Originally Posted by goldfz8
What size hoosier do you run? I got me a set of 265/40/17 hoosiers. im wondering if 15" rims would fit on a 135. These cars do 1.5-1.6 60ft on a good day and I feel like there would be much more potentential if we could get more rubber then rim. Im assuming you slip the clutch a good amount.
275/40/17 Hoosier DOT Drag Radial on Kosai K1 wheels. 2 step set at 3600 we do not slip the clutch at all, just dump it, and go. I have only got 2 runs in before my clutch went bye bye(3rd run I did slip the clutch hard, and it welded to the flywheel) new one is being put in, so far with only 2 tries, really bad shift points, slow shifting, with a 1.77 60 ft = 11.6 ET. Fixing the shift points, shifting better, and a harder launch we do not see a problem getting into the low 11's. This would be an easy 10 sec car with an Auto if it would hold and you could launch it.
