(#51)
Default 06-03-2021, 08:23 AM
Originally Posted by Sdt777
If Manhart MH3 600 with their tuning box can do 635 HP then the JB4 should be able to do it also?
With the JB4 you can push the tuning as aggressively as you want! We've seen some crazy numbers reported running E85 mixtures for example.
chinh_us chinh_us is offline
Car: 2021 G82 M4
Default 06-09-2021, 04:17 PM
Just installed today, thanks for the great product.
On the G82 you can drill out the firewall rubber indent for the OBD cable. Looks slightly different from the instructions but in the same general vicinity.
Default 06-10-2021, 07:57 AM
Awesome, thanks!
Mihail Mihail is offline
Car: Bmw M140i xdrive
Default 07-19-2021, 04:55 AM
JB4 Map 2. E20.
TMR's Avatar
TMR TMR is offline
Car: E92 335i
Default 08-02-2021, 09:11 PM
Terry I need a 6 speed JB4.
Donald
Mattssi Mattssi is offline
Car: 2000 Ford Escort
Send a message via AIM to Mattssi
Default 08-03-2021, 11:31 AM
Me too. And when will this be out of "beta"?
Matt
G80 M3
Old 135i 'vert
1st HPFP (881) down @ 1500 miles
2nd HPHF down @ 3000 miles
Fuel Pressure sensor down @ 8000 miles
Tail lamp replaced @ 8500 miles
Lemoned @ 9200 miles
On to the next I guess!
Default 08-09-2021, 01:43 PM
Donald
What is a 6 speed JB4 lol. JB4 is compatible with manual and auto trans, always has been.
Default 08-09-2021, 01:44 PM
It's been pretty stable so we may remove the BETA designation within the next few weeks. Like to get a few hundred units out around the world before we do generally.
circa77 circa77 is offline
Car: 2022 G80
Default 08-14-2021, 01:27 PM
So, 2 quick questions.
1st -
In the map guide, you list some maps like map2 as "4psi peak request over stock".
Since Base 6Mt G80s and the M3C request different amounts of boost at stock, does this map behave differently between the base and competition? Or is it normalized across all versions of the G80/82 (since they are the exact same engine)?
2nd -
I'm seriously happy you list the recommended fuel types for each map, but do you have expected gains for each? The dyno images on the product page are great and all, but they don't indicate which platform or map or fuel in the notes.
I think a lot of 6MT buyers (like myself) are going to look at correcting BMWs absurd downtuning of the base with a piggyback system, so it would be great to better set the expectations for those of us dumb enough to have bought the 3-pedal version of this magnificent car.
Default 08-15-2021, 01:21 PM
1st -
2nd -
+1 I'm curious as well.
Matt
G80 M3
Old 135i 'vert
Default 08-25-2021, 10:04 AM
1st -
2nd -
Additive maps are added on to the factory target while absolute maps run a fixed target. Generally speaking there is no power difference between comp and non-comp vehicles when JB4 tuned. The only difference is what map is required to get to the desired power output.
If you have specific questions on what map to run we'd need to see a JB4 log from your specific car/fuel/situation.
The posted dynos have their details listed...
https://burgertuning.com/products/s5...be67c295&_ss=r
Default 09-23-2021, 10:39 AM
Our G80 S58 intakes are shipping...
https://burgertuning.com/products/bm...77247b50&_ss=r
https://burgertuning.com/products/fr...77247b50&_ss=r
Default 11-10-2021, 02:08 PM
The Fuel-IT kit for the M3/M4 is ready, featuring stainless braided fuel lines! Super clean.
https://burgertuning.com/products/fu...-g80-m3-g82-m4
chris3g chris3g is offline
Car: G80 M3
Default 11-16-2021, 09:12 AM
[img]https://cdn.shopify.com/s/files/1/0890/2048/files/S58-flex-fuel-sensor-m3-m4-g80-g82-g83-bmw_1024x1024.jpg?v=1636573235[/ img]
[img]https://cdn.shopify.com/s/files/1/0890/2048/files/S58-flex-fuel-sensor-m3-m4-g80-g82-g83-bmw-install_6406313e-3fda-467e-8ab2-490487e42c41_1024x1024.jpg?v=1636574340[/ img]
Which wire should be tapped for power?
Default 11-17-2021, 06:40 PM
The G8X flex fuel kit and install location...
Closeup of install location...
Here's the complete installation guide...
Remove the strut brace with a 15mm socket or wrench and then remove the engine cover.
Remove the gray safety clip on each end of the stock fuel line...
To remove the stock fuel line, let the car sit overnight so there is no fuel pressure. Then push the line on as much as possible, depress the black clip, and then pull the line off.
Install the fuel lines, analyzer, and harness on to the ethanol sensor as shown. Connect the ends with the 3/8" fuel fittings to the ethanol sensor as shown.
Here's a video showing how to connect the fittings.
How to install our Cam-Lock! style fitting. - YouTube
Install the new fuel lines with the sensor and analyzer installed...
Connect the analyzer to ground...
Connect the white wire to the JB4 pin 4 of the DB25 connector...
Connect the power wire...
Superfly_whip Superfly_whip is offline
Car: 2022 BMW M3C
Default 108B0A Error Code After Installing JB4 - Help’ Please! - Today, 02:15 AM
Installed a jb4 and ***-less downs on my g80 can’t seem to get this code to go away.
Already double checked the tmap sensor under the intake (see below) I’m pretty sure it’s on there right.
Only other thing I can think off:
Are x3/4m harnesses/jb4 different than g8x? I ordered one of both and they just both came in labeled as s58
***** UPDATE
Decided to take off and rewire the whole thing an hour later and got all the codes to go away besides *** 108B0A *** and is hitting the rev limiter at 4k RPMS
*originally posted on Facebook but got no help, literally only one comment suggesting fried DME��***
Last edited by Superfly_whip; Today at 02:30 AM.. Reason: Wasn’t showing correct text
