Originally Posted by Nanometer
You are going to actually get worse mileage actually with the Michelin tires. Run flats are stiffer, and thus they have less compliance losses. This means that they don't soak up the bumps as well which is good maintaining energy of the car's momentum. This is also precisely why soap box cars use hard rubber tires and not soft, not the best comparison, but you get the idea. And the Michelin tires have a higher rolling resistance due to adhesive and cohesive forces, both of which reduce your mileage more. This is all in the interest of high grip and performance.
Agreed on your points, but seems that the unpsrung weight decrease, which is huge, might more than offset any additional higher rolling resistance due to stickier tires.
