(#51)
djerickd djerickd is offline
Car: 2019 GTS
Default 03-06-2020, 10:35 AM
You can't online...
Default 03-06-2020, 11:50 AM
Originally Posted by djerickd
You can't online...
https://www.burgertuning.com/product...31406336376947
whytiptoe whytiptoe is offline
Car: 2019 Kia Stinger GT2
Default 03-11-2020, 06:19 PM
Ok I have to say with my setup the EWG wiring has made a huge difference. My setup including WMI it is awesome!! Who else weigh this setup thinks the same thing?
atr1 atr1 is offline
Car: Stinger GT
Default 03-11-2020, 06:30 PM
How do you set it?
My car is faster too.
MNStinger MNStinger is offline
Default 03-11-2020, 08:56 PM
Just got these installed, did a quick test drive and something is definitely not right...feels way under powered. Using v14 firmware set bit 3 on, duty bias 50, ff 50, pid 20, auto shift 60.
BMS Intakes, Arc Secondary *********, MBRP Exhaust, Ultimate Perf Intercooler
What would u like from me? I assume some logs, but anything special about the run, gear, speed, etc?
2019 GT2 AWD - Panthera Metal
JB4 - Fuel Wires - EWG Wires - Ultimate Performance Intercooler - BMS Intakes - ARK Secondaires - MBRP Exhaust
Default 03-11-2020, 09:42 PM
Normal log should be fine. If you have another log to compare from previous firmware that would be great too.
asdap2 asdap2 is offline
Car: kia stinger
Default Ewg dyno test - 03-12-2020, 06:14 AM
I connected the ewg connector and did a Dyno test. We'll reach 500 hp in a few days. Joyful challenges always make me happy.
Car: Stinger GT
Default 03-12-2020, 06:58 AM
Nice graph. Does your car overboost during partial throttle?
Car: kia stinger
Default 03-12-2020, 07:28 AM
No, we don't have a load to worry about. If it's too much boost, we can change the settings.
Car: kia stinger
Default 03-12-2020, 07:48 AM
<font class="papago-parent"><font class="papago-source" style="display:none;">
Originally Posted by atr1
</font>
Originally Posted by att1
</font> <font class="papago-parent"><font class="papago-source" style="display:none;">Nice graph.</font>그래프가 좋네요. </font> <font class="papago-parent"><font class="papago-source" style="display:none;">Does your car overboost during partial throttle?</font>당신의 차는 부분적인 가속 중에 과열됩니까? </font> <font class="papago-parent"><font class="papago-source" style="display:none;">
</font>
</font>
Default 03-12-2020, 08:20 AM
No logs yet, but when I jumped in the car this morning I got some codes but can't find anything online about what they mean:
25A1
259E
Is there anyway in the app to ensure that I have everything wired up right? I checked and double checked everything before I put it all back together but...
Car: Stinger GT
Default 03-12-2020, 08:39 AM
25A1
259E
I've had both of them.
Here are the codes that I encountered so far.
259E 25A1 2564 2588
None seem critical but sometimes they are related to the settings.
Did you check the DTML WMI Input bit?
What are your duty bias values? Have you filled all values?
Default 03-12-2020, 09:52 AM
259E 25A1 2564 2588
Firmware: v14
DTML WMI (Bit 3): On
Duty Bias: 50 from 1500 - 7000
PID Gain: 20
Auto Shift Boost Redux: 60
FF/Wastegate Adaption: 50
I'm currently running Map 3 with a mix of 93 and e85.
Car has been running really good, unfortunately I don't have any "real" logs other than some random logs from daily driving.
Once I got it all back together, took it out for a quick drive and it felt really sluggish, not anywhere near the power/acceleration I'm used to feeling.
No codes when I shut the car off, but this morning when I started it up the codes were there...
I'll clear the codes and then get some logs over the lunch hour.
Default 03-12-2020, 12:30 PM
Here are some logs, hopefully they have what you need.
Default 03-12-2020, 01:32 PM
25A1
259E
Usually people mix up one of the wires or plug them in the wrong spot. You can post some photos if you want us to double check the work. The JB4 settings seem fine to me.
Default 03-12-2020, 01:34 PM
Yes there is a lot of potential here, we'll need to see exactly where the factory turbos stop adding power for you.
Default 03-12-2020, 01:40 PM
I'll take it apart tonight and let you know what I find. Does it matter which plug goes to which side (i.e. - driver/passenger) or can either plug go to either side?
Default 03-12-2020, 01:52 PM
How do you set it?
As it is Beta, I am just following Terry's suggestions and as far as setup I am talking about my bolt ons; Intake, WMI, Fuel-it, JB4.
Car: Stinger GT
Default 03-12-2020, 02:34 PM
You have boost pre trottle but very low boost past the throttle (boost2). I am not sure why. It did something like that when I didn't have the DTML WMI Input bit set to 1. If all the settings are correct there may be something wrong with the install.
What does the FF/Wastegate adaptation 50 do?
Djavier21 Djavier21 is offline
Car: 2017 Q60 Luxe
Default 03-12-2020, 04:30 PM
First order of business is those cars with modified exhaust that over boost, and of course large turbo cars who need more WGDC.
I'm going to be installing a full exhaust and Z1 catted *****. Will the EWG update control over boost issues?
Djavier
2017 Q60 AWD Luxe
JB4 w fuel wires
AMS Intakes
BMS HX
BMS Pedal Tuner
HKS BOVs
Megan Downs
Default 03-12-2020, 06:26 PM
Ok, took things apart and turns out I had swapped the purple pins...doh! Put it back together and I'm back in business...here are a couple logs. I did notice that it must have gone into safety mode cause the last log was map 0 which I didn't change.
Default 03-12-2020, 07:33 PM
Fuel pressure is tanking! What's the fuel mix?
Car: Stinger GT
Default 03-12-2020, 07:46 PM
Glad to know that you found the problem
Default 03-12-2020, 08:12 PM
It's 93 octane with about 4 gal of e85.
Default 03-13-2020, 08:59 AM
Strange that it's dropping with so little E85. First thing I'd try doing is leaning it out more using the custom fuel bias settings at 130 across the board.
