Default Infiniti Q50 3.0t VR30DDTT Red Sport and Silver Sport BMS Stage1 & JB4 - 05-08-2017, 02:51 PM
Order Link: http://burgertuning.com/infiniti_q50...nce_tuner.html
BMS data cable hard wired software and directionsClick here
Stage 1 Map Guide:
Map0: Stage1 disabled
Map1: Default performance map, 3psi over stock
Map3: Custom Target Map, select desired maximum boost over stock under "Boost Safety" user adjustment setting
All other maps and settings are unused
The idea behind the Stage1 is an inexpensive and easy to install/remove product that provides substantial gains with minimal headaches and trade offs. The Stage1 manipulates the ECU boost control signals allowing us to modify boost levels, but does not manipulate the ECU manifold boost reference, allowing it to properly map timing and fueling for the higher boost levels. The end result is something that runs as smoothly as stock only with higher boost targets under heavy throttle.
The Stage1 is not intended to provide the same maximum power gains you might get with a full custom ECU tune. Although based on today's dyno testing, the initial results for the Stage1 are still quite impressive. We envision a quick installation product that can be used with the factory tuning and even with aftermarket flash tuning for those looking raise boost a little in conjunction with higher octane via E85 or race gas.
For these tests we used a 30% E85 mixture, mixing in 5 gallons of E85 to a full tank of 91. Next round we will test 93 octane. With the stock tuning we were able to make ~320whp. We then used the Stage1 tune to test progressively higher boost levels, adding 4psi, 5psi, 6psi, and ultimately 7psi over stock. To my surprise each increase in boost resulted in a fairly steady increase in power, indicating plenty of tuning room within the platform.
Red Sport Dyno Results: http://www.n54tech.com/forums/showpo...6&postcount=82
Silver Sport Pump Gas Dyno Results: http://www.n54tech.com/forums/showpo...7&postcount=83
Silver Sport E85 Dyno Results:
How to connect and change map/boost level:
Quick directions:
1) Turn car on
2) Follow directions above to connect using either JB4 Mobile or BMS data cable
3) Once connected select map3 in drop down on logging page
4) Enter desired boost target on user adjustment page under boost safety and press save. Valid range is 0-8psi.
Stage1 user adjustment: Added option to adjust pedal to boost mapping using "Default Wastegate Position". Default value is 30, which represents 3.0psi. Below 3.0psi boost mapping is factory, above 3.0psi boost mapping is altered. Higher values may provide smoother but less powerful performance. When looking at your Stage1 logs DME BT represents the boost over stock. As you lower DWP you will hit your "over stock" boost target more quickly in the power band which may feel abrupt. If you raise it you'll hit your "over stock" boost target further up the power band which may feel smoother. If you raise it too high you'll never hit your full "over stock" boost target. During development we found 30 to be the best compromise set point and thus it's the default. It is now adjustable on map3. Probably best to avoid going below 10 or above 50.
Firmware:
There are no firmware updates for Stage1. DO NOT attempt to update firmware!
Ando @ BMS's Avatar
BMS Customer Service
Car: bmw 335i
Default 05-08-2017, 03:28 PM
Q50 Default Settings as of v9 firmware:
Firmware notes for posterity
JB4_VR30_OBDII_8:
1) Changed valet map from map4 to map8, changed WMI progressive map to map7, changed previous map7 race gas map to map5.
2) Adjusted ECO mode to force map8 VALET map when selected
3) Added communications to transmission to read gear, adjusted boost by gear to use actual gear instead of speed
4) Increased sampling rate of analog sensors for smoother performance
5) Enabled additional inputs/outputs for upcoming electronic wastegate (EWG) control.
6) Enabled boost control PID for upcoming EWG control.
JB4_VR30_OBDII_7:
1) Adjustment to fuel control mapping to add more fuel at higher RPM
2) Added support for BMS WMI kit under map8
3) Added linear pedal mapping option under FutureUseD Bit7. Turn on to smooth out boost targeting as a function of gas pedal input.
4) Added custom fuel mapping option under FutureUseD Bit1. Turn on to manually adjust "fuel enrichment" offset by RPM. Default values would be 50 across the board. Not suggested for most customers to play around with or touch this.
