Jamesholden Jamesholden is offline
Car: Bmw e92 335i
Default Log review need help! - 06-30-2019, 09:57 PM
Hello,my mods are bef.pump,***,lpfp stage 2,dci,cp with tial bov,2step relay
From couple of days my car works very bad and fuel trims looks worse,sometimes code 29e1 (fuel mixture control 2) pops up or misfire on several cylinder from bank2 only and sometimes no code its shown.What i have to do to resolve this isue. Thank you
Default 07-01-2019, 10:18 PM
What are you using for fuel?
Trims look a little wonky, and timing doesn’t look great
Car: Bmw e92 335i
Default 07-01-2019, 10:33 PM
I use 98ron gasoline...i am from europe
Default 07-01-2019, 10:39 PM
Does the car still misfire?
You’ll want to get those addressed first...
Car: Bmw e92 335i
Default 07-01-2019, 10:46 PM
Yes but most of the time on cyl 4 i get code for misfire.should i get out all spark plugs from bank2 and check them? and why trims looks so bad?its o2 sensors bad or injectors maybe?
Default 07-03-2019, 01:03 AM
Plugs or coils generally for the misfire..
Trims can be o2 or injector related
Let’s get your misfire fixed first & review logs
Car: Bmw e92 335i
Default 07-07-2019, 09:43 PM
i just change spark plugs and coil with new ones and misfire on cyl 4 its gone but code 29E1 still appears. i make 2 logs ,cold start on idle and 2k to red line.
Default 07-09-2019, 09:20 PM
Nothing glaring in the logs.
Have you cleared & it comes back?
Car: Bmw e92 335i
Default 07-10-2019, 03:46 AM
I have deleted the codes but the code 29E1 (fuel mixture control 2) reappears and in the morning when i start the car the idle its very unstable
Default 07-10-2019, 06:54 AM
Could be a few things...
You’ll throw mixture codes for a few reasons- tune related is when trims max positive or negative for too long
Given your morning start issues- let the car sit overnight & pull your spark plugs- check if they’re wet with gas... if yes- I would imagine your injectors need replacing / are causing the mixture control code.
Car: Bmw e92 335i
Default 07-10-2019, 07:29 AM
I have already checked the spark plugs in the morning and are dry,I'm thinking about the bank2 pre *** lambda sensor....can be that cause?
Default 07-10-2019, 07:53 AM
Yeah tired o2s can do that...are they original?
Car: Bmw e92 335i
Default 07-10-2019, 09:37 AM
nop,its bosch ones car have 200k km on board
Default 07-10-2019, 12:12 PM
Might be worth replacing especially at that mileage regardless
