Vadellas Vadellas is offline
Car: Skoda 1.8 ea888
Thumbs up 1.8t ea888 28psi dyno - 08-08-2019, 06:15 AM
Skoda Octavia 1.8t dsg7
Ecu: st1 APR + JB4;
Is38;
Full exhaust custom 76í;
Intercooler Revo;
Intake filter bmc in stock box;
Inlet pipe ecs;
Boost pipe;
98RON;
the intake temperature is very hot. air conditioner radiator is bad.
https://youtu.be/KBmVpZuXcx0
https://youtu.be/ycRhJO-cDo8
Default 08-08-2019, 02:49 PM
Looking great considering the high intake temperatures.
Default 08-09-2019, 03:59 AM
thank you.
Default 08-09-2019, 10:46 AM
Great numbers man, that's impressive!!
Default 08-12-2019, 06:04 PM
Thank you))
salik990 salik990 is offline
Car: Audi A3 1.8TFSI
Default 11-21-2019, 05:58 AM
that really great number on IS38 with stack tune, which gearbox u have, DQ200 or DQ250?
Default 11-25-2019, 04:37 AM
Dq200)
Default 11-25-2019, 05:53 AM
must be TCU flash with aftermkt clutch, was thinking to swap IS20 but i get worried about gearbox.
Default 11-29-2019, 12:39 PM
if you make TCU then you can use IS20. spool is best done later.
Default 11-30-2019, 01:03 AM
u mean i can add boost from higher rpm and wat about the ecu tune? would i need ecu flash tune to run IS20?
Default 12-01-2019, 03:03 PM
Yes. if you have simos 18 itís better to have ecu flash. jb4 cannot bypass restrictions on this block, and if boost is higher than 22 psi, then the ignition angle will be closer to 0. there are no such problems on simos 12. and make FUD D - 90
Default 12-03-2019, 01:40 AM
i remember my 2015 A3 1.8TFSI ecu is simos 12 but i cant go above 15-16psi on map 3 or 4...even map 6 customised with the help of George i reached 16psi. I have full bolt-on with TCU stage 2+ flashed from TVS, was considering ecu flash to get more boost but i think IS12 turbo wont be able to reach that high. Will be looking for IS20 turbo and see if i can make more boost. BTW i dont see FUD, all i see is future use A
Default 12-03-2019, 02:15 AM
I think everything will work out and on is12))
Default 12-03-2019, 05:51 AM
any reason u have set the 6 cylinder timing to 1? which firmware u have as i see your might be previous firmware as i dont see Future Use D anymore on my jb4 app
BMS JB4/TVS stage 2+ TCU flashed/Revotechnik down-pipe/modded oem airbox/Revo inlet hose/aFe drop-in filter with snow grate removed/Revo Intercooler/Revo turbo muffler delete/CTS TIP/GFB dv+/034 dog mount/NGK RS7 plugs/OBDeleven
VCDS tweaks visual parking aid, needle sweep & oil temp on DIS
Default 12-04-2019, 03:28 AM
6 cycles I don’t remember))) it was a long time ago that a person who understood this and started setting me up said that put 1 and do not turn it off. maybe the difference in ios and android. try to choose options, I think there will need to enable these bits 1,3,4,6. N20 needs to be set 1 this is necessary so that the boost is more than 21psi)))
Software 60.85.5
Default 12-04-2019, 03:45 AM
Originally Posted by Vadellas
6 cycles I donít remember))) it was a long time ago that a person who understood this and started setting me up said that put 1 and do not turn it off. maybe the difference in ios and android. try to choose options, I think there will need to enable these bits 1,3,4,6. N20 needs to be set 1 this is necessary so that the boost is more than 21psi)))
Software 60.85.5
mine is android so maybe that the slight difference app from iOS, also 60.85.5 is latest software. Will try changing N20 setting to 1 if that will help giving more boost.
