(#5576)
Default 07-30-2020, 09:05 PM
Originally Posted by roshg
I am able to fix it by using the boost in 1st gear option in Map 6...I basically make it so it adds 0 boost and it doesn't do it. I'm attaching a brief 1st gear log when I had about E25 mix, and this is pretty consistant everytime I have the cutouts/hesitation, my AFR dips to 20...not sure why its doing that.
Looks like something fueling related for sure, usually would be trims maxing out but they aren't maxing out in the log. What happens with 1st gear set to say 3psi?
roshg roshg is offline
Default 07-31-2020, 03:59 PM
Thx for helping me diagnosis this. I will have to retry to see what it does in 1st gear by adding boost +1psi each pull...then I can get back to you.
Syeghyayan Syeghyayan is offline
Car: Q50 3.0t
Default Terry please can you rate this log i tried to find closest to requirements - 08-02-2020, 03:11 PM
Link Sharing
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 08-02-2020, 05:29 PM
I personally am not clicking a random link when the .csv can be uploaded directly. Risky business.
12.64 @114mph
0-60 4.46
Car: Q50 3.0t
Default This better? - 08-03-2020, 03:58 AM
Did I attach it correctly
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 08-03-2020, 05:15 AM
Yep solid logs.. the log pros should be here soon
12.64 @114mph
0-60 4.46
Car: q50
Default 08-03-2020, 05:42 AM
Something really funky going on in those logs. I've seen targets of 6, but boost is also 6 like its not commanding any boost. Seems like a setting issue or something isn't connected correctly.
Q50 Premium RWD
BMS JB4 w/ FW, WMI, EWG
BMS HE
Low cost LSD
Car: Q50 3.0t
Default What should I do now - 08-04-2020, 09:45 PM
@ddnspider
what do you recommend that I should do? What is funky about it? What is it I should be looking for here to fix my problem?
Car: q50
Default 08-05-2020, 04:03 AM
Review the settings on page 1. Make a pull on map 0. make a pull on map 1. Then it can be compared. Safely, try to get a couple gear wide open throttle run.
Q50 Premium RWD
BMS HE
Low cost LSD
BUQ50 BUQ50 is offline
Car: 2017 Q50 S
Default 08-07-2020, 05:54 PM
Hey guys, another noob requesting some help deciphering logs.
Q50 Sport w/ L0wer D0wns, JB4 w/ fuel wires, running mobile 93 octane.
RightOnQ's Avatar
RightOnQ RightOnQ is offline
Car: 2018 3.0t Luxe
Default 08-07-2020, 10:36 PM
2018 3.0t Luxe stock/93 Octane/fuel wires on/EWG Wires "not" yet installed.
Map 6 graph, please let me know what you think about the chart. Def not fluent with reading charts so feedback if there's anything I'm doing wrong or anything my car dislikes.
Current settings on Map 6:
+1
+2
+3
+4
+5
+6
+7
+7
+7
+6
+3
+0
#MNVR30#RightOnQ
Car: Q50 3.0t
Default 08-07-2020, 11:10 PM
Yep definitely something wrong with my jb4 not doing anything for me highest psi is at 10psi ... like its restricted or something
Peekb24 Peekb24 is offline
Car: Q60 Red Sport 400
Default 08-08-2020, 01:42 PM
Has any with an RS noticed boost spikes with bit6 turned on ??? Terry@bms
Default 08-08-2020, 04:38 PM
Seems like something is wrong as boost is so low, log on map0? What codes are coming up?
Default 08-08-2020, 04:40 PM
Looks pretty normal to me.
Default 08-08-2020, 04:41 PM
Can i get some help please need your opinion Terry or anybody else willing to help
If you need technical support rather than just general log advice, you'll need to email in, unless you're not in a hurry. I'm not always to stay up to date on this thread.
Car: Q50 3.0t
Default Pic - 08-08-2020, 08:28 PM
Error Codes
0236
0106
0100
0000
Car: q50
Default 08-10-2020, 05:43 AM
Error Codes
0236
0106
0100
0000
Highly likely your map sensor connectors with the JB4 are not seated properly or you have bent pins or a poor connection. This would entirely explain the lack of boost from the logs.
Q50 Premium RWD
BMS HE
Low cost LSD
Car: Q50 3.0t
Default 08-11-2020, 09:27 PM
What should I do in this case ? I’ve tried unplugging and plugging make sure pins are aligned at this point I have no idea it’s been this way for about 3 months I even noticed the power loss
Car: q50
Default 08-12-2020, 04:09 AM
I would contact BMS about troubleshooting and possibly a replacement.
Q50 Premium RWD
BMS HE
Low cost LSD
Car: Q50 3.0t
Default Thanks a lot - 08-12-2020, 08:33 PM
Thanks you all for help and support
r2350zrt r2350zrt is offline
Car: 2019 Q60 Red Sport
Default Would like help with logs - 08-13-2020, 06:59 AM
Hey new to the thread
Just got my jb4 on a Stock Q60 red sport And would like to have log reviewed to see if all is good
JCB JCB is offline
Car: 2018 Q50 3.0t
Default 08-13-2020, 08:34 AM
Your timing dropped significantly in third gear, 4600RPM as boost hit 17+ PSI. You may need to back it down to +2 or 3. Best way to evaluate the log is a longer pull say 2nd to redline and then 3rd up to 6500 or so. Timing is Ign1. You shouldn't see sudden large drops in the number except at gear change. What Octane fuel were you running?
Default 08-13-2020, 08:45 AM
Hey thanks for the reply
Right now Iím running 91 but will be switching to 94 next fuel up
JCB JCB is offline
Car: 2018 Q50 3.0t
Default 08-13-2020, 09:36 AM
94 octane will make a big difference. Take it easy for now on the 91...car looks like it is fighting knock. Did your JB4 come with the fuel wires? If so hook those up. Also highly recommend the wastegate control wires.
