(#51)
Default 02-17-2020, 09:26 AM
Originally Posted by Vortex3.3
Ya there are a few guys on the g70 forum that ordered the stinger FMIC from agency power and it bolted directly up with no modifications needed. So I believe it will. Only reason Im willing to try it out
Yea, it just doesn't show it on the compatibility on the website. Keep us posted!
Default 02-17-2020, 09:27 AM
Originally Posted by djerickd
The toe hook rubs
Were you able to get any pictures?
Default 02-17-2020, 03:17 PM
Install guide is up.
https://www.n54tech.com/instructions...er-Install.pdf
Vortex3.3 Vortex3.3 is offline
Car: Genesis g70
Default 02-17-2020, 05:25 PM
Will do. I have been searching through the CPI threads and your website. Is there still a hold up on this kit at the moment? Would love to add this in when I get the new intercooler
2019 genesis g70 3.3 sport
Jb4, bms intakes, ark midpipes, jun bl catback.
Default 02-18-2020, 12:24 AM
We actually just got everything in! Will be on the website later this week
Car: Genesis g70
Default 02-19-2020, 09:01 PM
Awesome. Will the fuel it kit be needed to run CPI?
djerickd djerickd is offline
Car: 2019 GTS
Default 03-08-2020, 02:08 PM
Hey did anyone have a some oil in their oem intercooler when they removed it?
Default 03-09-2020, 11:01 AM
Normal from the PCV in the intake etc.
jsharp4684 jsharp4684 is offline
Car: 2019 Stinger GTS
Default 03-09-2020, 05:39 PM
So I have the BMS intercooler and the 450 kit. Can I safely run map 3 with just those items and 93 oct?
BTW, I didn't have any rubbing on the tow hook. It's pretty close though.
Car: Genesis g70
Default 03-09-2020, 06:16 PM
most likely you will need to bump up the octane. either with an e85 mix or octane booster
Default 03-10-2020, 02:36 PM
Post a log on map 2 with 93 only so we can evaluate that for now.
stargtsi stargtsi is offline
Car: Stinger
Default 03-11-2020, 08:39 PM
Any updates on the cpi kit? I'm trying to avoid going meth and would prefer cpi
Default 03-23-2020, 04:20 PM
Here's my log from today. 45F ambient air temp.
450hp kit + BMS intercooler + 93 oct fuel.
Default 03-23-2020, 08:30 PM
Email me Payam@burgertuning.com
Default 03-23-2020, 08:31 PM
Crazy how the IAT drops the more pulls you do, it's usually supposed to be the other way around. That's how you know this intercooler is working properly.
Default 03-24-2020, 03:16 AM
Until I stopped and let it heat soak a bit, temps were staying with 5F of ambient!
Does it look like Im safe to run map 3 on 93 oct, since I have the intercooler?
Default 03-24-2020, 08:53 AM
It looked okay from what I can tell. You might need to add some e85 when the weather gets hotter.
FlooF FlooF is offline
Car: Genesis G70 3.3T
Default 07-07-2020, 08:16 PM
So is this compatible with the g70 3.3?
