trebila's Avatar
trebila trebila is offline
Default For those who don't like the Alpina B3 trans flash - 11-10-2013, 07:32 AM
I like the Alpina B3 trans flash with the gear indicator even in D and S mode, and for the fast response for upshifts and downshifts.
But I don't like it in Drive mode because it upshifts too soon, approx. 1500rpm.
So for those like me who don't like this upshifts in D mode, but still want faster upshifts and downshifts, follow this DIY:
http://www.n54tech.com/forums/showth...ghlight=Alpina
but instead of uploading the ZB 7615835 (Alpina B3 trans flash), upload the ZB 7603527 ( BMW 2011 trans flash).
You'll not have the gear indicator ( D1, D2... S1,S2...) but you'll have upshifts and downshifts as fast as Alpina B3, and upshifts in D mode will appear at 1800-2000rpm, which is much better for me.
UPDATE November 2015:
here is a good summary, found on another forum:
ZB 7603527 (BMW 2011 Flash)
- No gear indicator
- D shift rpm raised slightly ~1800-2000
- Downshift rev match not like Alpina but better then others
- 6800rpm shift point
ZB 7615835 (Original Alpina B3 Flash)
- Gear indicator (D1, S1)
- D shift rpm relatively low ~1500-1800
- S mode shift rpm 2800-3000
- Great rev match downshifting
- 7000rpm shift
ZB 7603537 (New Alpina B3 Flash)
- Same as 7615835 except:
- Smoother
- Slightly higher RPM S mode upshifts ~3300-3500
ZB 7603541 (Euro Sport Flash)
- No gear indicator in Drive, M/S still have it i.e. S1...S6 / M1...M6
- D drives just like the stock
- S a bit more aggressive than stock
ZB 7601494 (US Sport Flash)
- D feels stock
- S stays in gear longer than the B3, Shifts at ~3300-3500
-M is more impressive than the B3 at shifts
I'm using the Alpina 7603537 trans flash, and my custom trebila performance flash tweaked specifically for AT with alpina trans flash, and here is the results in D mode at very low pedal input, upshifting between 2000 and 2500rpm, as it should be:
Jgnp15333's Avatar
Jgnp15333 Jgnp15333 is offline
Car: 2008 335xi
Default 11-10-2013, 08:33 AM
Thanks, Pal! Added to my coding cheat sheet!!
______________________________________
2008 335xi Sport 6AT - JB4 ISO - Wedge E85 Flash - Alpina TCU Flash - Walbro Inline LPFP - AA CP & BOV - AMS Intercooler - 100% Meth - VRSF *** - Apex Arc-8 17x9 et30 [squared] - Michelin PSS 245/40/17
1/4m - 11.7741s @118.27mph - - - 437awhp/510awtq
2 tanks - 4 pumps - 7 injectors - too many ponies!
Jeffman's Avatar
Jeffman Jeffman is offline
Car: 335xi
Default B3 Alpina does actually adapt to your foot - 11-10-2013, 01:07 PM
In my experience, the B3 Alpina TCU flash does actually adapt to your foot. If you baby the throttle driving around town it'll shift at ca. 1500 rpm. If you drive more aggressively it'll up shift and downshift at higher rpms in D mode as well as S mode. Really! Try it!
trebila's Avatar
Default 11-10-2013, 01:58 PM
Yes, All the trans flash do that, but I prefer to shifts at says 2000 rpm, even at very low throttle.
I've been using the 2011 BMW trans flash during 5 month, and the Alpina B3 one during 3 month, and in my opinion, the best trans shift behaviour is the BMW 2011 one.
The Alpina b3 one have 2 advantages: the gear indicator in D and S, and the high rpm shifts at 7000 rpm ( 6800 with the BMW 2011).
Default 11-10-2013, 05:24 PM
Agreed...in drive with the B3 flash it shifts a bit early...I hated it at first but like it for a few scenarios.
1. Wife driving
2. Freeway cruising (in sport it'll shift down to 5th at 75mph if you set the CC)
3. Loafing around town
However, I have paddles so for the most part I'll leave it in sport and use those.
The other thing is that since going with the N55 mids, a shift at 1500rpms sounds a tad bit raspy...so I typically avoid that. May try this flash and see how it does as 2k+ shifts sound much better...
Thanks for the update and info Trebila...
coolbho3k's Avatar
coolbho3k coolbho3k is offline
Bravest N54 Owner Award
Car: BMW 335xi
Default 11-10-2013, 06:32 PM
Just shift manual mode much better
2007 E90 335xi 6AT Premium Pkg | JB4 G5 ISO | Cheap custom exhaust: OBX ********* ***, Secondary *** Delete w/ Magnaflow Xpipe | WedgePerformance Backend Flash ("PUMP") | DCI | BMS Cowl Filters | Alpina TCU Software | M3 flappy paddles retrofit | NGK "one step colder" Soon: custom oil cooler retrofit, VRSF 7" FMIC
Wedge1967's Avatar
Wedge1967 Wedge1967 is offline
Car: '07 335i e92
Default 11-10-2013, 07:07 PM
I didn't post this information on this site, but you also have the option of Sport AT also. You get the standard D in Drive, but you also get the S1 S2... in Sport. It's a bit more aggressive than stock in Sport, but D drives just like the stock D.
