(#3051)
ck awd korea ck awd korea is offline
Car: stinger gt awd
Default 03-15-2020, 05:40 PM
Is JB4 new? Sounds like you need another 2580 chip. If JB4 not new then plug be plug or coil.
Chip is 2580. Chip LastSafe is floating on number 3. What is it? fuel pressure low
Car: stinger gt awd
Default 03-16-2020, 10:35 AM
When did you buy the JB4?
Car: stinger gt awd
Default 03-16-2020, 10:32 PM
It's about April 2019
GregV GregV is offline
Car: Kia Stinger GT2
Default 03-17-2020, 07:09 PM
What problems is a bad 2580 chip known to cause?
Default 03-17-2020, 07:45 PM
We made a setting more sensitive and on some cars with good plugs causes JB4 to reset mid run as if plugs were bad.
Default 03-18-2020, 03:47 AM
Sounds like what I have been experiencing. Purchased on Jan 3 2020 and have already tried two different sets of plugs.
Default 03-19-2020, 08:41 AM
OK email me us your address we'll send a 2580 chip to rule that out.
akim93 akim93 is offline
Car: Stinger GT
Default JB4 Logs. Please review! - 03-21-2020, 10:44 AM
Hey Terry,
I have the jb4 installed on my 2019 Kia Stinger GT2 AWD.
-Map 2
-Denso Spark Plugs gapped to .22
-Fuel Wires Installed
-OBDII Installed
-93 Octane
-Lighter 18" Rims
Please let me know if there are any issues with my logs or is everything is good so far.
Thank You
Badley13 Badley13 is offline
Car: Stinger GT
Default Data log! - 03-21-2020, 03:14 PM
Hi Terry,
Here are my logs from today. First run it dropped to 2nd when floored. Iím running 93 gas on map 2. Spark plugs are factory gapped to .025
Default 03-22-2020, 08:20 AM
Originally Posted by akim93
Hey Terry,
-Map 2
-OBDII Installed
-93 Octane
-Lighter 18" Rims
Thank You
Looks fine to me!
Default 03-22-2020, 08:21 AM
Originally Posted by Badley13
Hi Terry,
You're on v7 firmware which had more limited logging, update to v14 and grab another run so we can check for knock in cyl 2-6.
BoostedLife BoostedLife is offline
Car: 2019 Veloster 1.6T
Default 03-22-2020, 01:20 PM
Are we still supposed to tap wire #2 for the fuel wire on front o2 sensor for 2019 Veloster 1.6T? I see Veloster N 2.0T says wire #2 but just making sure for 1.6T.
Holaam1986 Holaam1986 is offline
Car: Stinger GT
Default 03-22-2020, 05:59 PM
20200322_0208_runs(2).csv
Hi
Uploaded the first log
But I fail to run map1/2, map0 is ok. That mean I Connected the right socket of the JB4.
seem like misfire I guess but no fault I code .
I canít full throttle on map 1/2 when I heavy throttle the car shock, the rpm canít going high and the sound ďpop pop pop ď and the smell very bad
I buy the device on 17 JAN2020 form KHAR.
Also using HKS plugs without any gapping by myself
Nick said already gapped
Connected fuel wire
Updated V13 firmware
No check engine light
98fuel
No fault code
extra information: after I change the map, the jb4 app all the gauge freeze, need to reconnect the device.
Please check what is going on
Thanks a lot
Default 03-23-2020, 09:23 AM
Whatever we're previously stated in the directions. There is Veloster specific thread in this forum somewhere.
Originally Posted by Holaam1986
can’t going high and the sound “pop pop pop “ and the smell very bad
Just needs an updated 2580 chip, email us your address and we'll send one out. You can stay on map0 until then.
Car: Stinger GT
Default 03-24-2020, 02:51 PM
I clearly know what Iím doing. Let me know if this file works. Second pull downshifted you 2nd but the others should be good.
Default 03-25-2020, 08:54 AM
Looks OK to me here, although you left the app in "raw sampling mode" which is a diagnostic mode for logging that makes the charts look funny.
Car: Stinger GT
Default 03-25-2020, 09:14 AM
Thanks Terry! Iíll disable that for future logs
Car: stinger gt awd
Default 03-30-2020, 09:51 PM
2254 The engine warning light comes up every 2-3 days. Do you know why?
If you put the map in and hit the full axel, the boost will not rise, and the 0106 0049 code will be displayed, and Safe Mode 5 will be activated.
Default 03-31-2020, 09:20 AM
Some sort of o2 sensor code... Fuel wire installation problem?
Car: Stinger GT
Default 04-04-2020, 02:00 AM
After change the 2580chips
My car running well
Please check my dyno sheet and first log
I am using 98fuel
I try to run map 1 and map2 on dyno
But the map 1 result is better than map 2.
Imgur: The magic of the Internet
dgascho dgascho is offline
Car: Cobalt SS/TC 502whp
Default 04-05-2020, 08:31 AM
Been running on map8 flawlessly for several months now. Typically on 93 or e85/93 blend. All bolt-ons, meth, etc. Suddenly today on medium acceleration, noticed some shuddering. Stopped, tried a pull, major misfiring kicks into limp mode. Stopped, restarted, running fine. Dropped to map 0, runs ok for gradual acceleration, even to higher boost/rpms, but does the same thing if I floor it. Weirdly, throwing no codes? I can't even pull enough to log anything, I let off immediately as it starts bucking around, so not much on this. Haven't had time to investigate yet, but any suggestions?
stargtsi stargtsi is offline
Car: Stinger
Default 04-05-2020, 08:38 AM
Plugs
Default 04-05-2020, 08:42 AM
Firmware is now updated, as of now, if relevant. I agree, does sound like plugs, but the recommended ones I installed fouled already? Maybe 15,000 miles, but i guess that's a good place to start
