(#5601)
r2350zrt r2350zrt is offline
Car: 2019 Q60 Red Sport
Default 08-13-2020, 09:55 AM
It did come with the fuel wires so I’ll hook those up.
Guess my last question would be what I am looking for when it comes to the logs?
JCB JCB is offline
Car: 2018 Q50 3.0t
Default 08-13-2020, 12:33 PM
Basics - Ign 1 is the most important item. Drops in timing indicate engine knock which is damaging to the engine. AFR should bottom out around 12. Watch for boost spikes during engine shifts and adjust boost target down to compensate near that RPM.
Hopefully more advanced users can chime in with more insight.
Default 08-15-2020, 05:23 PM
We don't have a Q50 specific how to read logs post but it's similar to the Stinger one.
Kia/Hyundai JB4 Logging Parameters - N54Tech.com - International Turbo Racing Discussion
Default 08-16-2020, 10:04 AM
Thanks for the replies, been helpful.
For now I just lowered the boost to +2
Gonna up to fuel octane then I’ll play around with the numbers
Another question, is it safe to assume i can raise the boost more if I add ldp and cbe as well as a cai?
Car: q50
Default 08-19-2020, 11:05 AM
Always modestly increase boost and log, don't just assume.
Q50 Premium RWD
BMS JB4 w/ FW, WMI, EWG
BMS HE
Low cost LSD
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 08-22-2020, 03:33 PM
Originally Posted by radar24
So I finally installed the jb4 with fuel wires on my 2017 Q50 RS. Took my first data log today on map 1. Doesn't help me to look at the graph as I can't tell most of the colors apart. Lol
Post the .csv file
12.64 @114mph
0-60 4.46
radar24 radar24 is offline
Car: 2017 Infiniti Q50 RS
Default 08-22-2020, 04:10 PM
It took me a minute to figure that out.
robrizok robrizok is offline
Car: '18 Q50 RS
Default 08-25-2020, 02:58 AM
Stock Q50 RS
Fuel wires installed, Bit 0 enabled
WOT pulls showing some 10.5 AFR at 17.5 to 18 psi
Duty bias default at 50 (latest firmware hex9)
Question: Can someone explain Duty Bias? Can I use this to slightly lean AFR toward 12.0? If so, which direction should I adj bias?
Thanks in advance.
Bob
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 08-25-2020, 04:57 AM
Originally Posted by robrizok
Stock Q50 RS
Thanks in advance.
Bob
Duty bias is only impacted when EWG connectors are installed. Nothing is happening on your car with those numbers in the fields.
18psi is aggressive for a stock car, you may want to post some logs for review
12.64 @114mph
0-60 4.46
dingo6610 dingo6610 is offline
Car: 2017 Infiniti Q50 RS400
Default AFR as low as 10.7 - 08-25-2020, 11:32 AM
Is it a problem if one or two readings of AFR during a pull are as low as 10.7?
What about IGN2 and IGN6 showing all zeroes?
CSV attached.
JCB JCB is offline
Car: 2018 Q50 3.0t
Default 08-25-2020, 12:24 PM
Your fuel wires do not look like they are active in the log. You would likely not fall below 11.5 or so if the wires were active and working. Ign 1 is the only active log for timing, so no worries that the others show zero. Fuelen column would show values at higher RPM if it were working properly.
Default 08-25-2020, 12:29 PM
Thanks. I actually do NOT have fuel wires. So can I assume that everything else looks relatively normal?
JCB JCB is offline
Car: 2018 Q50 3.0t
Default 08-25-2020, 05:50 PM
Yes, the fuel wires will even out your AFR - not critical, but makes a bit more top end power. The timing looks normal, but you may want to do a log/pull of 2nd gear to redline then to 3rd gear to 6500 or so. Looking to make sure the timing recovers after the shift and then stays say between 6 and 12 without any single large drops. At the shift the timing will normally go to zero.
Default 08-26-2020, 04:55 AM
Thanks for the feedback!
Syeghyayan Syeghyayan is offline
Car: Q50 3.0t
Default Log - 08-26-2020, 09:01 AM
how does this log look? Or am I still not @ peak boost psi
Default 08-26-2020, 09:25 AM
Boost seems low, map0 log?
Default 08-26-2020, 09:26 AM
CSV attached.
The factory mapping will dip AFR in to the 10s during runs, which is where the fuel wires are useful to lean that out for more power. Only IGN1 is active. The other parameters have non-related data stuffed in them for diagnostics.
azsuptt azsuptt is offline
Car: Q50RS400
Default 08-27-2020, 01:35 PM
Is there a way to get all default Values to Start Fresh; Is there a Button on app to set all back to default? Can it be done by installing a new Firmware?
I will be Installing mine this upcoming weekend; Once install will enable Fuel and egw settings , then Map One and Datalog it. I will like the JB4 witch was bough used to get back to Default Values and Start fresh with my RS400 and JB4 experience...
Default 08-27-2020, 05:40 PM
There is not a reset button. Default settings are included in the first post.
Car: Q50RS400
Default 08-27-2020, 06:41 PM
Understood!, Thanks..
Prodigy JDM Prodigy JDM is offline
Car: Infiniti Q50
Default jb4 lean on launch - 08-31-2020, 04:01 AM
Hi, Im very new to this platform and was trying to get a opinion on my data logs. The car felt really sluggish on the launch at the track. My afr was pretty lean on launch. Here is my data log. Thanks.
2016 premium w/ jb4, e30, fuel wires, ewg wires,megan ldp, stillen catback, k&n drop ins, BMS hx, BMS inlets, 20inch rims w 225/35/20
Ran a 12.74 at 111mph
Car: q50
Default 08-31-2020, 02:37 PM
Terry please check this log. Looking for ideas how to launch in boost or get boost in quicker. Since you have wastegate control and fuel control have you investigated a launch mode? I've got a significant chance at 11s in good weather but need to leave in boost.
Q50 Premium RWD
BMS HE
Low cost LSD
Car: q50
Default 09-02-2020, 07:58 AM
bump...
Q50 Premium RWD
BMS HE
Low cost LSD
Default 09-02-2020, 09:10 AM
Looks generally OK to me, you may need to brake boost more aggressively to get a better launch going. The high RPM map6 taper isn't doing you any favors in 1st gear either.
Default 09-02-2020, 09:11 AM
On launching what works best is brake boosting as aggressively as possible. Let it sit in brake boost for a few seconds to spool up.