Try 7603541 Euro or 7601494 US
I honestly don't know if there is much of a difference, but you won't hurt anything trying them both. Just disable UIF write so it doesn't update your UIF... Hopefully someone can post up the differences if any.
Russell @ BMS's Avatar
Car: 2009 335i AT
Cool 11-10-2013, 07:09 PM
1. Wife driving
Steve, let me know how the update goes.
Default 11-10-2013, 10:02 PM
Thanks Wedge...also, do you happen to recall which file was the stock one? Somebody was asking me about it and I know it's out there but figured you'd know.
Will do, but I probably won't play with this for a bit. Much prefer turning a wrench to playing with software and I want to get this testing done so I can move on to supplementary post FMIC injection
steve.kodra steve.kodra is offline
IXLR8
Car: 335xi
Default 11-10-2013, 10:03 PM
Tried this (ZB 7603527) today on mine (05/2007) and it was a no go. I had to go back to the B3.
Default 11-10-2013, 10:44 PM
Steve, try the 7601494 and let us know
That one sounds much more interesting to me.
coolbho3k's Avatar
Car: BMW 335xi
Default 11-10-2013, 10:58 PM
What is that one?
Default 11-10-2013, 11:29 PM
Originally Posted by coolbho3k
What is that one?
trebila's Avatar
Default S - 11-11-2013, 01:40 AM
Good information.
But can you confirm the shiftings (up and down) are as fast as the Alpina B3 one?
What is UIF?
Xearo's Avatar
Xearo Xearo is offline
Because Racecar
Car: '08 135i
Default 11-11-2013, 07:59 AM
Wow, lots of good info here. Sub'd!
-'09 135i MT - Custom 6466 ST - 680whp
-'08 135i AT - 6466 ST - dead
-'97 318is - Daily
-'82 320i
IXLR8
Car: 335xi
Default 11-11-2013, 08:35 AM
I will give it a shot and let you know.
2Times's Avatar
2Times 2Times is offline
Car: 08 E92 335xi
Default 11-11-2013, 08:38 AM
I'm curious about UIF also
nguyenvn nguyenvn is offline
Car: 2007 335i E92
Default 11-11-2013, 09:39 AM
Just flashed the ZB 7603527 ( BMW 2011 trans flash). Will test it out today. 05/2007 Prod date.
|2007 E92 SGM 335i|
Cobbv3 BMS DCI & OCC VRSF *** & FMIC E85 Custom Backend & Alpina TCU flash ER CP RB PCV+Cap
Walbro 255 Rohana RC5 19s Nittos 555 245/275 Cyba Scoops LUX V3 M3 Cowl ST Coils LCI Tails
Car: 2007 335i E92
Default 11-11-2013, 09:40 AM
Did you not like it or did you have problems flashing it?
|2007 E92 SGM 335i|
IXLR8
Car: 335xi
Default 11-11-2013, 12:50 PM
Gave the "car on lift" error in the dash. Didn't shift properly. Started out in 2nd. Wouldn't go into S mode and the paddles didn't work.
Car: 2007 335i E92
Default 11-11-2013, 01:11 PM
It's working fine for me so far. Shifts are not as crisp but still quick. D mode is a lot better than alpina, for me at least. Shifts around 2k. I still need to test it for a few days to make a decision.
|2007 E92 SGM 335i|
Eleventeen Eleventeen is offline
Car: 2007 335i
Default 11-11-2013, 01:20 PM
Low speed shift points can also be manipulated by adjusting torque request tables (Requested Torque %) in ATR and probably the BB flash. For instance, lowering the factor in each of the Pedal Position % columns will cause the trasmission to upshift later. It also makes the car downshift more easily when pressing the pedal down. (I believe the DME observes pedal position for shifts, not throttle blade position). However, the downside to lowering the factor is that it lowers pedal sensitivity and makes throttle feel a bit laggy, which is not good if you like a snappy throttle. It works well for me though, because I don't have any torque down low with the single, so a later shift helps keep the car from straining and moaning under light throttle.
Ferrari Red F80
IXLR8
Car: 335xi
Default 11-11-2013, 01:50 PM
Flashed the 7601494 successfully. D mode feels much more like normal. S mode stays in gear longer than the B3. Mine would shift at about 2800 - 3000 RPM on flat ground with minimal throttle. It now shifts at about 3300 - 3500. M mode is more impressive than the B3 at shifts. The car slams into gear and I had wheel spin from 1st to 2nd on both occasions when letting it shift by itself. This is new for me since I am an xi. However, it is too early for me to say that I will stick with this one. Lets see how it goes once adaptation happens. But for now, I like it!
IXLR8
Car: 335xi
Default 11-11-2013, 02:24 PM
Originally Posted by trebila
what is uif?
trebila's Avatar
Default 11-11-2013, 03:58 PM
Ok. Can you explain more?
Thanks.
I'll try 7603541, 7601494, and let you know compared to 7603527.
