luisgfernandez luisgfernandez is offline
Car: Honda accord 1.5t 2018.
Default code 0234 - 12-29-2020, 03:38 PM
hi, this is for terry .I have a honda accord 2.0 with prl intake.Today the car lose the power and trigged 0234 this is an over boost, i was in stage 1 and my boostsafe is on 24.I know that it exceed this limit to 24.3 according with the log .which is the boost safe limit for this car that i can increase and what is the max psi that it produce in stock mode.
Default 12-29-2020, 06:21 PM
Post up a log similar to when code was triggered and lets check out the details.
Default log - 12-30-2020, 04:41 AM
hi, terry thank you
Default 12-30-2020, 12:29 PM
OK looking at the log boost seems in check, knock count is low and fueling is normal. Does the fault appear every run or only randomly?
Default 12-30-2020, 12:34 PM
hi ,terry that was just once.Its ok if i increase the boost safe to 26?
Default 12-30-2020, 04:18 PM
Sure, that is just the level that JB4 will go to map0 (disable) if boost exceeds that for a second or more.
Default 12-30-2020, 04:43 PM
thank, I assume that all is good,but let me ask you another question.If i had an over boost why the last safety code in the log isnt 1 .The number that i have is 2.This number have been there when the jb4 was conected in my other accord 1.5t that i change for 2.0t.This is a detail that the jb4 has to improve,the ability to erase this code ,this is important to know if the code is for a new situation that is important to resolve .With all respect this is a sugestion.
Default 12-30-2020, 04:50 PM
I don't think you triggered a JB4 safety but an ECU fault code, different things. Maybe just adaption from your intake install?
Default 12-30-2020, 05:19 PM
so, seems like I will have the same problem though I increase the jb4 boost safe to 26. How can i deal with the situation.Thank for your time.
Default 12-30-2020, 05:59 PM
If it's something that comes up often enough capture it on a log so we can see technically what your problem is.
Default 12-30-2020, 06:11 PM
thank you
