(#5201)
guymandude guymandude is offline
Car: 2018 Q50 Luxe 3.0t AWD
Default JB4 Guages: no boost then blue boost - 03-26-2020, 08:59 AM
Some weirdness this morning as I was about to go on my daily Kung Flu supply run. I had zero boost registering on boost 1. Boost 2 showed numbers but the gauge was blue instead of green. I shut the car off then back on a couple times and boost 1 started registering again. But they're both showing blue...what does that mean? I posted a short run of map 0 then another longer run of map 1. Can you please take a look and let me know if anything looks amiss as well as explain the blue boost gauge (as it is normally green)?
2018 Q50 Luxe 3.0t AWD. JB4, no other mods
styles styles is offline
Car: '20 Q50 RS AWD
Default 03-26-2020, 09:35 AM
The only issue I see is timing advance is really low as if it's on really bad fuel. Sure it's not filled with 87 octane?
I always only use 93, for all my cars. How could I fix that or any ideas of what could be causing that issue given that I am on 93?
Thank you
'20 Q50 RS AWD
JB4 w/BT, AMS LDP, MBRP CBE, SPL Adjustable Rear End Links, Stillen RSB, Tanabe FSB, RS-R Down
Car: '20 Q50 RS AWD
Default 03-26-2020, 09:37 AM
No throttle = no fuel.. the AFR is normal.. I can't read logs so I will let others chime in
Thanks Serstylz
'20 Q50 RS AWD
rad1game rad1game is offline
Car: Infiniti Q50
Hello guys.
Just recently bought my Q50 Luxe (2019), make a service on 10k KM, and installed JB4.
Could you please assist me on the log, since I am not really familiar with it.
I make a run on a "super" fuel (98 octane in my country) using map5, from ~30km\h to 262km\h (speed limiter, yes). As per my own ass feeling the car, everything was fine, but I want somebody more experienced to double-check all the parameters.
Thank you in advance!
dajcopeland dajcopeland is offline
JB4
Car: Q60 Redsport
Default JB4 Version 8 Firmware Question - 03-26-2020, 10:03 AM
Hi Terry. I'm now running V8 firmware on my Q60 Redsport. Do I need to now switch FUD 6 to on?
Default 03-26-2020, 10:14 AM
Thanks Ando for assisting via DM!
In the event anyone experiences the same...gauge color isn't an indicator of an issue and logs look good (unsure why gauge color for the two boosts changed tho did have a smartphone update earlier this week which may have been the culprit).
I reseated all the JB4 connections anyway and while doing so didn't notice any bent pins, etc. It appears to be reading properly now so will keep an eye out. BTW the car never felt like it was running bad/different...just the boost 1 gauge was not reading for some reason tho is now.
Car: q50
Default Yesterday, 06:57 AM
Are fuel wires required for using the EWG add-on feature?
Q50 Premium RWD
BMS JB4 w/ FW & WMI
BMS HE
Default Yesterday, 10:50 AM
Suggested.
Car: q50
Default Yesterday, 11:33 AM
Suggested.
Are you commanding more fuel down low or leaning it out? I'm running WMI and prefer the richer mixture after seeing some full times. If you're pulling fuel with the fuel wires I don't plan to add them, but if you're adding fuel down low I may put them back on. Just ALOT of wires to snake around the engine bay between WMI, fuel wires, now EWG.
Q50 Premium RWD
BMS JB4 w/ FW & WMI
BMS HE
Car: '20 Q50 RS AWD
Default Yesterday, 09:47 PM
Hi Terry,
Have another log (combined this time) that I would appreciate some feedback on. I believe I was experiencing some of the hesitation and issues i described during these logs. Curious if there's any other issues you might see in addition to the low timing advance.
Appreciate the input!
'20 Q50 RS AWD
