giovanniv giovanniv is offline
Car: 08 bmw 335i
Default Clutch setup for 500+torque - 05-20-2015, 10:27 PM
ok so I just recently upgraded to the MHD e60 flash tune and the stock clutch is not liking the power whatsoever in 4th+ gear. What setup are you guys running? Anyone running a clutchmasters? What about act? I know spec 2 is very popular as well. Also what flywheel are you guys running and what kind of power are you putting down? I'm looking for a heavier clutch but still want it to be my DD. Future mods are RBs most likely as well.
2008 e93
-MHD e60 custom map, VRSF DP, VRSF CP, tial bov, wally 255, Drilled/slotted rotors, Hawk pads, VRSF FMIC, M3 control arms, VIS CF hood, ECS CF lip
ba114's Avatar
ba114 ba114 is offline
Car: 135i 6MT
Default 05-21-2015, 12:27 AM
im in the same boat.
Going to give the 335is/550i clutch and DMFW combo a try.
swat's Avatar
swat swat is offline
Car: 07 335i
Default 05-21-2015, 07:19 AM
335is clutch holding it just fine here for a bit. Have a buddy pushing 600+ to the wheels with this same clutch for 50,000+ now too on a SMFW.
Stacked BMS Flash & JB4, Dinan CAI, ER Chargepipe, 7" VRSF Intercooler, VRSF DP's, ER Sport Oil Cooler w/Steel lines, Gunmetal 19" VMR V710's, 335is clutch, Wavetrac LSD, M3 FSB, M3 Front & Rear Control arms, M3 RSB, M3 rear subframe bushings, M3 guide rods
jyamona jyamona is offline
Car: 2010 135i 6MT
Default 05-21-2015, 07:33 AM
I recommend the mFactory SMFW + 550i clutch. I am running it now, and it is fully broken in. Chatter at idle is very minimal, I only can hear it with the AC on. 1k - 3k rpm light accel chatter isn't too bad either. Mine is amplified by my Rogue trans mounts. With stock mounts I believe it wouldn't be noticeable.
Car: 08 bmw 335i
Default 05-21-2015, 08:08 AM
What flywheel are you guys running with the 335is clutch?
2008 e93
swat's Avatar
Car: 07 335i
Default 05-21-2015, 12:56 PM
Currently stock DMFW, but that's only cause I've added power since getting the clutch. I should be running with a SMFW, which i'd go with the one from SPEC.
Car: 2010 135i 6MT
Default 05-22-2015, 06:58 AM
The mFactory one is nicer, in my opinion.
SCGT SCGT is offline
Car: 207 335i 6MT
Default 05-22-2015, 10:16 AM
I have the spec SMFW and the 335is/550i clutch. It works great, but if I were to do it again I'd try the MFactory. Reports are that it's quieter... not sure how but I'd give it a go. The spec is pretty loud, I'm used to it now though. I think the MFactory is cheaper too.
swat's Avatar
Car: 07 335i
Default 05-25-2015, 08:19 AM
The SPEC one is louder in my opinion.
Car: 2010 135i 6MT
Default 05-26-2015, 07:01 AM
agreed!
swat's Avatar
Car: 07 335i
Default 05-26-2015, 08:12 AM
agreed!
Much better! Makes it sound more like a race car.
Element's Avatar
Element Element is offline
Car: BMW 135i N54
Default 05-26-2015, 09:57 AM
Also in for a clutch (and or flywheel) upgrade after last weekend's drag racing roasted min.
Anyone got some info and part numbers for the 335is/550i setup?
2016 F22 M240i | 8ZF
suspenceful's Avatar
Car: 2008 BSM 135i
Default 05-26-2015, 10:04 AM
I see you have a 135i. You'd love my blog post about my installation. Includes all the parts you'll want/need!
http://my1series.com/2015/03/23/335i...lutch-upgrade/
🚀 My 750HP 135i build: my1series.com
🔧 My budget 335i build: bmw335i.com
📷 Follow me on Instagram: instagram.com/jakespence
🎬 Watch me on YouTube: youtube.com/jakespence135
🌟 Support me on Patreon: patreon.com/jake_spence
🏁 Shop BMW merchandise: bimmerstreet.com
Element's Avatar
Car: BMW 135i N54
Default 05-26-2015, 10:33 AM
Weirdly enough I came across your blog when I found the part number on RealOEM and then googled it. Great read so far
Car: 08 bmw 335i
Default 05-26-2015, 02:16 PM
Element look on ecstuning, they give the part number as well.
2008 e93
FRD135i's Avatar
FRD135i FRD135i is offline
Car: 2008 135i
Default 05-28-2015, 07:37 AM
I have a Clutchmasters 880 twin disk. Absolutely bulletproof and loud as crap. Took some of the chatter out but still turns heads at a stop light. ZERO friction zone, I mean ZERO. took the CDV valve out. On/Off clutch. Luckily I don't find a whole lot of stop and go traffic around here. Great experience so far, and no one can steal you car because its a pain in the ass to drive. *supposed to be good to 800HP
2008 135i, JB4 G5, BMS DCI, AA Catback, CPE ******DP's and MIDs, 1 Gal. trunk mount.
2010 BMW S1000RR Mineral Silver
Lost Love= 2002 M5
BobVader's Avatar
BobVader BobVader is offline
Car: 335xi 2008
Default 05-28-2015, 07:44 AM
upgrade 335is/550i clutch with stock DMFW...and work great after 1200 miles. very happy
'08 BMW 335xi // Sedan // Black Sapphire // Sports Package//Mods: JB4 G5 iso|MHD bef Race|Hexon rr600|inlets|stage 2 fuel pump|N20 tmap 3.5|Chargepipe|Diverter valve|RB pcvalve|BMS Meth kit|AA Speed Delimiter|BMS tuning gauge|UR CL DP|BMS DCI|AA Exhaust|HELIX fmic|CDV|H&R coilover|10mm Spacers H&R on 4 wheels|**Record for XI's on dragtimes.com, before new turbo and inlets...new results soon...11.768s@118.70**Top speed 186,4 mph GPS, vbox 60-130mph 7.9,
MFactory MFactory is offline
Car: BMW E92 M3
Default 05-28-2015, 10:01 AM
$890 shipped for the 335is/550i Clutch + MFactory SMFW. You won't regret it
MFactory / YCW Engineering (LSD's, Gears, Flywheels, Clutches, Driveshafts, Axles) - www.teammfactory.com
YCW Suspension (Mid-Range Coilovers) - www.ycwsuspension.com
SWIFT Springs Europe (Exclusive Distributor) - www.swiftspringseurope.com
SWIFT Springs Asia (Exclusive Distributor) - www.swiftspringsasia.com
