748adam 748adam is offline
Default Pure stage 2 inlet size question - 11-15-2018, 12:15 PM
Hi guys,
Iím about to order a set of pure hi flows and when looking at the compressor housing size,
I currently have stock location silicon intakes, will I be able to use head if I go to the 2ich upgrade? Iím guessing not but always worth asking. What power gains would I get by going to 2inch?
My overall power goal is 600hp with no ethanol as itís not available at the pump in the uk.
Adam
Default 11-15-2018, 12:32 PM
You will not be able to use those if you upgrade to 2". Stock inlet size is 1.75"
Ultimately it's up to you, I would go 2" if you're upgrading and sell those stock turbo inlets you have.
We have 2" inlets here:
http://www.burgertuning.com/N54_bmw_silicon_inlets.html
Car: 2007 e90 335i
Default 11-16-2018, 11:37 AM
If you order the turbos with 2 inch compressor inlets then you cannot use your current stock 1.75 size silicone intake inlets.
I personally have the pure stage 2 dd with the stock 1.75 compressor inlets with rob 1.75 silicone intake inlet *****. The 1.75 inlets are proven to make 600whp just fine.
Also 600whp is not a realistic goal with low octane 91/93 octane pump fuel. For that power level you need higher octane fuel like E85 or race gas like c16/q16/ 100octane. Or you would at least need meth/water injection.
2007 e90 335i
Default 11-16-2018, 01:31 PM
Thanks for the reply’s guys, was looking at port injection in the future wether it’s meth or extra fuel I haven’t decided yet.
JDangHTX's Avatar
JDangHTX JDangHTX is offline
Default 11-16-2018, 05:48 PM
From asking other users and vendors about this before, you can use the 1.75" Silicone Inlets on 2" CH inlets, but it will stretch.
Because I didn't want to deal with those problems, I returned my 1.75" VRSF Inlets and bought the 2" VTT Inlet/Aluminum Outlet combo kit for $275 to match up with my 2" Inlet on the VTT Stage 2+.
JDang - Catch me on the streets in H-Town
Default 11-16-2018, 06:36 PM
+1 on the 2" inlets. All that work to swap turbos, inlets have to come off anyway, might as well do it right.
