Car: 08 535i
Default 05-10-2017, 02:31 PM
Time for some more updates......
A/C
No A/C line = a lot more room....
Last shot of cooling
Gone.....so much room.
29.5" of room.....hood closes just fine.
Initial relocation..... no good.
Mocking up a new bracket. This is from the NMP RELOCATION kit..... also mounting the washer fluid hose here.
Cut part of the oem bracket for washer fluid
Washer fluid cap
I used various clips and bolts from removed parts or parts laying around like this.
attached to bracket....
Installed
I have many more pictures to upload but have to get back to other things......stay posted.
Car: 08 535i
Default 05-10-2017, 03:36 PM
Bracket And final instal pics...
Finalized before paint...
Installed...
Foam pad for protection...
Hose set up.
Next up was praying the a/c line that was made for me fit.
It's going to be close....
Whew!
Canister
Rear intake pipe on. Getting messurements for Y
Modified MMP intakes to fit Y pipe.
Front intake on....
Y pipe
Ryan
Car: 08 535i
Default 05-18-2017, 10:56 PM
I have plenty more pictures to upload but have not had the time.
Here is my current situation. Any advice
I just fired up my 08 535i from installing hotside intakes. The car is still in the air and it started right up on first push. It ran fine at idle for about two minutes, then I started revving it and the first few light revs were fine. It came back to idle just fine with no indication of any problems. Then, I opened up the throttle and heard a pop. The car went into reduced power with DSC/DBC/ABS faults and threw codes P1633 (Throttle Valve Adaptation: LimP-Home) & P1417 (Throttle Control Incorrect Air Supply). The revs just bounced from 1000-1500 rpms.
I figured the intakes popped off, and I was correct. I re-installed them with clamps this time and fired the car up. The car is still in limp mode with all the braking errors.
DanL DanL is offline
Car: 2010 535i M Sport
Default 05-19-2017, 05:51 AM
You cleared the codes and they came back? Battery charged? Also, I'm assuming you installed the charge pipe locking clip at the throttle body. Looks like it's missing in the earlier pictures.
2010 535i M Sport - Platinum Gray/Dakota Black/Anthracite Bamboo
Premium, Value, Cold Weather, Sport Auto, Navigation, Satellite, Logic 7, Comfort Access, Park Distance, Fold Down Rear Seats, Heated Rear Seats, Rear Side Airbags, JB4 G5 ISO, BMS DCIs, ER Charge Pipe, Proform Clear Bra, LUX H8 160 LED angel eyes
Car: 08 535i
Default 05-19-2017, 08:20 AM
Yes I cleared them through torque.
The battery may not be fully charged and am going to charge it today.
Yes the locking clip is in place. And all piping is secure.
I'm sure it is something simple....will the car stay in limp mode if the solution was fixed or does it need to be told to get out limp mode?
NoQuarter NoQuarter is offline
Car: 2008 535xi
Default 05-19-2017, 10:41 AM
It will clear itself on a restart.
Car: 08 535i
Default 05-19-2017, 04:30 PM
Ok, that makes me happy.
The battery is completely dead so it is time to have it tested and charged or replaced. Then we can resuming trouble shooting. But I think this will resolve it. I mean I am hopeful this will solve it.
Car: 08 535i
Default 05-20-2017, 09:18 PM
Issue solved! car runs like a champ with the new intakes, or should I say idles like a champ. Ill drive her tomorrow.
See this post for a reference to the solution.
http://www.n54tech.com/forums/showthread.php?t=46985
ferocious's Avatar
ferocious ferocious is offline
Car: 335i N54 2008
Default 05-21-2017, 12:03 AM
Good Job!
2008 335i N54 FFtech Top Mount single turbo Precision 6266
JB4 G5 , VRSF 7" FMIC , VRSF CP + TIAL Q50 BOV, Tial Wastegates
BMS METH KIT , PURE M1 METH,TMAP 3.5,
FUEL-IT STAGE2 BUCKETLESS LPFP, RB PCV. JB4 MHD BACKEND FLASH, xHP Stage2 v3.0
more to come...
Car: 08 535i
Default 05-21-2017, 09:05 AM
Originally Posted by ferocious
Good Job!
Thank you!
Car: 08 535i
Default 05-21-2017, 04:32 PM
Cleaning things....
Car: 08 535i
Default 05-21-2017, 09:13 PM
Took off the ******** brackets.
The rear intake clamped on...
New heat sheild with OEM solenoid bracket...
Modifying....make sure to keep two bolt holes. See my mistake.
Test
Mounted
Car: 08 535i
Default 05-21-2017, 09:17 PM
A few almost finished pics. Have a few more things to button up.
Ryan
Car: 08 535i
Default 05-21-2017, 10:33 PM
I plan to repair my leaking dynamic drive sways. But have thoughts of completely removing this system. I feel like having solid sways will eliminate one more thing that can go wrong as it currently did.
I plan to remove them, clean them, reapply new sealant to the boots and re-install. Not sure if this will work, but it beats paying $1800 for a new sway bar. For that price tag it has to be less expensive to remove the system.
Pump
Ryan
ferocious's Avatar
Car: 335i N54 2008
Default 05-22-2017, 03:44 AM
Ryan, i think that air filter is a bit small for reaching high psi goals, comparing it to BMS DCI and AFE
don't you think it will starve the car on long pulls
Joe
more to come...
Car: 08 535i
Default 05-22-2017, 07:59 AM
Joe
Yes I do,
I bought this filter and intake set up for test fitting purposes. I will be installing a RB EVO intake kit when I replace the turbos. Ordering them today.
ferocious's Avatar
Car: 335i N54 2008
Default 05-23-2017, 01:06 AM
yep
i have seen RB EVO intakes
they are right on the money
more to come...
Car: 08 535i
Default 06-15-2017, 02:36 PM
Plasti-dipin' the grills.
Turner stickers
Last edited by rkreimer10; 10-03-2017 at 12:04 AM.. Reason: Photobucket posted wrong picture
y0itzflip y0itzflip is offline
Car: e60 535i
Default 06-16-2017, 05:38 PM
nice to see another e60 guy. engine build is coming along great. gonna keep an eye on this thread. keep us updated!
Car: 08 535i
Default 06-24-2017, 08:18 AM
Thank you! I will have more updates soon!
Car: 08 535i
Default 06-24-2017, 08:21 AM
What I woke up to this morning!
Car: 08 535i
Default 06-29-2017, 10:14 PM
Well my time with photobucket has come to an end unless I pay. Going to be a bit till I fix these links. So inconvenient.
Car: 08 535i
Default 06-30-2017, 10:15 AM
So I have a lot of picture resizing to do. Lol.
Car: 08 535i
Default 06-30-2017, 02:04 PM
A tool I want
Car: 08 535i
Default 06-30-2017, 02:44 PM
Imgur failed. This sucks. So much time lost cause of photo bucket.