5) Fixed bug with false AFR reading during decel.
JB4_VR30_OBDII_6:
1) Added support for JB4 fuel control wires. To enable install wires to JB4 and set FutureUseD bit0 on. Once enabled you'll see "fuel enrichment" dynamically adjust in JB4 logs as it drives AFR up to the revised targets. Setting bit0 on WITHOUT the fuel wire will not negatively effect anything, but AFR readings in logs will not be accurate.
2) Added beep confirmation indicator when changing maps. Car should beep the number of map selected.
3) Added beep confirmation indicator when saving settings. Car will double beep when saving.
Q50UK Q50UK is offline
Car: Infiniti Q50
Default 04-05-2021, 09:17 AM
I recently updated to firmware v9 and duplicated the default settings as shown in the photo on page 1 with map 4 selected. Not sure which settings affected my car, but throttle response was limited to the point where the car would barely pick up speed with a lot of throttle input.
Any idea what could cause this condition, specifically which setting would cause this reduced throttle response? I have the 400hp version engine.
mikemike mikemike is offline
Car: Q 50
Default 04-05-2021, 10:18 AM
I'm new to this but I seen someone with this before and they had set the map to 0 then 1 then which ever map they wanted.
Car: Infiniti Q50
Default 04-05-2021, 10:49 AM
Thanks Iíll try this.
sky777 sky777 is offline
Car: Infiniti Q50 RS AWD
Default Logs Review - 04-05-2021, 11:24 PM
Hi Terry, could you take a look at my logs? wondering if running Map 1 & 2 is good and if I can safely run Map 3 on the RS? I'm at a high elevation 3,500 ft and have decent 94 octane (no ethanol) gas. Thanks for your time!
2018 Q50 RS AWD - Electric Indigo
JB4 w/ Fuel Wires
Megan LDP
BMS Elite Heat Exchanger
aFe Power Magnum FLOW Pro DRY S Air Filters
Z1 2 Piece Akebono Front & Rear Rotor Kit
Konig Ultraform 19x9, 35 offset
Car: Q 50
Default 04-21-2021, 01:43 PM
Originally Posted by Q50UK
Thanks I’ll try this.
Did this ever happen again? I had something like this happen the other day and what I noticed was my intake temp was 160..I'm in Florida so it's hot. I had removed the front intake cover because it sounds nice without it but I was obviously getting heat soaked. With the cover i do get 130/140 mostly in traffic/city driving in open road is around 95. And that limp mode seems to hit around 160.
Default 04-06-2021, 11:56 AM
No setting should cause that, maybe have a fault code stored? Log of issue?
SilverRS SilverRS is offline
Car: Red Sport 2020
Default 04-07-2021, 05:42 AM
Do you step on it and nothing? On your JB4 set the gauges to show pedal and throttle. When this happens does your pedal go to 100 and throttle jumps to 100 then down to 26? Or throttle just never goes to 100 but stays mid20's? If so, several people are experiencing this. Still no explanation. I gotta get some logs uploaded here to show it happening. I almost exclusively drive in manual now and I do see that in 1st and 2nd my throttle rarely goes to 100.
2020 RS RWD
JB4
EWG and Fuel wires installed
Previous Q's
2018 RS RWD
2015 Q50 Premium
dingo6610 dingo6610 is offline
Car: 2017 Infiniti Q50 RS400
Default Log from yesterday - 04-09-2021, 05:17 AM
Hi Terry, hoping you can take a look at my log.
JCB JCB is offline
Car: 2018 Q50 3.0t
Default 04-11-2021, 06:48 AM
Not Terry, but I think your log looks fine. Timing (Ign1) drops a little low at mid-range. You may want to back off a bit, maybe top out at the 4.2 on your map6. Also think you don't need to taper quite so much on the high end. So maybe look to add .5 to your values after 6k RPM. The stock JB4 maps taper but to less extent. You also would gain a little at high end with fuel wires. If you have them hook them up.
Mike_L's Avatar
Mike_L Mike_L is offline
Anti-Social
Car: 2021 M550i xDrive
Default 05-08-2017, 06:39 PM
Gotta wonder what the Red Sport would do, or if the mechanicals are any stouter.
