JB4OFF JB4OFF is offline
Car: 340i
Default 06-08-2017, 05:45 AM
Logs look normal to me. Stick with map 1 and shell 93
risktaker76's Avatar
risktaker76 risktaker76 is offline
Car: BMW 440XI MPPSK
Default 06-12-2017, 06:44 AM
Saga continues... again MPPSK 440 with Shell 93 octane
I have been fighting "smoothness" and predictability... In other words sometimes the car runs like a champ (relative) and other times like a stuttering mess (normal driving no issues - mostly hard accel or WOT is the issue)...
I also have noticed that my Sport Gauges no longer would hit my peaks as I once had (pre JB4).. 370HP and 375TQ (about)... Its clear when I hit my previous peaks on these gauges the car pulls... when not such as 300 peak HP 320tq peak the peak bounces around - its a stuttering mess and doesnt pull at all near stock...
The logs unfortunately dont tell much either how the car is driving or performing... Logs look fairly good...but dont tell the truth unfortunately.. As you can see FOL at 60 looks decent - but its a stuttering mess actually..
I decided to revert back FOL to 0 and the car is running MUCH smoother under normal driving conditions (partial to before WOT)... At WOT its still unpredictable but much much better - and the car pulls like a rocket now... Its almost as if FOL at 60 is either not giving it enough fuel or too much.. (im no expert)... But overall FOL at 0 the car is running better throughout the RPM range under most driving conditions.
One other point - with FOL at 60 pops and crackles (MPPSK exhaust) was at a minimum - Now they are back with a vengeance...
Why all this?
So.... I need some insight from the experts in the community.. I figured I would share these findings in the open community to hopefully help in tuning MPPSK cars...
I am playing now with map 3 and will do the same (fol 0) and report back... I have a concern about the amount of boost now... Its now averaging almost 17 and peak at 21 - from watching the real time gauges! Is this safe?
I will be ordering the EWG wires to run fixed Boost - however, I think the community would love to be able to get a stable map without all the extra wires.
Maybe we need a MPPSK map...
thanks again for all the help the community has given..
Default 06-12-2017, 06:03 PM
Terry@bms Any feedback ?
Default 06-13-2017, 05:29 AM
Here are logs from Map 3 FOL 0...
The car is running significantly better with FOL at 0 (Flex / Fuel Pressure wires disabled) vs FOL at 60...
Map 3 doesnt pull as hard as Map 1 but clearly some nice gains...
Of course feedback always welcome..
Bullitt1841's Avatar
Default 06-13-2017, 07:02 AM
Try setting FUA to 10. That helped me with smoothness a little.
Default 06-13-2017, 07:43 AM
If I am not mistaken, I need the EWG wires for that to work correct?
I have to say changing FOL to 0 maybe very close to stock smoothness... I need more time to evaluate but I went back to look at my Map 0 logs and in fact I have less Throttle closures with similar curves except with more boost (albeit less timing)...
Have you ever tried taking yours to FOL 0? If not, try it and report back.
Default 06-14-2017, 11:58 AM
No new logs... But the car does not like Map 1. At WOT its not getting to full power and seems to lose it as you approach red line. It also seems as if something resets and takes time to learn again as its fine for a little bit then again some stutter and not getting full power...
Map 3 however is very smooth - not perfect but pulls to red line with little fuss... Does not exhibit the symptom of falling flat...
Default 06-16-2017, 09:33 AM
Open loop only works with the fuel pressure connector on, and FUA only works with the EWG connector on, regardless of settings. Red herring there since you have neither as I understand it. Once those sensors are attached if fuel trims are maxing out raising open loop will lower them. If you're getting excessive throttle closure (from boost going over target) raising FUA will lower WGDC and bring boost down to target.
The map3 log looks OK to me. You're going to run 2-3psi more boost than stock on map3, PPK it hitting 16-17psi, so makes sense for you to hit 19psi.
You mentioned map0 also feels off? That makes no sense as its a straight pass through!
Thumbs up 06-16-2017, 11:02 AM
Hi Terry,
Right now I have the Flue Pressure connector. However running FOL 60 power delivery was very inconsistent under WOT.. Even around town driving acceleration smoothness was very unpredictable.. Even though the logs look OK the car was not accelerating smoothly - with some points with loss of power - However as you can you can see where I compare FOL 60 vs 0 there no throttle closures with FOL 60 but the car was not accelerating cleanly (it was actually slightly bucking during this run) - http://www.n54tech.com/forums/showpo...4&postcount=27
Any advice on this point?
I also now purchased the EWG - though not installed yet.
In general I am fighting inconsistency in acceleration across all maps tried and why I purchased the TWO cables; To allow complete tweaking as needed. Again, some times no issues, other times (within minutes) stuttering. Here is an example taken 1 day apart - http://www.n54tech.com/forums/showpo...2&postcount=21
With that said, whats a good starting point with Fuel Pressure Cables and EWG Cables installed for Maps 1 or Map 3 (I will try both)... Eventually I will tackle Map 6.
DOn't mind putting in some time logging and sharing the results for future improvements..
Regarding Map 0 - I am not sure at this point. At that time Map 0 wasnt liking something but it could also be the computer relearning. I will write that off as that.
