Default JB4 for Porsche 718 - 02-17-2019, 02:52 PM
Order here: https://www.burgertuning.com/product...jb4-tuner-beta
We'll use this thread for our Porsche 718 BETA updates, map guides, firmware, and discussion!
Install Guide here: https://www.n54tech.com/instructions...tall_guide.pdf
Optional map changing, datalogging and updates are done using the BMS data cable or JB4 Mobile REV3 bluetooth kit.
BMS data cable hard wired directions and software Click here
Map guide:
Map0 - JB4 disabled
Map1 - 2psi peak 91 octane
Map2 - 3psi peak 91/93 octane
Map3 - 4psi peak 93 octane, race gas, or ethanol blend
Map4 - 6psi peak ethanol blend or race gas
Map5 - 8psi peak ethanol blend, race gas, CPI required
Map6 - User adjustable by RPM map using settings on user adjustment page. Setting of 5.0 would request 5psi over stock at that specific engine speed.
Map7 - Progressive WMI integrated map, boost profile under WMI flow adjustable on WMI page.
Map8 - Low boost VALET map COMING SOON
Firmware:
JB4_PORSCHE_718_5:
1) Corrected issue with boost targets being scaled higher than intended in v4.
JB4_PORSCHE_718_4:
1) Revised top end boost and other mapping changes.
JB4_PORSCHE_718_3:
1) Revised boost scaling in app
2) Revisions to map4 & map5
JB4_PORSCHE_718_911.2_1:
1) Added additional logging channels for bank2 AFR, bank2 fuel trims, intake air temperature, high fuel pressure, and more.
718_1: Initial firmware.
How to update firmware:
For firmware updates if having issues we suggest you turn off WiFi, change upload timeout to 25, and set your phone next to JB4 box under the hood.
Obx_jk Obx_jk is offline
Car: Porsche 718
Default 03-30-2019, 04:07 PM
I’ve installed mine. Need some help understanding which map is which. Also the Bluetooth is not connecting to the the gauges. It will for a moment, but then goes to zero. Two gauges will work but doesn’t seem real time.
Default 03-30-2019, 04:40 PM
Had a customer connect the JB4 connections in the wrong spot limiting boost. Be sure rainbow patch is on the MAP sensor as shown!
Brown109 Brown109 is offline
Default 04-25-2019, 12:17 PM
Do any of the maps currently available require any modifications?
jungo jungo is offline
Car: porsch
Default 09-27-2020, 03:36 PM
Hello there
I just wonder how can I install the connector of map sensor. there is conflict between the installation guide and this post of the forum which shows the wrong and correct installation method of map sensor on manifold ? could you illustrate which one is correct?
many thanks.
Car: porsch
Default 09-30-2020, 04:24 PM
Originally Posted by jungo
Hello there
many thanks.
Can any one help me ?
Default 04-25-2019, 02:57 PM
No they don't.
leogets954 leogets954 is offline
Kill Mode RC
Car: porsche 718 GTS
Default 05-21-2019, 10:39 AM
Ordering mine now for my 718 GTS. Will be running a ******* ********. Do I need to use a specific map, or will I need an O2 Spacer?
Default 05-21-2019, 11:14 AM
Inside USA we can't provide any advice. Outside USA there is a passive delete option for those.
Kill Mode RC
Default 05-21-2019, 11:34 AM
Sorry Terry, I should have mentioned the car will be used for track racing only. Where would I find information on the passive delete option?
Fred V Fred V is offline
Car: 718 Cayman
Default 05-23-2019, 01:33 PM
I just purchased it and will have it installed very shortly. Very excited. The dyno charts posted on the order page are for a base model running E26 fuel correct?
What are the power gains for each maps on regular 91/94 fuel?
Kill Mode RC
Default 05-23-2019, 01:58 PM
I dyno'd my stock GTS on sunday. 91 degrees, 65% humidity, 700miles on the odometer. made 354hp/ 335torque.
Kill Mode RC
Default 05-23-2019, 01:59 PM
I dyno'd my stock GTS on sunday. 91 degrees, 65% humidity, 700miles on the odometer. made 354hp/ 335torque. will dyno the jb4 when I get it.
Car: 718 Cayman
Default 05-24-2019, 10:41 AM
I'm very curious about the base model since this is what I have, and everything seems to be about the 2.5
Default 05-24-2019, 05:11 PM
Sounds good! Steve can help you crank up the boost too if you need.
Kill Mode RC
Default 06-05-2019, 08:58 AM
Has there been any updates on the progress of Maps 5-8?
Default 06-05-2019, 02:53 PM
No we haven't done any higher maps yet, as Steve is continuing fuel development so we can determine how far we can safely push it.
Kill Mode RC
Default 06-06-2019, 09:59 AM
Sounds good! Just ordered mine for my gts yesterday! cant wait!
Default 06-06-2019, 11:01 AM
Harnesses are on back order for a couple weeks I think, but we'll ship it as soon as we can.
Car: 718 Cayman
Default 06-25-2019, 06:50 AM
Had it installed, have been running map 4 for around a month now, and 3 pretty agressive track days. The car performed wonderfully.
Had a cooling system fault on the last day, but temps didn't exceed normal ranges and once I cleared the codes they never came back.
Also curious about the O2 sensor. I'm in Canada and my next purchase is a ******* ********, would the tune take care of the CEL or would I have to erase the faults at every start?
Cheers!
Default 06-25-2019, 10:03 AM
Passive delete is an option for outside the USA work, should work but we've not tested it yet on the 718.
Car: 718 Cayman
Default 06-25-2019, 10:06 AM
I will end up giving it a try I think. How about the boost spike issues some people are reporting without a tune?
Thanks,
Default 06-25-2019, 10:14 AM
Until I see a JB4 log of it it's hard to evaluate. If you have any tuning issues with them share the log and lets see what we can work out!
Default 06-28-2019, 01:25 PM
Added updated firmware to first post
sniper260687 sniper260687 is offline
Car: 718 cayman s
Default 07-10-2019, 09:53 AM
Mine is on the way for my 718 cayman s.
If i run map 4, how much E85 can i filled up? gallons wise combine with 91 gas
