(#276)
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 03-24-2020, 10:04 PM
I had a flashing CEL the other day on cold start.
Engine had a slightly rough idle. While CEL was flashing, I scanned for codes using the JB4 app with the engine running but none found. The CEL never went solid and no error msgs.
Stopped the engine , restarted and CEL was gone and idle was fine. Drove around for hours right afterwards and had no issues, and haven't since.
Not too worried as it seems like a one time hiccup so far. Just an FYI and to see if anyone has input.
4/22/20 Update: this has not recurred yet
Okayandre Okayandre is offline
Car: 2017 Mercedes c63s
Default Issues - 04-29-2020, 10:50 AM
Hey guys i have the 2017 c63s, f1 *********, straight piped all the way through, BMS intakes, plus the jb4 tune.
My idol is really rough. If I sit at a light for to long in any map but map 1 my engine light will start flashing n mid fires occur. When the car is moving it’s fine just when I stop I see problems.
I started running 30% mixture e85 and it ran great in map 3/4 the whole
Day but towards the end once I started doing pulls the jb4 kept putting itself to map 8 “valet mode” my boost safety is at 25 and fuel loop is at 30 so I’m not sure what’s going on. Any 3rd gear pull as soon as I hit high rpms it’s straight to map 8.
If someone can give me some insight that would be much appreciated.
spikiii's Avatar
spikiii spikiii is offline
JB4 addict
Car: powered by JB4
Default 05-01-2020, 06:49 PM
Been using v4 for a while now with no dramas - smooth transitions
random question - did the firmware files get removed from first post? can't see them there anymore
Car: 2014 335i M-Sport
Default 05-13-2020, 09:16 AM
The firware files are located here now: Platform Firmware Manager Yeah, it took me a minute as well. A version 6 is now available.
2003 E39 M5 - Sold
2013 335i MSport - Sold
2018 C63s AMG - Sold
2021 M550i
chongl chongl is offline
Car: 2017 C63
Default 05-13-2020, 09:21 AM
I wonder if true boost by gear has been implemented yet
Anyone running E30 mix in CA on map 3? I'm still on map 2
Default 05-13-2020, 09:25 AM
I feel for you Cali guys. Running E30 on Map 5; 93 octane . It's retarded
2003 E39 M5 - Sold
2021 M550i
spikiii's Avatar
JB4 addict
Car: powered by JB4
Default 05-13-2020, 03:06 PM
Thanks mate!
Default 05-14-2020, 08:22 PM
We don't have gear in there yet but boost by speed remains active and one of the most useful user adjustments in the app!
It's in the app now, and a link is provided for those few using a datacable/laptop.
spikiii's Avatar
JB4 addict
Car: powered by JB4
Default 05-14-2020, 08:59 PM
ahhh most users on the bluetooth app now.
lol thanks for not forgetting about us old USB cable uesrs :D
jagger230 jagger230 is offline
Car: Volkswagen GOLF R
Default 2018 Mercedes E63S - 06-03-2020, 06:47 AM
hi there, i run 94 petro canada in my E63S
i wanna to run map 3 map 1 and 2 seem good on 94 octane. what do you guys recommend for me to do in order to run map 3. my best time is 10.58 in 132 mph on map 2 on 94 octane. let me know what you guys think. which octane booster is the one you guys recommend
LessIsMore's Avatar
Inner Circle Member
Default 06-08-2020, 10:34 AM
You need meth injection, ethanol (E85), or race gas for maps 3 - 5. I run those maps successfully on my C63 with about E30-E35 mix, by mixing E85 and 93 pump.
None of the octane boosters you can buy and add to the tank of pump gas are going to be enough.
Default 06-10-2020, 09:36 AM
Hi guys I got a code on my E63s 2018
Here are the codes
P0300-22
P0305-00
P0306-00
P03008-00
Do you guys think I need to change spark plugs sometimes I have a rough ideal.
What do you guys think? The code doesn’t clear it comes right back w a flashing check engine and idles very rough
LessIsMore's Avatar
Inner Circle Member
Default 06-17-2020, 11:55 AM
those are misfires i believe. Do you get them on map 0 or just higher maps?
Default 06-17-2020, 07:37 PM
I get them in all the maps just changed an injector on warranty and only 4 spark plugs maybe I should change the other 4 as well?
18bora 18bora is offline
Car: C43
Default 06-27-2020, 05:54 PM
I just finished installing it on my 2020 glc63. It fired up without any CEL's, but I don't have RPM or throttle readings. Everything is connected properly, I even unplugged and plugged the obd2 wire and still no rpm/throttle.
Default 06-27-2020, 09:30 PM
If it's a 2020 model be sure to update to the 2020 C63 firmware to enable CANbus!
Car: C43
Default 06-28-2020, 08:14 AM
I keep getting error message
Default 06-29-2020, 11:21 AM
Ah yes that was an app bug, I think you emailed me about it?
Car: C43
Default 06-29-2020, 03:25 PM
Got the update and it's working now, Thanks.
I did a couple of pulls this morning (before the fix) and I got decent numbers.
My best 0-60 stock
I ran out of road on the 1/4 mile run and had to hit the brakes.
My best 1/4 times stock. Based on the 1/8th times, I'm getting around 5mph over stock.
Default 06-29-2020, 05:04 PM
Looks like a good start. Hopefully now with CANbus active you can log the runs!
HashtagC63 HashtagC63 is offline
Car: 2017 C63
Default 07-10-2020, 09:26 AM
Hey all,
I've read through this entire thread and it seems like it is possible to stack an aftermarket ECU tune and JB4. What is the best method to get dialed it properly? Who exactly should I message or email with Map 0 logs?
Default 07-11-2020, 11:11 AM
Yes just post or email the map0 logs to terry@burgertuning.com and I can help you get it dialed in!
Car: 2017 C63
Default 07-15-2020, 12:51 AM
I just emailed Terry, but also wanted to include them here in case anyone else on the forum wanted to chime in.
The two most recent files were short highway pulls to redline. The older file was a dyno pull in 5th gear. All done on map 0 with 93 oct.
Default 08-08-2020, 11:12 AM
hey so again i have misfire codes,P0305, P0306, P0308 those cylinder did in fact have spark plugs and injectors changed at the dealer i changed 6 injectors and all the spark plugs the car went on limp mode twice because it showed the afr was lean. i have a E63 S AMG 2018 im a lost of words of what to do. its either someone helps me to solve the problem or im removing the unit from the car
