(#1976)
Aneurysn05 Aneurysn05 is offline
Car: 335I
Default S55 JB4 - 05-06-2019, 04:12 PM
Looks all normal to me for map2! Is the car flashed? If so set FUD.6 on.
Hello Terry, I've had JB4 on all my vehicles and now I purchased an F80 M3 2016. I've owned this M3 for a couple of years now, however, for some reason since I got my JB4 installed I find it runs much better with my map set to 0 (stock) than when my JB4 is active.
Being a JB4 customer for so long, I know there must be an issue with my configs.......
Attached you will find my latest logs. for some reasons, every time I enable my JB4, my car lags then goes from whatever map I had it on and into map 4 (safety).
Could you please review my logs and give me some recommendations. I would truly appreciate it.
I currently have fabspeed ********* installed.
Default 05-06-2019, 07:15 PM
Looks like you mixed up the brown and rainbow TMAP connections during install. Fix that and relog map1.
Car: 335I
Default 05-08-2019, 04:14 PM
THANK YOU TERRY!!! you were absolutely right. Mistake on my end during installation. Now i get proper readings. But may need skme further adjustments. no rush since youve helped enough already, but when you get a chance please review these logs and make any recommendations. thanks again.
Please note that i had to split the data into two files in order to upload. Split on line 175. Thanks.
Default 05-08-2019, 08:37 PM
Need the CSV files. Can't open excel files in the JB4 interface.
Car: 335I
Default 05-09-2019, 05:14 AM
See attached
Default 05-09-2019, 03:29 PM
AFR is a bit strange, it's dumping in a lot of fuel. Trims are high for just map1. What fuel are you using?
Car: 335I
Default 05-09-2019, 05:49 PM
93
Default 05-09-2019, 09:51 PM
Let's see a log on map0 next.
Car: 335I
Default 05-10-2019, 12:17 PM
Hello terry, i attached two runs on map 0
Default 05-10-2019, 01:33 PM
I can only really evaluate logs that are full throttle for fairly long length of time, like 40-90, 4th gear 2k to redline, etc. On a safe private track of course.
Default 05-17-2019, 02:52 PM
Moved IC discussion here: Phoenix Racing S55 Intercooler - N54Tech.com - International Turbo Racing Discussion
Car: 335I
Default 05-18-2019, 10:41 AM
Hello Terry, sorry I was traveling the past week. I did several runs. Please see attached.
Default 05-18-2019, 11:44 AM
Still not a lot of WOT but map1 looks more normal now, maybe just need some adaption runs.
Car: 335I
Default 05-18-2019, 01:35 PM
Ok, thank you.
narstune's Avatar
narstune narstune is offline
Car: '11 E90 335i
Default 05-19-2019, 07:06 PM
Terry, would you happen to have the change notes for firmware 1_8_5_T5?
2017 M3 ZCP
Dreebanqz Dreebanqz is offline
Car: 14 bmw 335ix
Default 05-22-2019, 03:20 AM
are these still the same setting?
Car: 335I
Default 05-22-2019, 04:57 AM
Any release notes for firmware 1_8_5_T5?
Default 05-22-2019, 09:03 AM
Haven't released any notes on it, just some minor changes.
Car: 335I
Default 05-22-2019, 05:59 PM
I suppose its safe to move to the latest firmware. if so, I will make my changes tomorrow. Thanks again for your prompt responses.
lazycat lazycat is offline
Car: f30 335i
Default 06-12-2019, 02:07 AM
Ive been using the latest firmware 1 8 5. Seems the same as before, what changes?
2017 F80 M3 Competition Package. JB4, BMS Stealth Meth kit with dual CM5. ESS charge pipe. RKtunes post intercooler meth injection. Stock exhaust with 2ndcat delete
