Hierlevelz Hierlevelz is offline
Car: 09 E90
Default Swift spring Coilover conversion ? - 05-14-2014, 10:46 PM
Those of you that have done the swift spring conversion, did you reuse the lower spring pad? Harold from HPA specd me out a rear set of height adjuster with 65mm spring and spring adapters. I was told that the adapters go above and below the spring. But it doesn't seem right to use adapter in conjunction with oem lower spring pad. Fitment doesn't look right to me. I installed the springs and adapters without lower spring pad. But I'm starting to second guess my install.
