mb21111's Avatar
mb21111 mb21111 is offline
Car: E92 335i
Default N54 XI Part Out - 06-28-2018, 12:50 PM
Lots of goodies for sale. All parts came off of a 2008 E61 535XI wagon with 58k on the odometer
535XI turbo outlet pipe- $50
Inlets: $90
Intake manifold: $70
Water pump: $150, Thermostat: $50
OEM Turbos (need new seal): $375, includes oil drain lines
Heat shield: $20
Intercooler: $90
Valve cover: $70
8 bolt Engine- 58k on odometer when pulled, 90-100 psi across the deck cold and without oil, 115-120psi across the deck with oil in the pistons. Ran and drove prior to removing.
(does not include oil pan, hpfp, turbos, oil cooler, oil cooler lines): $1500
Also for sale but no pictures yet:
HPFP, oil pan, oil cooler, oil cooler lines, starter.
If you need something that isn't listed shoot me a message- I more than likely have it. All parts will be cleaned with a material safe degreaser to remove oil+dirt before shipping.
Mike_L's Avatar
Mike_L Mike_L is offline
Anti-Social
Car: 2017 X3 xDrive35i
Default 06-28-2018, 01:58 PM
Where are you located? I'd kinda like to build that motor, but its certainly not worth shipping with all the BS residential and liftgate surcharges.
Mike Levy
2017 X3 xDrive35i
2000 F150 Lightning
2018 Equinox LT 2.0T
mb21111's Avatar
Car: E92 335i
Default 06-28-2018, 02:18 PM
Hi Mike, I'm located in Newton, MA- just outside of Boston.
Mike_L's Avatar
Anti-Social
Default 06-28-2018, 03:46 PM
Damn. I'm down in central Florida. Oh well. Good Luck!
Mike Levy
2017 X3 xDrive35i
2000 F150 Lightning
mb21111's Avatar
Car: E92 335i
Default 06-30-2018, 10:13 AM
BUMP: price drop on engine.
New price: $900
Badbimmer269 Badbimmer269 is offline
Car: 2008 bmw 335xi
Default 09-21-2019, 11:10 AM
I would like to buy your water pump and thermostat if you still have it for sale
