(#4751)
bcstinger3 bcstinger3 is offline
Car: Kia Stinger GT1
Default Possible issue - 01-26-2022, 12:19 PM
Hi Terry,
When you get a chance please take a look at the attached log. Took the Kia out for a quick spin on a back road and noticed some hesitation or studdering. Does this mean it is time for new spark plugs or is there something else going on like bad gas?
Map 2
Denso sparks plugs with an estimated 15K - 20K on them.
Around 40 degree day
Thanks,
Default 01-26-2022, 12:36 PM
Looks like no boost on that run. Not sure why, did you get a fault code?
Default 01-26-2022, 05:55 PM
No I didn't see any error codes. I will take it out again tomorrow and see if it does it again
Default 01-26-2022, 07:44 PM
Hi Terry,
Took the car out again tonight to see if it would do it again. Filled the tank up with 93 gas prior then attempted to do a couple full throttle runs in sport mode. See the attached spreadsheet. This time it threw a check engine code on both attempts but I was only able to read the code on the second attempt. It threw an P0306 code which from a quick search shows that it has a misfire on cylinder 6. Please take a look at the attached log and let me know what you see.
Thanks in advance.
Default 01-26-2022, 09:10 PM
Originally Posted by bcstinger3
Hi Terry,
Thanks in advance.
Looks like logging stopped also when it misfired. What date was JB4 shipped from BMS?
Default 01-27-2022, 07:33 AM
8/9/2019 shipment date
What do you recommend I do from here?
Chrismack22 Chrismack22 is offline
Car: 2019 Kia Stinger GT
Default New install with two map2 logs - 01-27-2022, 01:55 PM
Here are my first two logs on map2. I have intakes,fuel wires, and 93. Just want to make sure everything looks good.
paulcosg70 paulcosg70 is offline
Car: 2021 G70 3.3T AWD
Default 01-29-2022, 08:13 AM
Would you mind taking a look at the attached logs and let me know if you see anything out of the ordinary map 3, E30. Thanks.
Default 01-29-2022, 02:26 PM
Seems good to me
Default 01-29-2022, 02:27 PM
Pretty normal for 93. Maybe try a different station next time as octane looks closer to 92.
Default 01-29-2022, 02:28 PM
Order a 2580 off our site or send in your board and we can reflash it for free. I suspect the low level firmware on the 2580 is causing the issue.
ereed91 ereed91 is offline
Car: Kia Stinger GT2
Default LOG HELP - 01-30-2022, 08:21 PM
I have attached my log onto this post in hopes of someone helping me out making sure everything looks good, i was running MAP3 and i posted a log and someone said just to do MAP1 so i ran another log on MAP1, if anyone can help me out it would be much appreciated. My mods are just an intake and tune with new denso spark plugs gapped at .022. Log is compressed to a zip file because of the size.
phil000 phil000 is offline
Car: Kia Stinger 2018 GT1
Default 01-30-2022, 10:07 PM
I'm very new to anything with any amount of power
Thanks for your reply!
Web9 Web9 is offline
Car: 2020 Veloster N
Default Help with stutter issue on JB4 - 01-31-2022, 10:57 AM
Hi, I have a 2020 Hyundai Veloster N - the only mods are a AEM CAI and a mid-pipe. Everything else is stock including the spark plugs. I installed the JB4 about a week ago and set it at Map 1 and didn't change any other parameters. I only intend to run 91 oct and so it will always be on Map 1.
Anyway, it seemed fine for the first four days of short drives (back and forth to work), even at WOT. Then suddenly it started stuttering / cutting power when 75% - 100% throttle was applied about 3000 rpm or so. It is pretty violent when it happens and doesn't feel like a rev limiter, etc. There are no codes or MIL on the dash though.
I did re-check the installation and the video at https://burgertuning.com/collections...ia-stinger-jb4 appears to be incorrect for the fuel wire. After re-reading the instructions, I moved it to position 2 (white wire). The wording makes it sound like the fuel wire isn't even used for map 1?
So I re-logged again in Map 1 and then Map 0 and the stutter continues to happen. I then disconnected the JB4 completely (MAP, TMPA and OBD) and the stutter disappeared completely. Any ideas on why it would happen even on Map 0 which should mean the JB4 is disabled? Any help is appreciated. Logs attached.
Default 02-02-2022, 11:57 AM
What fuel? Log looks like 87 octane lol.
Default 02-02-2022, 11:58 AM
Turn on option bit0 to disable fuel wire control and lets confirm its related.
SIKG70 SIKG70 is offline
Car: G70 3.3 RWD
Default G70 RWD 3.3 MAP 2 - 1ST LOG - 02-02-2022, 01:15 PM
1st log after installing the JB4, can you check and see if we're OK?
MAP 2
12 GALLON CA 91+ 4 GALLON E85
Car: G70 3.3 RWD
Default G70 RWD 3.3 MAP 3 91+ E85 - 02-02-2022, 01:19 PM
Can you check this one over, want to make sure I'm not gonna blow anything up.
I started in map 2 doing some draggy runs and switched to MAP 3 for the very last run.
Default 02-02-2022, 03:27 PM
Thanks Terry. So enable Bit 0 and leave all other option bits (1-7) disabled and then re-log?
khancerto's Avatar
khancerto khancerto is offline
Car: 2020 Hyundai Elantra Sport
Default 02-04-2022, 07:27 AM
Hello! I need some logs looked at. Did a lot of pulls from a dig in maps 3 and 4. E30 blend or close to it at least. I have EWG wires installed as well.
2020 G70 3.3TT AWD
HKS M45IL Plugs
ThePower777 ThePower777 is offline
Default 02-06-2022, 01:38 PM
Just installed JB4 on my 2018 stinger gt1. I used 93 octane gas and did some pull ups on map 1 and 2. Still using factory air box and plugs.
Terry, could you please check if anything look at wrong and if I can use map 2 before replacing the plugs?
TIA
Default 02-06-2022, 05:44 PM
Looks fine to me!
Default 02-06-2022, 05:45 PM
Correct
Default 02-06-2022, 05:46 PM
Boost, timing, AFR all seem fine on map4.
Default 02-09-2022, 07:08 AM
Terry, could you check my logs as well. Just wanted to make sure everything works fine:
https://www.n54tech.com/forums/showp...postcount=4770
