5alive 5alive is offline
Car: JB535
Default Strange jB4 behavior, New Codes, AF63 and some fuel pump ones plus same old code 2DED - 04-23-2019, 10:14 PM
I posted some info about this in a different thread which I'll link but this is different with a new code. Been getting 2DED anytime car sits for awhile. Add to that today
I was driving, and had been for 30 min, stop and go at first, then highway for 15min. As I slowed into 3rd and began braking around 40mph I noticed the 'gauge sweep'. The comment I made in the thread below was I had seen this a couple times just after start up. Not when I started the car but 30sec to 1 min later. Today the gauge sweep was at start up, blinkers flashed at oil temp. 20 minutes later random gauge sweep.
Might not think much of this if I wasn't getting high batt drain warnings everyday...
The code list is attached and shows the high current and high voltage fuel codes. It's not a log but lists the specific codes and I pasted a freeze frame for the 2DED code.
Ideas appreciated; especially from jB4 designers/builders.
Faultcode: (0x2DED) Power management, closed-circuit protectio
** Faultset 1:
** (appeared at: 244064.0km)
***** Voltage cl. 87:
****** 12.19 V
***** Time with quiescent current 200 - 1000 mA:
****** 0.00 min
***** Time with quiescent current 80-200 mA:
****** 135.00 min
***** Time with quiescent current bigger 1000mA:
****** 0.00 min
2008 535i | 6MT | Evo CP (stock DV)| jB4 (duh) | BMS BEF (PumpUSA) | BMS DCI | 93 (via 91 + Octane booster) | E85 ~35% | MFactory SMF | Spec Stage 2+ Clutch | UUC STS | 7" Street FMIC | Toggle Switch Gas Pedal delete
152k - Maintenance (HPFP, LPFP sensor, Fuel sending unit, CPK sensor, Injectors (12), Plugs 97506 (.020), Delphi Coils, AGM Battery, starter, Koni FSD @ corners...)
Car: JB535
Default Bump - 04-29-2019, 02:52 PM
Anyone?
Default 04-29-2019, 09:03 PM
If you have an upgraded fuel pump- that can draw more current than oem- hence your EKP code- most ignore
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: JB535
Default 04-29-2019, 09:05 PM
No upgraded fuel pump. Just the most recent version of OEM installed by BMW in 2016.
No CELs but triangle dash warning for fuel pump at the end of 3rd pulls and at 3-4k WOT in 4 5 or 6.
Default 04-29-2019, 09:13 PM
Could be a failing EKP- any idea if you have EKP2 or 3?
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: JB535
Default 04-29-2019, 09:16 PM
Dumb question of the day, What's an EKP? How do I know which I have?
Would this relate to 2DED? I'm thinking high volt at FP could be related to 'short' causing 2DED, but...
Default 04-29-2019, 10:46 PM
Do a bit of research, but connecting the dots- more current draw could be causing that code yes.
A simple search of EKP here will net you the what is it answer & help you learn a bit more too
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: JB535
Default 04-29-2019, 10:55 PM
Seems like most update this when modding fuel pump. I have not. Wouldn't cause more draw when off right? It's when off for extended periods 2DED shows up. E.g. overnight.
