Car: 08 535i
Default Ryan's e60 LCI 535i build thread - 04-20-2017, 08:55 PM
MUST USE GOOGLE CHROME TO SEE PICS
HI all,
My name is Ryan and two months ago I purchased a bone stock, dealer maintained, 08 535i. The car has 150k miles and known wastegate rattle. The car runs well for what I am familiar with so far. I am still learning and plan to do various modifications based on personal preference and function. I usually do not post DIY's or build threads, but with not a lot of stuff out there for the 5 series guys I really want to help. Especially for the help I have already been given. Please feel free to ask questions and comment, but I have to warn you I am very busy and do not participate online everyday. I am going to try to do a series of "video DIY's" and post them here for reference. I do not really have the time to do write ups, plus videos might be easier to understand. I hope I can follow through with this and help bring more information to the 5 series community.
Now onto the build. Sunday I will be starting the process of:
-Replacing bad oem turbos with VTT oem replacements
-Boost monkey charge pipe (no leaks, works great)
-TAIL Q w/ 10psi spring (need to tap intake manifold for 7/32 vacuum)
-Custom silicone intake relocation from MPP (they do not know I'm about to hack up their 3 series products to fit the 5 yet)
-Relocate canisters(done, but need to be cleaned up. Possibly switch to one canister)
-Relocate cooling expansion tank
-Install Godspeed Intercooler for e90
-Relocate A/C suction line to cold side
-Various hose replacements
-Amazon (BMS) Catch Can
This is what I am going to be starting no later than Sunday. There may be additional projects that take place once I start getting into things. A few may include:
-DSC relocated to the M5 location
-VRSF *********
-Walnut blasting (will also tap numerous vacuum ports at this time.)
-black out headlights
-plasti-dip wheels, grill, and interior trim
-replica Mtech body kit (suggestions???)
-Find Solution for leaking sway bar
As soon as I know how to post pictures I will share some of this gem I found....
Car: 08 535i
Default 04-21-2017, 09:27 AM
Picture test.....
olabje olabje is offline
Car: 335i E91
Default 04-21-2017, 09:29 AM
failed
FBO 335i N54 WAGON
Pure Stage 2 Turbos
Port Injection
Stage 3 LPFP
E85...
Car: 08 535i
Default 04-21-2017, 09:49 AM
Car: 08 535i
Default 04-21-2017, 09:55 AM
There we go.... now just waiting for pictures to upload to photo bucket and I can get this thread started.
Stayed tuned......this project is going live as soon as I finish my 8 page research paper on why fracking is bad for our environment. Can't wait till that is over so I can go remove the emissions from my car. Hahaha
audiophool audiophool is offline
Car: '08 535xi
Default 04-21-2017, 12:23 PM
Subscribed.
You'll spend a lot of time messing around with Photobucket - that site is so loaded with adware and bloat that each time I log in my Mac heats up and slows to a crawl.
Car: 08 535i
Default 04-21-2017, 12:45 PM
Originally Posted by audiophool
Subscribed.
What do you suggest? I'm using the app from s7.....i want to be able to load photos right from my phone.
Car: '08 535xi
Default 04-21-2017, 03:07 PM
I still use Bot-oPhucket, but only for pix I want on forums. There are probably better places out there that suck less.
Car: 2010 535i
Default 04-21-2017, 03:21 PM
Just use imgur like a regular person.
Car: 08 535i
Default 04-21-2017, 03:30 PM
I don't want to be a regular person.
But I will check out imgur
Thank you!
Car: 08 535i
Default 04-21-2017, 03:49 PM
A few more pictures of when I got her.....
Stock engine bay......not for long...
Most of the goodies.....
Charge pipe and fake tial.....fake tial caused vacuum leaks..
Garbage......
Real Tial Q with 10psi spring intalled....no more vacuum leaks.
Here is the charge pipe I am using from Boost Monkey.
Air canisters before.....
After.....
Back to homework.... fun stuff...
Car: 08 535i
Default 04-21-2017, 04:02 PM
Where the magic is going to happen!....
Ok....now back to homework.
