BTMFR's Avatar
BTMFR BTMFR is offline
Default N54 single turbo - 12-05-2013, 07:42 PM
Ever since I bought my 335i I have felt the need to make it go faster. First it was a simple tune a jb3 which I ended up upgrading to the jb4, then the jb4 iso, and then jb4 g5 iso. At the same time I went from tune only to meth and then onto my pursuit of using E85 with a FBO car. For a long time I considered RB turbos and even though they are a great product I decided I was ok sacrificing response in the name of more power. So I started looking into single turbos. I knew exactly what I wanted, and that was a 6466 top mount twin scroll. I wanted the 6466 for relatively good spool (combined with the twin scroll) and also because it produces very good numbers compared to turbos in its same size category. Looking at other platforms it seems to be the right choice for the power I wanted to make which is 600whp on pump and once the HPFP issues are solved around 750+whp on E85 depending on how the motor ends up responding to that power. I knew what I wanted and all I needed now was to see how I was going to get there. Just so happens a friend of mine is a fabricator and owns his own shop caller KSR Performance and Fabrication. https://www.facebook.com/KSRPerformanceFabrication He build all kinds of awesome stuff on a day to day basis and his work is amazing. When I told him about the project he jumped right on board and this is the outcome. The project is coming together nicely and I just wanted to share some pictures of the progress. It will be another month before its done. The ********, turbo to intercooler pipe, 4" exhaust, and trans swap all have to be done still but i just wanted to share progress.
dropping the car off
got the parts in
more parts
pulling her apart
some room in there
awww yeah thatll fit
flange and some runners
some preliminary calculations
that moment when an auto just wont do it
needs a clutch right? clutch masters twin disc fx 850
wow these things are small
this isnt...
starting the manifold
oh hello there
mounted needs a filter...
thats better I am going to make a better intake eventually...
all done top mount twin scroll single 44mm mvr tial wastegate
O2 sensor j style bungs may switch to standard heat syncs depending on how well these work or dont
ill have to get a better picture but the wastegate is fed by one pipe that has been plasma cut in half and a divider has been welded into place to keep the exhaust gasses completely separated all the way up to a clearance of 1/16 of an inch to the wastegate valve
Thats all folks. I will update when I have updates...
iuhutch's Avatar
iuhutch iuhutch is offline
Car: 2011 e92 335xi
Default 12-05-2013, 08:11 PM
Holy jeez I just got a hard on! What a piece of work, keep us posted on your install and tuning. God damn that turbo is huge lol
mjmarovi mjmarovi is offline
Car: '09 335i coupe
Default 12-05-2013, 08:22 PM
Looks good man, a little different than FFtec's kit. Is that not stainless steel? Do you plan on coating it?
2014 2500 Cummins- Pretty much everything.
09' Single Turbo 335i SOLD
BTMFR's Avatar
Default 12-05-2013, 08:32 PM
fully stainless will most likely be coated ...
Car: '09 335i coupe
Default 12-05-2013, 08:40 PM
Ok, just not polished I guess, coating would pretty much be a waste on SS. It really looks like mild steel, must just be the pictures.
Looks like it's coming together quite nicely. If you don't mind me asking, what is the trans swap costing you? I'm doing a large single turbo build as well, and am looking at swapping my 6AT as an option
Eleventeen Eleventeen is offline
Car: 2007 335i
Default 12-05-2013, 08:46 PM
Lookin' good!
Ferrari Red F80
BTMFR's Avatar
Default 12-05-2013, 08:52 PM
I got the transmission for 1600 from lkq clutch was 2800 misc parts i think between the short shifter knob cylinders lines mounts is close to 1000 ill add it all up once im done and have a final number
Default 12-05-2013, 08:55 PM
Looks great man.
