TTM5 TTM5 is offline
Car: M5
Default 07-13-2021, 04:27 PM
Engine is like new GTI and turbo remained the same as 248/252hp version. On 91 around 310hp and on 93 around 315hp or so on the 252hp version so the ouput should be more on yours.
U mentioned it uses the same turbo and the 12v does not add hp just spool, so wouldnt the power be the same as the 2020?
Moderator
Default 07-13-2021, 04:54 PM
In theory yes, in practice no. We will know more once its run.
2021 VW Golf 8 R
Car: M5
Default 07-15-2021, 11:27 AM
Does the 2021 q5 w/tune run 30psi psi of boost like the gti?
Car: M5
Default 07-18-2021, 03:34 PM
AFter or on this weekend.
Where is the dyno sheet george?
Moderator
Default 07-18-2021, 04:25 PM
Will post more information early in the week. Power at the wheels. Boost targets are similar to 248/252hp version.
2021 VW Golf 8 R
Car: M5
Default 07-18-2021, 05:24 PM
A stock a4 makes 261whp?
Moderator
Default 07-18-2021, 05:48 PM
Yes, was coldest run. Seems its under rated.
2021 VW Golf 8 R
Car: M5
Default 07-18-2021, 05:57 PM
How much whp does a 2020 make?
Moderator
Default 07-19-2021, 05:15 AM
I have seen 250 to 260whp. We havent had one on our dyno.
2021 VW Golf 8 R
Car: M5
Default 07-19-2021, 10:42 AM
George, jb hardly seems worth it for a 20hp gain on map2....
Moderator
Default 07-19-2021, 11:48 AM
Mapping is different on this, map 3 will be used for 93/94.
2021 VW Golf 8 R
Car: M5
Default 07-19-2021, 08:34 PM
Ok but even map3 30hp gain is not much, was expecting at least 50hp on 94 ....
Car: M5
Lightbulb 07-21-2021, 04:29 PM
330hp or so. Looking more into things it looks like the 262hp motor is closer to a Gen4 motor than a Gen3.
Looks like nowhere close to 330hp on 93/94, right?
Moderator
Default 07-23-2021, 04:49 PM
Thats more or less where it is if you factor correction from wheels to engine. If you factor in 15% losses it will be around 345hp or so keeping in mind the car is underated stock.
2021 VW Golf 8 R
Car: M5
Default 07-27-2021, 03:33 PM
What bhp does a 2020 q5 make vs 2021 @345hp on 93/94?
Car: M5
Default 07-30-2021, 12:41 PM
George, in other words, does the 2021 make more power than the 2020 on jb4?
Moderator
Default 07-30-2021, 01:13 PM
Personally I dont think they are any different.
2021 VW Golf 8 R
Mooglemd Mooglemd is offline
Car: 2018 Audi SQ5
Default 10-03-2021, 02:31 PM
I have the JB4 for my 2020 macan, I assume I need a new one if I get a 2022 Q5 right? This would be group 16? I have the group 6 one. Also You said the maps are different for this, I cannot find info on the new maps (what octane etc) for the new jb4, or is it the same as in the gen 3 thread?
Moderator
Default 10-03-2021, 03:45 PM
They have changed the sensor technology on the 2022 Q5 so a new unit will be needed and group 16 is indeed the correct one.
On this we using the following maps.
Map 0 stock
Map 1 and 2 can be used with 91
Map 3 for 93
From then and on you need to submit logs and we can work it up with a custom map.
2021 VW Golf 8 R
Car: 2018 Audi SQ5
Default 10-18-2021, 05:56 AM
Map 0 stock
Map 3 for 93
So they had no cars available for a while, so I ordered a Q5 55e. Any idea what box this engine would take?
Moderator
Default 10-18-2021, 07:57 AM
My understanding based on literature is the 2022 has a 261hp motor. They also added larger batteries to increase range.
Best bet though is once you get it we can look at the sensors and identify for sure which JB4 will be compatible.
2021 VW Golf 8 R
Car: M5
Default 02-10-2022, 12:31 PM
George, how much power can u make on 94 octane with a 2021 q5 now? I saw you made a lot more on the new GTI recently, which is the same engine more or less…
Moderator
Default 02-10-2022, 12:58 PM
We have not had a car on the dyno yet. The GTI uses a Garett turbo vs IS20 on Q5. I have done quite a few cars with custom maps and it should make around 10-15hp more than the dyno on our site. Waiting for summer temps to come around in order to get more data from users and we will amend the maps with a firmware update.
2021 VW Golf 8 R
Car: M5
Default 02-10-2022, 02:05 PM
On 93-94, how much whp will the gti make vs q5, no other mods only jb4....
Moderator
Default 02-10-2022, 02:42 PM
The strongest GTI we have dynod so far is 321whp. This had a intake though.
2021 VW Golf 8 R
