danalmsa danalmsa is offline
Car: G80 Sport 2018
Default Timing pullback as soon as I press the accelerator - 08-30-2021, 07:07 AM
I have noticed that timing will pull back between 2.3 and 5.3 on many cylinders the moment I press the pedal and was coasting. RPMS are at around 1500 to 2000, and the pedal is 50%. Boost is near 0 or just plain 0.
It's a spike and it disappears. I thought it was a MAP 6 thing, but, it happens with MAP 2 as well.
Under boost, I get no corrections and I don't see those spikes anywhere else, the car behaves great.
Personally I think it's when the gears are high, car is moving and slight acceleration causes the car to bog. Just wondering if others have seen this?
2018 G80 Sport
Jb4 Map 6 with EWG & Fuel Wires
DYI Intake (half BMS intake)
BMS OCC
TB Coolant Bypass
Windbooster Pedal Tuner
Steve @ BMS/Fuel-It! Steve @ BMS/Fuel-It! is online now
Default 08-30-2021, 11:15 AM
Car: G80 Sport 2018
Default Timing pullback as soon as I press the accelerator - 08-30-2021, 01:06 PM
Sorry about that. I attached a log. It's bit long (I tried cutting it down). But in it, you can see various examples of the behavior.
2018 G80 Sport
BMS OCC
TB Coolant Bypass
Jaybone Jaybone is offline
Car: 2020 Kia Stinger GT1 AWD
Default 08-31-2021, 09:19 AM
Not sure but doesn't look like anything to be concerned about. Could be false knock its picking up but its so short and consistent I wouldn't be worried about it.
JB4 W/FUEL WIRES & EWG WIRES
BMS INTAKES
BMS WMI KIT
BMS OCC
FUEL IT FLEX FUEL KIT
BORLA EXHAUST
STOPTECH FRONT AND REAR PADS
DENSO 5346
SEIBON CARBON FIBER OEM HOOD
NICHE 20" WHEELS MATTE BRONZE
DRONE MOBILE REMOTE START
Default 08-31-2021, 09:42 AM
Looks pretty normal...you will run much higher timing when cruising and no boost, then once you put the throttle down, it'll pull timing based on the timing targets in the ECU...totally normal.
Car: G80 Sport 2018
Default Timing pullback as soon as I press the accelerator - 08-31-2021, 11:57 AM
Thank you for confirming that. With boost, timing is fine (from what I have seen). So glad to hear it's nothing to worry about.
2018 G80 Sport
BMS OCC
TB Coolant Bypass
Default 08-31-2021, 02:23 PM
I noticed it doesn't say fuel wires on your mods list. Do you have those connected?
BMS INTAKES
BMS WMI KIT
BMS OCC
BORLA EXHAUST
DENSO 5346
Car: G80 Sport 2018
Default 08-31-2021, 03:51 PM
Yes I do. I'll update my sig.
2018 G80 Sport
BMS OCC
TB Coolant Bypass
