alo0oy215's Avatar
alo0oy215 alo0oy215 is offline
Car: 2012 f30 335i
Unhappy transmission slipping - 03-23-2020, 04:30 AM
As it says in the title, my transmission is slipping in all gears except 2nd, 4th and 8th all other gears cant be used. once i shift and try to accelerate the car acts like if it is in neutral and goes to limp mode and locking the transmission in 4th gear until i restart the car it goes back to normal and i have to use it in manual and skip the bad gears.
car has:
D o w n p i p e
chargepipe
Jb4 BEF
Meth injection
Xhp stage 3 (returned to stock and the same thing is happining)
the car has nearly 136k miles on it
looked into the problem and found out that the clutch pack C is bad, for fixing the issue i went to some shops and the price was so expensive so my only option now is to buy a used transmission and replace it.
is there any programing or coding or anything special needed when installing the new (used transmission) to make it work?
N55 powerd 335I sedan :
1- kettyless D P
2- CP
3- Custom exhaust
4- JB4 + FF wires
5- BMS F30 N55 Performance Intake
6- BMS WMI KIT
Default 03-23-2020, 10:01 AM
Logs?
alo0oy215's Avatar
Car: 2012 f30 335i
Default 03-24-2020, 01:05 AM
Logs?
Canít do any logs
Once i hit the throttle peddle the engine revs like itís in neutral and suddenly it shifts to the next gear and i get a malfunction message and the car locks me in 4th gear
1- kettyless D P
2- CP
3- Custom exhaust
4- JB4 + FF wires
6- BMS WMI KIT
hardparker hardparker is offline
Car: F25
Default 03-26-2020, 03:36 PM
That's the 8HP45. I've been thinking of doing upgrade kits for those like I've done on some of the Jatco transmissions in the past. I've seen burnt C and E clutch packs on the 8HP45. Not a lot, but a some of them out there. Seems like power levels on cars that came with them are starting to approach the limits. That plus high mileage examples like yours, or a combination of the two.
F25 X3 35i M Sport | Pure Stage 2 turbo + inlet | UR de-catted thingy | VRSF Race IC | FTP full thingies | BM3 PTF tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | 50iX brakes
alo0oy215's Avatar
Car: 2012 f30 335i
Default Yesterday, 08:34 AM
It would be great to find an upgrade for the clutch packs especially pack C because it is the main pack in 6th gear which is the weakest + 3rd gear and thats why they have a torque limiter from the factory
1- kettyless D P
2- CP
3- Custom exhaust
4- JB4 + FF wires
6- BMS WMI KIT
