(#826)
ClixT ClixT is offline
Car: B9 Audi A4 S-Line
Default 08-13-2020, 12:29 PM
The first code is 4DA3 19875 No communcation ABS Control Module
Second is 5A56 23126 Fuel level sensor circuit- Implausable signal
Both are communication errors that are most likely once offs. I would clear and see if they persists.
I cannot imagine what would affect the myAudi program to think that.
Thanks for the help! The weird thing is I don't have CEL on. I'm assuming after I do "read" i "delete" the codes?
As for that, I think the iOS version of OBD11 is just buggy as hell, causing problems. I've seen posts where they made a backup (like I did) to prevent this from happening and ironically, it broke the sliding sunroof code while doing so. I just copied the values back to original and it worked.
Default 08-13-2020, 12:34 PM
The codes are most likely soft codes and ECU will trigger a engine light or EPC if it happens over a certain amount of events.
2021 VW Golf 8 R
Default 08-13-2020, 12:59 PM
You're right I think it's one of those soft codes. I had to clear it twice for it to disappear. All good now
julian2292 julian2292 is offline
Car: bmw 1m
Default 08-17-2020, 08:10 AM
Yeah I just mounted my iPhone. That said, I do have a rooted spare Android Phone so hopefully a rooted Android Phone will let me show Jb4 on the MMI. I'd have to buy Jb4 mobile again though...
It worked ??
Only root phone and android auto ?
Default 08-17-2020, 08:14 AM
Originally Posted by julian2292
It worked ??
Yes because you have to use this: GitHub - endyrubbin/AAStream: AA Stream is a device screen mirroring application for Android Auto
It worked, but the experience is less than stellar because I was using an older phone (Galaxy Note 3) so YMMV.
thestuffle thestuffle is offline
Car: mk7.5 GTI
Default 08-17-2020, 09:17 AM
'18 GTI, stock. I was getting an intermittent EPC light and loss of boost/power on map 3. Map 0 did not fix the issue, but removing the JB4 did.
Turns out I had a failing battery, could this have been messing with the JB4? I'd like to put it back on but don't want to risk any damage to my car.
Default 08-17-2020, 10:56 AM
Its possible. If it does occur when its back on use the JB4 to read the code you getting which will direct us to a quicker resolution of the issue.
2021 VW Golf 8 R
Car: mk7.5 GTI
Default 08-17-2020, 11:19 AM
Will do. It's been running great without for a week now so I'm confident the car is fine at this point.
The codes I was getting before removing the unit were:
4F1B - no description
3ABB - fuel rail pressure circuit - low input
0000 - no description
2600 - no description
Along with a slew of OBD codes, which is how I found the battery issues. No codes since installing and registering the new battery.
quattromaniac quattromaniac is offline
Car: 2018 Audi S3
Default 08-17-2020, 09:18 PM
Anyone know what codes 3AD2 and 3AE2 are? I get them running on map 4 on a 2018 S3.
Default 08-17-2020, 09:42 PM
Check your if your fuel open loop is 45. If so then lower by 5 otherwise set to 45 and see if the faults persists.
Also set autoshift boost redux to 70 if not set already.
2021 VW Golf 8 R
Car: mk7.5 GTI
Default 08-20-2020, 08:43 AM
Just an update in case anyone is searching.
After a new battery my JB4 has been running without issue for 3 days, no codes.
WillyR7 WillyR7 is offline
Car: Golf R7.5
Default Speed limiter hack / dsg firmware - 08-24-2020, 04:21 AM
Dear George
I was wondering if u guys are possibly working on;
1. Speed limiter hack (for vehicles to run past speed limiter).
2. Dsg hacks/firmware codes into the JB4 to have quicker gear changes, optimal gear change identification and adjusting pops & Bangs.
3. Are there some new firmware updates on the table?
Lastly I could not find the description of error 6D00.
Thx in advance
Default 08-24-2020, 08:43 AM
Originally Posted by WillyR7
Dear George
Thx in advance
Speed limiter by the looks of things cannot be done. Same applies for the DSG.
We always making improvements on firmware but are pretty much limited at this point feature wise.
2021 VW Golf 8 R
Missingparts Missingparts is offline
Car: MK7.5 GTI
Default 08-24-2020, 01:26 PM
My new JB4 has the 60/87//5 firmware loaded. Is this the stable, beta or alpha? The hex file names are different than the firmware number so I'm not sure what version I'm running and if I should update. Also, is map 4 ok for a 7 speed DSG GTI? I see on the first page it specifically says it for the R model. I just want to make sure its ok for a non R model as well.