JuniorB JuniorB is offline
Car: 2007 e60 5 series
Default 04-21-2017, 07:11 PM
Good luck with the build, the dsc mod is a great choice, I may end up doing the same, same with the m5 diff swap. I just need to know 100% if you can use the 335 Dee pipes, along with e90 mids...
Car: 08 535i
Default 04-23-2017, 08:36 PM
I think you need 535i specific down pipes. Not too sure yet, have not evolved to exhaust yet.
Car: 08 535i
Default 04-23-2017, 08:59 PM
Going up on stands.....mounting the new intercooler
Still stock....
Getting closer, seeing what all had to be cut and removed.
Passenger side trimmed
Driver side trimmed
Front view with oil cooler re-mounted....
Bracket mounts did not line up so I had to get creative.
I used a mounting plate for an exterior light to make a bracket.
Cut in half...
Attached...
Other side before.....
Trimmed...
Installed.....
I plan to do a write up on exactly how to fit this Godspeed intercooler for an e90 in an e60. So stay tuned. I only paid $250 shipped for this intercooler.....
Ryan
christoepurrr christoepurrr is offline
Car: E60
Default 05-02-2017, 01:17 PM
subscribed for updates
Car: 08 535i
Default 05-02-2017, 01:52 PM
Black and white:
All the removed parts so far....
Deleting this hard line:
That went between here
And going to delete this too...
Removed
Going to replace this vacuum line
Removed
Going to reuse oem ends
Playing around with ends and options...
Last edited by rkreimer10; 09-27-2017 at 10:28 PM.. Reason: [URL=http://s32.photobucket.com/user/rkreimer101/media/Mobile%20Uploads/20170426_144807_zpsgcq4euwj.jpg.html][IMG]http://i32.
Car: 08 535i
Default 05-02-2017, 08:41 PM
Booster line
Starting to put the rest of the brake booster line
Moving along...
Complete...
Installed...and hidden
New solenoid set up....
The other vacuum hard line that goes into the fender.. this comes from the module that eventually plugs into the throttlebody
New oem end installed.
Installed...
A/c line protected and the coolant lines in oem bracket.
Bracket cut and sealed with gasket maker.
Ryan
BrownPower's Avatar
BrownPower BrownPower is offline
Car: 2008 535i
Default 10-06-2017, 10:52 PM
[QUOTE=rkreimer10;535632]
Located in Toronto
Cars:
2006 Saab 9-3 Aero 335whp+390wtq
2008 BMW 535i; JB4, MHD PUMP BEF, DCI, VRSF KOTLESS, ER CP TIAL BOV, RB PCV
Car: 08 535i
Default 10-07-2017, 09:49 AM
[QUOTE=BrownPower;562473]
This is fuel tank breather line that plugs into the fuel tank vent valve, which plugs into the throttle body. Here is where it plugs into the sensor.
Car: '08 535xi
Default 05-02-2017, 09:01 PM
Looks nice, but are you sure heater hose will stand up to vacuum?
Car: 08 535i
Default 05-03-2017, 03:13 PM
Thank you!
99% sure. I will be replacing everything with vibrant hoses when I replace the turbos. This is just the initial mock up. I'm sure the vibrant hoses will withstand better pressures.
Default 05-05-2017, 02:48 AM
I also have my bumper off and looking at the space were the dcs pump and the coolant overflow is. Removing the pump is going to be a massive amount of work with the motor in there, and scoping the parts used will be a man hunt, but it's a nice clean mod when done. If the tank was relocated, it looks like a ram air inlet could be fabbed using a m5 duct, that would be a nice mod. I'm planning my n54 swap and reading all the e60 mods that guys are doing. Evan has a great write up on his car, one of the cleanest, and hope to see how yours come out. Good luck with her!
Car: 08 535i
Default 05-07-2017, 06:28 AM
I am working on a way to relocate the dsc without hacking up your oem hardlines. I have been studying Evan's thread ever since I found it. I just fit the rear intake on last night before I called it quits..... hopefully she will be running today soon can start the turbo swap. I also plan on using some of the m5 ducting for my intake.
Car: 08 535i
Default 05-07-2017, 06:36 AM
So Thursday I saw the light at the end of the tunnel and planned on getting the car fired up......then this happened....
Working on getting more pictures up.
