robc1976's Avatar
robc1976 robc1976 is offline
Car: 2007 335i
Default HSF-4 V2 install pics - 10-25-2013, 09:27 PM
Few days ago I installed the HSF-4 and thought I would post some pics. My system is completely all -4AN and aquamist had all the parts. Impressive! Jeff Howerton had some of the best customer support I have seen....Respect!
musc's Avatar
musc musc is offline
Car: 335is DCT
Default 10-25-2013, 09:33 PM
Very clean set up!
335is DCT
sranch335i sranch335i is offline
Car: 2008 335I
Default 10-25-2013, 09:40 PM
WOW!!! NICE!!!!!!!!
I definitely want to do this!
robc1976's Avatar
Car: 2007 335i
Default 10-25-2013, 11:15 PM
Originally Posted by musc
Very clean set up!
robc1976's Avatar
Car: 2007 335i
Originally Posted by sranch335i
WOW!!! NICE!!!!!!!!
It's a pretty awesome setup
temperamental's Avatar
temperamental temperamental is offline
Default 10-25-2013, 11:50 PM
As usual, great initiative. Pics are tops. Thanks.
JB4 //MMP Stage 3 turbos//Custom Exhaust/BMS DCI//FMIC/KW suspension//Pi & Fuel it stage 4/MHD
BEF /CP&TIAL/ OCC.
_ink's Avatar
_ink _ink is offline
Car: 335i DCT
Default 10-26-2013, 12:09 AM
So why did you go down this route from your original JB4 setup?
Default 10-26-2013, 06:12 AM
Rob, do you have pics of tank and pump as well?
I am slowly installing the same system, but hope to fit the gauge in the ashtray so it can disappear completely.
Did you have the first bung welded onto the IC pipe?
Are those Aquamist 1.0 mm nozzles?
Did you retap the thread on the ER CP?
Wedge1967's Avatar
Wedge1967 Wedge1967 is offline
Car: '07 335i e92
Default 10-26-2013, 09:05 AM
Sorry I couldn't make it by the house this past week, just short of time and really came down with the worst cold with the quick weather change you had on Tuesday. Moline was getting some really fluffy snow most of the day. Was nice to see, but I'm glad to be back in Portland.
Install looks great... The only thing is the vents are not in the pin holes on the right side so they look unevenly spaced. Be very careful and use long needle nose rapped with electrical tape to get them into place.
robc1976's Avatar
Car: 2007 335i
Default 10-26-2013, 12:02 PM
Originally Posted by Wedge1967
Sorry I couldn't make it by the house this past weekjust short of time and really came down with the worst cold with the quick weather change you had on Tuesday. Moline was getting some really fluffy snow most of the day. Was nice to see, but I'm glad to be back in Portland.
How did you notice that lol! The ends keep falling off lol! They are in there lol!
robc1976's Avatar
Car: 2007 335i
Default 10-26-2013, 12:05 PM
Wife's car got the JB4 and I put different tune on mine...want 2 different cars.
robc1976's Avatar
Car: 2007 335i
Default 10-26-2013, 12:11 PM
They are aquamist 1.0 and all I had to do is run the tap in bung a bit deeper. Tank is a howerton engineering twin tank with custom -4AN fittings with stainless lines. The first bung I had ER weld a bung on it. Pump pic is with another pump but same location.
SneakyDeeky's Avatar
SneakyDeeky SneakyDeeky is offline
Car: 335i E90 6MT
Default 10-26-2013, 01:00 PM
Some quality work right there - respect!
6MT | JB4 G5 | E60 | Walbro 392 | NGK 5992 | Spec2+ | ER Dual Oil Coolers | ER CP | Synapse BOV | ETS FMIC | 3.46 Wavetrac LSD
BMS DCI | AR *** | Magnaflow | BSH OCC | KW V1 | M3 Bits | Advan RS | Michelin PSS | LS3 AEs | P3 Boost Gauge | Dyno Results | COTM Pics
robc1976's Avatar
Car: 2007 335i
Default 10-26-2013, 01:12 PM
I Appreciate that!
Wedge1967's Avatar
Car: '07 335i e92
Default 10-26-2013, 05:45 PM
OCD or something like that. Mine did the same thing and it drove me crazy until I fix it.
Default 10-28-2013, 07:34 AM
Rob,
I noticed that the kit shows a Cooling Mist pump, but the install photos shows a Devil's Own. (BWT since I have 5 series I don't recognize the location of the pump, is that in the trunk somewhere?)
I am having some issues fitting my kit together since Aquamist uses different connectors than other companies apparently. (They also drive on the wrong side of the road over there in UK.) So I am considering the DO pump with stainless 4AN fittings up to the nozzles. Then just using Aquamist control box, gauge, sensors and nozzles. Is that what you did in this build?
I am using a trunk mounted 3 gallon tank from A.I.S.
robc1976's Avatar
Car: 2007 335i
Default 10-28-2013, 07:38 AM
Rob,
The above pics where just for location pics...that is my old setup. I use aquamist pump with the connector....and relay. It is easy man, the power wire goes right to battery....then write guess from trunk to controller...easy as pie! That is the best way.
ashmostro's Avatar
ashmostro ashmostro is offline
Car: 2013 335is DCT
Default 10-30-2013, 04:33 AM
beautiful install as usual bro... how does it FEEEEEEL?
2013 335is DCT -- Quaife | JRZ RS1 - 450/800# | M3 + Hardrace arms | e93 M3 + Hotchkis f/r sways | BMS CP + OCC | ETS 5" IC | AFE DP's + DCI | RB PCV + Thermo Delete | Setrab + Improved Racing oil cooling | Stoptech f+r BBK | Cobb BQ Tune
Default 10-30-2013, 04:44 AM
Nice...I like it Rob...wish I lived closer..would love to check out your car!
robc1976's Avatar
Car: 2007 335i
Default 10-30-2013, 11:24 AM
Have to purge it and set up failsafe and it will be ready!
robc1976's Avatar
Car: 2007 335i
Default 10-30-2013, 11:25 AM
likewise my friend!
bmsportzn135i's Avatar
Default 10-30-2013, 11:55 AM
It looks too good. This HSF-4 is soo much of "i want".
537.75HP 540.63TQ
