Sohrob Sohrob is offline
Car: Leon Cupra
Default Map 2 settings - 05-20-2019, 02:24 PM
Can anyone tell me the exact settings for map 2? My car made good power and I like the characteristics. My train of thought is base map 6 off the map 2 settings
Default 05-21-2019, 05:18 AM
Map 2 peaks at 5.4psi over stock and is additive map.
Below are the Map 2+ settings we use when we start logging a map 6 for users. You can change the large boost numbers in the map 6 boost chart to these and the JB4 will switch to additive mode automatically
1500 0
2000 2
2500 3
3000 3
3500 3.5
4000 4
4500 5
5000 5.5
5500 6
6000 6
6500 6
7000 6
masher55 masher55 is offline
Car: Golf GTI MK7 PP
Default 05-21-2019, 10:17 PM
Hi Goerge, what should boost saftey and fuel open loop, be set at for these settings. thnx
Car: Leon Cupra
Default 05-22-2019, 05:13 AM
Thanks George, is it advisable to go higher than these numbers?
Default 05-22-2019, 05:38 AM
Will have to see logs and see how the car is running.
Fuel loop stays as is and in summer boost safety can be moved to 26 or 27.
Default 07-04-2019, 01:37 AM
These map2+ settings are awesome, car is really strong. thank you