TimCupra TimCupra is offline
Car: MY20 Cupra 290 GPF
Default 08-24-2020, 03:47 PM
I have a MY2020 Cupra 290 GPF on order for early September.
I have heard of a long term issue with the JB4 on the GPF model.
The explanation is below from a well known UK VAG tuner.
Could someone please advise on this and whether or not an unreleased firmware patch is required?
Many thanks,
Tim
Default 08-24-2020, 05:04 PM
That is the Beta version.
Yes, map 4 is good if you on 93US/98 ron. For max performance on the front wheel drive cars map 3 for 98ron.
2021 VW Golf 8 R
Default 08-24-2020, 05:08 PM
Many thanks,
Tim
He most likely doesnt understand how it works or just want to sell flash tunes.
The ECU sits on the maximum AFR table of the ECU since the feedback once boost is reached is that of a stock car. The AFR biasing in turn makes the car run richer avoiding high EGT values. On some GPF cars we actually need to reduce the AFR biasing so it is quite the opposite.
2021 VW Golf 8 R
n3m0 n3m0 is offline
Car: Ď17 GTI Sport DSG
Default 08-26-2020, 02:11 PM
Been running Map 2 on my '17 GTI Sport DSG w/ 92 octane w/ 8.4 since 1/2019 without issue. No other modifications other than a Cobb DSG tune as well.
Just upgraded to 8.5.1 and read about the new Map 3 and 4. Would either be too aggressive for my setup, given that peak boost is slightly higher than Map 2, and I can't get 93 octane around here? Also, would there be any advantage of Map 4 over 3, given that I already have a DSG tune and haven't been having issues with launch control/shifting after launch, or are there additional (non-DSG) benefits?
Sorry for the questions if they've already been answered, tried as best I could to glean useful information elsewhere in this thread and still had these lingering.
Default 08-26-2020, 03:17 PM
Map 4 has a specific fix for the launch control for the 7Speed Haldex equipped cars.
Map 3 make slightly less torque so at the bottom of the rpm range there wont be a problem. Havent seen to many logs with it in summer though on 92 so best to email some logs in to george@burgertuning.com .
2021 VW Golf 8 R
Sanc47 Sanc47 is offline
Car: 2016 VW golf 1.8t
Default Few issues concerning jb4 - 08-29-2020, 12:23 PM
Hello I bought my Jb4 unit around a month ago and have observed a few issues, maybe some of you have experienced the same before.[*]The module casing heats up after I drive and check on it, is that normal?[*]I try to log my runs on my surface pro but no information shows up when I press stop and display[*]Iím wasting a lot more gas that usual, I run a 7 mile trip and see 15 miles gone from my display
Everything is installed correctly from what I see and Iím running the latest firmware. Any suggestions?
Default 08-29-2020, 12:33 PM
The casing heat is not a issue.
Can you take a picture of where you have fitted the AFR wire, its easier to email it through to george@burgertuning.com.
If you want at as a test remove AFR wire and go map 1 and see what the consumption does.
2021 VW Golf 8 R
Majiic86 Majiic86 is offline
Car: Leon Cupra 4drive 19' GPF
Default 09-04-2020, 03:54 AM
I would like to thanks to George from BMS for helping me out with map 6.
On dyno car produced 374 hp and 480nm of torque. Its really fun to drive now.
ksmyth's Avatar
ksmyth ksmyth is offline
Default 09-06-2020, 01:50 PM
Hi George,
Helping my nephew out with his 2019 Rabbit GTI. JB4 Map 1. He is in SoCal. 110 degrees there now. He had some shuddering issues. Here are the codes it threw. I had him clear the codes, set to map 0, drive it around. That cleared up the issues. The codes where 3AE2, 431A, 0000, 2700, 2600, 0026 and 0000 again. After clearing the codes and resetting to map 1 I had him run a few logs. Attached those logs. I am more familiar with the N54 platform. Suggestions? Thanks.
P26_M0_R3_200906_1259.csv
P26_M1_R1_200906_1338.csv
09 335xi - 6AT - JB4 - hot side inlets - *** - MHD Flash - 7" IC - Fuel-It TBI
Default 09-07-2020, 04:30 AM
Originally Posted by ksmyth
Hi George,
Attachment 98395
Attachment 98396
He has the wrong firmware loaded. He need to load 60 - VAG Gen3.
On settings get him to make the fuel open loop 45 and boost safety 26. Fuel bias values must all be 100.
2021 VW Golf 8 R
Car: Golf R7.5
Default 09-07-2020, 08:59 AM
E98 Mixture with 95unleaded pump
Hi , does anyone have input on E98 mix ratio to 95 unleaded pump?
