TSI 1.8T Jasper's Avatar
TSI 1.8T Jasper TSI 1.8T Jasper is offline
Car: 2018 mk7.5 1.8T m/t
Default Going from Map1 to Map2 question - 06-08-2019, 02:51 PM
Im running map1 now 91, 1.8T 5spd and intake only and was wondering if map2 on 93 would be fine and is clutch friendly also can some one post both maps 1 and 2 for comparison since having no luck on finding one.
Other question is , should I run custom map6 setup , not looking for more power find map1 is quite fine but just wondering between running on map2 or map6 custom or just stay with map1 , also will be getting a CTS ******** shortly .
Default 06-10-2019, 08:44 AM
Best would be to post a log on map 1 so we can evaluate. From there we can tell you how to move forward.
Default 06-10-2019, 02:51 PM
On the 1.8T we haven't had clutch longevity issues with map 2 on 93. You can try it out and see how it feels. Map 1 has a peak add of 4psi and map 2 of 5.4psi. If you happy with the power you don't need map 6.
Default 06-10-2019, 03:25 PM
Thanks , will give it a try on Map2 ...so far loving the jb4 and how well it works .
Default 06-10-2019, 04:10 PM
will do some logs ,little harder with laptop need to get a longer cable to run inside car.
thanks