Car: '09 335i coupe
Default 12-05-2013, 08:56 PM
Cool man, gonna be a pretty sweet setup. I hope my trans lasts a little while, my wallet can't take another beating right now....lol
j23a45m's Avatar
j23a45m j23a45m is offline
Car: 2011 E90 335i
Default 12-05-2013, 09:21 PM
nice work so far
2011 BSM 335i E90 MTECH 6MT BMS Intake Vishnu c@t less DP Cyba Scoops LUX V4 H8 6000K Headlight/Fog light Morimoto Euro headlight switch ACS roof wing 35% tint Black Grilles Misc coding JB4 Stage 2 AA charge pipe Vrsf 7" FMIC M3 cluster
2000max 2000max is offline
Default 12-05-2013, 09:28 PM
Looking good. How much clearance do you have between the hot side and the shock tower?
BTMFR's Avatar
Default 12-05-2013, 09:59 PM
Not alot... at all
Default 12-06-2013, 08:25 AM
Not alot... at all
It looks like a small area was notched out to make room. I guess that is that concession you have to make to have the turbo placement further back from the headlight.
2Times's Avatar
2Times 2Times is offline
Car: 08 E92 335xi
Default 12-06-2013, 09:14 AM
That is a cool project. No 6AT solutions which fell in a similar price range I take it? Or did you really just want MT?
BTMFR's Avatar
Default 12-06-2013, 11:36 AM
it wasnt notched but it is very tight i wanted the turbo to sit as far back as possible to allow for the filter
there are a few companies that offer 6at solutions but none that are proven manual has been proven with higher power...
trebila's Avatar
trebila trebila is offline
Default 12-06-2013, 12:58 PM
WTF, it's huge!!!
JETmn JETmn is offline
Car: 2011 335xi
Default 12-06-2013, 01:25 PM
Originally Posted by trebila
WTF, it's huge!!!
It's not that at 6466 is so huge vs. the stocker is just so tiny! It is a good sized turbo, but it is no 88mm. The 6466 is quite popular with the bigger EVO builds on a 2.0 4 cyl.
BTMFR's Avatar
Default 12-11-2013, 08:48 PM
Almost done just need the intercooler pipe and oil lines
Default 12-12-2013, 12:55 AM
^^ Badass man. What is the AR on the exhaust turbine for the T4 housing.
sti917's Avatar
sti917 sti917 is online now
Car: 2011 bmw 335i e90 M tech AT
Send a message via AIM to sti917
Default 12-12-2013, 05:03 AM
good job
2011 335i sedan Auto xhp flash 11.9 @118 mph
jb4 Bef, pure stage 1, meth, boost activated exhaust cutout on ********, BMS spacers, BMS air intake, BMS cowl filters
sranch335i sranch335i is offline
Car: 2008 335I
Default 12-12-2013, 10:10 AM
BTMFR's Avatar
Default 12-12-2013, 11:13 AM
1.00 ar twin scroll
wastegate recirc done
wastegate can actually be watercooled which i will hook up in the future
down pipe is 3.5 inch and vbanded at the end so i can hook it up to stock exhaust flange and down the road i can just run a 4" exhaust
2Times's Avatar
Car: 08 E92 335xi
Default 12-12-2013, 11:26 AM
That vband end is pretty smart. Looks good.
SneakyDeeky's Avatar
SneakyDeeky SneakyDeeky is offline
Car: 335i E90 6MT
Default 12-13-2013, 08:54 PM
Woah - tip of the hat to you, sir!
6MT | JB4 G5 | E60 | Walbro 392 | NGK 5992 | Spec2+ | ER Dual Oil Coolers | ER CP | Synapse BOV | ETS FMIC | 3.46 Wavetrac LSD
BMS DCI | AR *** | Magnaflow | BSH OCC | KW V1 | M3 Bits | Advan RS | Michelin PSS | LS3 AEs | P3 Boost Gauge | Dyno Results | COTM Pics
Default 12-14-2013, 01:43 AM
1.00 ar twin scroll
Can't wait to see log and dyno of how it boosts with that. I'm deciding what AR to do...