Mike Levy
2022 Black Sapphire X3 M40i
Default 05-09-2017, 10:25 AM
I hear it's roughly the same but with more aggressive tuning from the factory. But, looking forward to testing one in person one of these days.
houbmw houbmw is offline
Car: BMW n52 530i
Default 05-09-2017, 05:20 PM
https://onedrive.live.com/?authkey=%...211594&o=OneUp
https://conceptzperformance.com/blog...turbochargers/
differences between the 2
Mike_L's Avatar
Anti-Social
Default 05-09-2017, 06:32 PM
Based on what I'm reading, theres not all that much more in that motor as delivered. The turbos seem to be extremely small, and the way they're designed, a swap is not gonna be easy. Wonder if the heads and manifolds from the GT-R will swap, as that would make upgraded turbos much easier.
Still think I'd stick with BMW and the B58 or upcoming S58.
Mike Levy
AUbeast86's Avatar
AUbeast86 AUbeast86 is offline
Car: 2007 335i e92 Coupe
Default 05-11-2017, 10:27 AM
Those days are here
BoostedSlvrSport BoostedSlvrSport is offline
Car: 2019 3.0 Silver Sport
Default Who can I send my JB4 data log files too? - 04-02-2019, 07:30 AM
Hi All , I am new to this community and recently installed my JB4 on my 2019 Silver Sport. I have a few logs that I would love for someone to review as I have some boost concerns. If you could point me in the right direction much would be appreciated. -thanks man
As a side note, is there a place where I can find a comprehensive explanation of all the features of the JB4? I would like to understand my own logs and what is happening to the car.
Lastly, any shops in North Jersey anyone could recommend for Dyno and tune on the JB4.
Bigjhouse Bigjhouse is offline
Car: 2016 q50 vr30
Default 04-02-2019, 08:09 AM
Terry, can you checkout my log, quick map 7 pull on around e30
Car: q50
Default 04-02-2019, 10:43 AM
Just a heads up, within the next few weeks I'll be doing a cheap LSD upgrade on the RWD model. I'll post up my install pics and impressions. Much cheaper than Z1/AMS. Stay tuned.
Default 04-02-2019, 02:18 PM
Need the orignal CSV to open it in the JB4 windows interface.
40Rolls 40Rolls is offline
Car: 2018 Q50 Silver Sport
Default Map 2 Log - 04-03-2019, 10:27 AM
Terry could you take a look, first logged map with JB4. 18' silver Q50 rwd, ams down *****,93 oct, fuel wires, map 2 & manual 3rd to 4th pull
Default 04-04-2019, 09:20 AM
Just post the logs here if you want us to check them out.
While we're not in the training to read log business, but there some threads around you can get the basics from if you want to start learning.
Car: BMW n52 530i
Default 05-09-2017, 04:11 AM
WOW...thanks for the introduction to this platform.
1) Is the red sport a twin turbo compared to the 3.0 Premium being a single turbo? If you can, could you explain any major differences between the 2 models...from what I have read, the RED SPORT has extra intercooler I think.
2) Is the stock exhaust system extremely restrictive? I have seen on q50 and q60 forums that some companies are getting 20+HP and torque with just exhaust mods.
3) How is the transmission handling the power? I have a 3.7 2015 Q50 and it is a beast, but the transmission is horrible. I wish they had put the ZF 8 speed in it.
4) When you are adding boost to the 3.0 premium, how much is the stock boost...7psi? So when you adding 6 or 7 lbs of boost, total is 14/15lbs of boost...thats seems to be about what the Red Sport is pushing stock.
5) My lease ends in September and I am looking this month to get into a new Infiniti...It looks like it is better to get into a 3.0 instead of a Red Sport because of the optical sensors in the turbos. Would you state that tuning and modifications wise, 3.0 engine is better than the red sport?
Thank you again...I am looking forward to working with yall!
Lowon's Avatar
Lowon Lowon is offline
Car: Bmw M2
Default 05-09-2017, 07:51 AM
This is pretty crazy good job guys!
Mods: Stock for now
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 05-09-2017, 08:34 AM
Wow 90WHP was that easy? Looks like the days of walking Infiniti's is coming to an end.
