Tortuga Tortuga is offline
Car: 2018 VW GTI
Default New user and new to JB4 - 07-09-2021, 09:56 AM
What's up guys and gals! I purchased a JB4 unit with a USB connector and was wanting to retro fit the bluetooth connector. Questions are:
1 - Is that even possible?
2 - If it is possible, can I route the blue power cable inside the enclosure?
It's a group 2 JB4.
Thanks in advanced!
Andy-J-Knight Andy-J-Knight is offline
Car: Fk2 Civic Type R
Default 08-04-2021, 08:46 AM
It's a group 2 JB4.
Thanks in advanced!
Yes you can swap from data cable to bluetooth just by cracking open the unit and unplugging one then fitting the other.
The newer bluetooth modules should carry the power connection within the main cable itself that comes out of the module rather than needing a separate power wire however if you have an older bluetooth module with the external power wire you can always pin it to pin 2 (from memory) on the plug to avoid having to tap a power wire in the JB4 harness. You obviously need pins and a soldering iron etc to do that though.
Honda Fk2 Civic Type R | JB4 | Injen Air Intake | Scorpion Exhaust | Shadow Chrome Rota PWR's | Insta: @andrewjonknight
Moderator
Default 08-05-2021, 10:47 AM
Guys note the pin can only be moved if the board is EWG. If its a older board it wont work. Board identification here: https://burgertuning.com/products/jb...02b267e1&_ss=r
2021 VW Golf 8 R
