(#501)
2.7Boosted-Brad's Avatar
2.7Boosted-Brad 2.7Boosted-Brad is offline
Car: 2018 F-150 2.7
Angry Check Service manual message - 06-16-2019, 04:59 PM
WOT for more than 4 seconds or so will often send the truck into limp mode (check service manual message) comes on. Everything looks good in the logs to me, overboost?
Default 06-16-2019, 06:38 PM
Update to v6 firmware in the first post and relog so we can see fuel pressure...
Car: 2018 F-150 2.7
Default Wow! - 06-17-2019, 04:28 PM
Amazing customer service! I was having trouble updating and kept getting an error after updating. I kid you not five minutes after emailing support I got the solution I needed!
Default 06-17-2019, 05:34 PM
Glad to hear it!
Car: 2018 F-150 2.7
Default Limp mode - 06-17-2019, 09:05 PM
Limp mode in map 5, here’s the log.
WOOSH!
Default 06-18-2019, 09:47 AM
I can't see any obvious cause, but map5 is up there. Does it come up on map2?
Car: 2018 F-150 2.7
Default 06-18-2019, 10:04 AM
Will log again tonight on map 2. Only 1 out of every 20 or so runs on map 5 will it be triggered.
WOOSH!
Default 06-18-2019, 02:04 PM
Got it... And never any codes?
Car: 2018 F-150 2.7
Default 06-18-2019, 05:39 PM
30 roll triggered it again +p0263 code. (Map 5 still)
WOOSH!
Default 06-18-2019, 05:41 PM
I think it's just a boost under target code. Map 5 is too high, you're not making as much boost as is being requested, and thus the fault. The P0263 number looks up to some sort of cyl1 misfire sort of code though.
Either way I'd get over to map2.
