Originally Posted by JCB
JB4 without fuel wires installed/activated has no way to influence fueling. Even if the fuel wires were installed and malfunctioning to call for a very lean AFR it would show in the log under the fuelen field (just theoretical, I have not seen this ever occur in a log). I am always trying to learn more though. Can you post the log of your stock pulll where AFR looked good? Also link to the information about JB4 causing lean condition?
I cannot seem to get the file to upload at this time, so you'll just have to trust a stranger on the internet haha. As far as other forums discussing it, you can search 'JB4 AFR lean' or similar and you can find a few forums here and there discussing the possible causes, but nothing definitive for a solution. To me, it's reasonable that if my Map0 runs have no issue but Map1 leans out, and Map2 just a bit more from there, that my vehicle is unable to provide enough fuel when I use the JB4 to request more air. The reason for that is what I am not sure of, but I don't think it would simply be a fueling issue from the car if it behaves normally while stock. I'm hoping to get to the bottom of this so I can safely run the JB4 because most discussions I've seen around it have been nothing but rave reviews which is why I was excited to purchase and run it.
