(#3826)
Default 06-29-2020, 05:38 PM
Thanks, I should have specified PWG as I didn't make the change to EWG yet. Sorry!
NLM235I NLM235I is offline
Car: M235i
Default 06-30-2020, 02:48 PM
Originally Posted by cashzhang87
hey i’m running jb4 with EWG Connector!
i went to updated jb4-f -ewg -18-t5 , that is Newest!
and after that CEL is on !
123511 Wastegate Flap Sluggish
120308 Boost pressure lower than expected
i got ******* DP ,bms intake!
I want to know what's going on!
thank you!
Today I did the same updated to jb4_f_ewg_18_t15.hex. The car reaction was slow and got the same codes :
108F01 Boost pressure lower than expected
Flashed back to jb4_f_ewg_17_t2.hex and the car was fast as before and no codes...
I think there is something wrong with the latest bta firmware?
Driving a m235i ******* DP, chargepipe and wagner ic.
Default 06-30-2020, 04:45 PM
Fail to enter the new duty bias = 50 settings perhaps? Log would shed light on it.
Car: M235i
Default 07-01-2020, 03:25 AM
Its the first time I do this, see log. I hope its ok, please let me know what you see?
fldfld fldfld is offline
Car: 2013 535i xDrive
Default Anyone have a copy of the old .HEX files??? - 07-02-2020, 02:23 PM
So, I just flashed to the version 15 of the N55 PWG...and my car is now not driveable. Drivetrain codes, MAP codes...
These all appeared the minute the app said refreshing the JB4.
Of course, like a moron, I deleted the old .hex file.
Does anyone have N55_F_PWG_INT_13.hex???
With the app changes, you only get to download the latest version and all the older files are gone from here. And, BMS says they don't have it!
Appreciate it if anyone could send the version 13 to me. Thanks
siim138's Avatar
siim138 siim138 is offline
Car: F10 535i
Default 07-03-2020, 12:33 PM
fldfld, did you get INT_13.hex file?
2011 F10 535i M-Sport PWG // Deep sea blue //
//JB4 PWG_INT_13 + BMS BEF PWG1_RACE_3 // M Performance mufflers// 3,5" cless dowpipe
Default 07-03-2020, 12:36 PM
siim.... No, not yet... Please tell me you have it...
Default 07-03-2020, 12:37 PM
No, not yet... I sure hope you have it...
siim138's Avatar
Car: F10 535i
Default 07-03-2020, 01:04 PM
here you go. N55_F_PWG_INT_13_T1.hex
It is T1, hopefully does not matter, my 535i runs very good with this
Default 07-03-2020, 01:53 PM
Awesome thank you!!!!
I'm going to reconnect the JB4 now and flash it with this.
BMS wants me to send back the circuit board but I'll do that next week after I give this file a try.
Thanks again!
Default 07-04-2020, 10:56 AM
Thanks again!
A firmware change isn't going to cause faults unless you loaded the wrong firmware for the board, which would be obvious if we looked at a CSV file.
Default 07-04-2020, 11:05 AM
Terry, well, I get what you're saying but I loaded version 13 last night and the car is now perfect again.
I've been loading the correct software and flashing it since I've had the JB4. Never had a problem before. So, it's either the board or the version 15 flash. That's why I'm sending the board to you next week. I can only say what process I used to flash it to 15 and the fact that it immediately starting throwing codes and drivetrain errors putting the car into low power mode. Then, the return to 13 went perfectly and all codes gone.
Something ain't right but I'll leave that up to you and Ando to figure out.
Default 07-04-2020, 01:56 PM
Don't have enough information to offer you any useful advice. What is your email address? If you've sent in v15 logs and the code details I can always check those to see if anything is set wrong.
Default 07-04-2020, 02:38 PM
dressler.rick@gmail.com
I sent the log file the other day to Ando.
I appreciate you taking a look.
Default 07-04-2020, 03:43 PM
Don't see any obvious issue but it's a v1 PWG board, not a current v2 board. So could be some firmware conflict with it although nothing else has been reported. If the older firmware is working better for you then just stick with it.
Default 07-04-2020, 04:10 PM
Well, so much for the complimentary upgrade to a v2 board.
Thanks, I'll just stay with version 13 for the life of the car.
