boh boh is offline
Car: 2018 Q50
Default 2020 Supra? - 01-14-2019, 05:51 PM
Am i the only one wondering if Burger Tuning is going to jump into the new Supra market?
Input? Thoughts?
-boh
Default 01-14-2019, 06:39 PM
Yes we're ordering one for R&D. Although, it looks like its mainly a BMW Z4 with a Toyota badge.
Car: 335i, 2009
Default 01-15-2019, 10:14 AM
If I am not mistaken the engine is a BMW version of the B58, which probably has some variant of the same ECU in the current B58. I would imagine all that would be required would be new firmware and potentially different connectors to be compatible. Can't wait to see results! Should be easier to hit strong WHP numbers with a slightly raised fuel table from the factory.
JB4 ||| H&R Sport Springs
X5 50i 2013 ///M Sport
BMS Stage 1
Default 01-15-2019, 11:15 AM
We'll have to see what has been changed when released, but we're hoping to get a ton of power out of it with the Supra JB4!
tonyng92 tonyng92 is offline
Car: 2015 m4
Default 08-05-2019, 12:19 PM
Any update on the jb4 for the Supra? expecting to pick mine up very soon. Would like to continue using jb4 in the Supra.
Default 08-05-2019, 04:50 PM
We have a loaner car coming next week I think, and I expect we'll have a JB4 released for it shortly after that.
luchocamp's Avatar
Default 08-14-2019, 06:22 PM
time to make a new category
Supra ...
18 BMW XXXX Car in Process
Mike_L's Avatar
Mike_L Mike_L is offline
Anti-Social
Car: 2021 M550i xDrive
Default 08-14-2019, 06:40 PM
Nah, no new category required. It’s just a B58.
Mike Levy
2021 Tanzanite Blue II M550i xDrive
2018 Silver Equinox LT 2.0T
luchocamp's Avatar
Default 08-14-2019, 06:59 PM
1 month out, runs 10sec 1/4 mile
luchocamp's Avatar
Default 08-15-2019, 03:13 AM
after saw 10.79@128mph with 1.64 on 60ft and 102.6mph at 201mts yesterday from tpg tuning ... my question is how could you make 128mph trap with less than 520whp .... or they remove 300 pounds ..... or the real Q it was 75 or 100 shot to be the first into 10s ?
anyway the New Supra makes 1.64 with 305 MT with ZF8hp almost same as M3 or M4 dct.
alexis485's Avatar
alexis485 alexis485 is offline
Car: 2011 BMW E92
Default 08-15-2019, 05:37 AM
A stock turbo 335is with 495whp did 11.0s @126mph and it weights about 200 to 300 pounds more than the Supra so, the 128mph trap speed make sense to me.
https://www.n54tech.com/forums/showt...ght=boostninja
2011 E92 ABR N55 Built Motor | ABR Built 6AT | Big Boost 3.4 Turbo Kit | JB4 + MHD | xPH Stg3 Flash | Fuel-It Stg 3 LPFP | Fuel-it PI Kit | COBB Exhaust | E85 |
luchocamp's Avatar
Default 08-15-2019, 09:11 AM
I saw that post, 11.16 @ 126mph
Over a 40 improving parts
Weight reduction -180lbs
DCT transmission
Better DA ...
We are talking 10.79@128mph only with **, tune and two tires ....
Car: 2015 m4
Default 08-28-2019, 03:07 PM
Any update?
Default 08-28-2019, 04:37 PM
Originally Posted by tonyng92
Any update?
Yep:
Supra Burger Motorsports, Inc.
luchocamp's Avatar
Default 08-29-2019, 03:07 AM
I will order one and see when the first Supra arrives to Dominican Republic ... so we got 50% of equation solved
Car: 2015 m4
Default 08-29-2019, 08:12 AM
awesome! any dyno result from the supra? the link is showing the supra jb4 but the dyno are of 340i.
Default 08-29-2019, 09:42 AM
Just a couple customer dynos so far. 330whp baseline, 390whp map3 on pump gas. He's going to push it harder on the dyno next go around I think.
Car: 2015 m4
Default 08-29-2019, 02:18 PM
WHat kinda number you think i can get with stage 2 and d p?
Default 08-30-2019, 10:07 AM
Had a Supra customer do a dyno run today on the existing map3, pretty good results.
luchocamp's Avatar
Default 09-06-2019, 06:42 AM
How about E40 with WMI ....
luchocamp's Avatar
Default 09-06-2019, 07:11 AM
It's not same B58 from 2016-2019
Supra is a going to be a better market than Infinity, Kia, Ford, Mini and Honda...
Default 09-06-2019, 09:29 AM
We setup unique firmware for the supra as it's better with more boost than the bmw version for some reason. Maybe turbo is a bit larger?
luchocamp's Avatar
Default 09-13-2019, 03:33 AM
with Pure Turbo upgrade, no NOS
93oct 630whp
VPMS109 670whp
RKTunes .....
luchocamp's Avatar
Default 10-01-2019, 06:43 PM
any update ...
absaifan absaifan is offline
Car: Supra 2020
Question 10-18-2019, 01:59 PM
I just installed mey JB4 today, I can see terrific response increase and positive boost feel, but from the maps I see boost drops significantly (4-5psi) after 5000RPM, specially on maps 1 and 2, it drops less on map 3 but still does.
I attached both 5th gear runs on Map2 and Map3 files here, appreciate BT review and feedback.
K&N drop in filter, and everything else is Stock.
