(#51)
PaulyD88 PaulyD88 is offline
Car: 2018 vw passat
Default 01-27-2019, 12:56 PM
Sweet thanks George. I ordered my connect today. So I'll give map 3 a try when I get it. What mods would be beneficial after that? I'm guessing trying to find a better intercooler?
PsychoDad PsychoDad is offline
Car: Skoda Octavia 2.0tsi 140kw/190HP,DQ380, IS20
Default 01-27-2019, 01:01 PM
Hi all,
Anyone with with Skoda installed it ?
Octavia 2018 - 2.0tsi 140KW/190HP, DQ380, IS20
soulrider4ever soulrider4ever is offline
Car: Mk7 golf r and 2019 beetle
Default 01-30-2019, 10:16 AM
In cooler weather on the Passat which has a different turbo to the rest of the Gen3B cars user are using map 2 or 3 or a custom map we set up for them.
Any idea what turbo this is? Closer to IS12? What kind of power are you seeing with this different turbo?
Default 01-30-2019, 10:48 AM
Not sure at this point. We still seeing around 200-205whp.
fenrik fenrik is offline
Car: Seat Ateca FR 2.0TSI
Default 01-30-2019, 02:50 PM
Have had JB4 running in my Seat Ateca FR, 2018 for some months now. Usually in map 2, sometimes in map 3. Always use 98RON gas (Sweden). Bought the unit from: https://www.jb4shop.co.uk (don't buy it from them, they sent the wrong unit!). George helped me with firmware and how to rebuild to work with 3B engine (Thank you very much!) Have had two problems with it the first weeks, draining the battery and parking heater triggering the alarm... Both quickly fixed by George!
Customer service is amazing!
I'm very satisfied with the results...
"my buttdyno loves the" new" engine"!!!
Car: 2018 vw passat
Default 02-02-2019, 07:05 AM
Hey guys so I got my jb4 connect kit installed and working, however the only gauges that are giving me a reading are the map and boost gauge. What do I need to do to get my other gauges reading? Thanks
Default 02-02-2019, 07:11 AM
Go to settings then user adjustment. Scroll down and you will find a parameter called Future use D. Check to see if there is 1 in the window. If not set it to 1 and save. Lock the car for a while so the JB4 can power down and it should start working on next start up. For guys reading this is a Passat specific setting and the other cars wont need it.
Car: 2018 vw passat
Default 02-02-2019, 09:30 AM
Ok thanks George! Your the best man. I'll try it out when I get home. I switched over to map 3 and it's running good so far and it's about 73 degrees out side
Car: 2018 vw passat
Default 02-04-2019, 07:07 AM
Is there a way to get the gauges to sweep on start up with the jb4?
Default 02-04-2019, 07:31 AM
Unfortunately not. The modules on the VW's do not directly connect like on other models we support hence why we also don't have steering controls etc.
Car: 2018 vw passat
Default 02-04-2019, 08:36 AM
Ohh ok thank you. Btw been running map 3 for a couple days now about 50miles no issues. Only upgrade besides the jb4 is a k&n filter and 93oct fuel
jnhalstead jnhalstead is offline
Car: 2017 Audi A3 FWD 2.0
Default 02-05-2019, 07:01 AM
George, any chance BMS will make a turbo inlet hose or even an intake for the Gen 3B? could eventually take the current 8V intake offered and cut it in half. My only option left is the Nuespeed TDI intake and making it fit. I just installed the CTS Turbo Inlet hose and I really noticed a difference.
JB4 - CTS Turbo Outlet Pipe/ Throttle Pipe / Turbo Inlet Hose - APR Turbo Inlet Pipe
17 A3|JB4|APR Turbo Inlet pipe|CTS Turbo Outlet Pipe, Throttle Pipe|aFe Dry Flow Drop in Filter
Default 02-05-2019, 07:08 AM
We can look at it if there is enough demand.
Default 02-05-2019, 10:13 AM
Thanks for the reply George, CTS just got back to me and said they have a Gen3B intake in development.
Kellen Kellen is offline
Car: 2018 Passat
Default 02-12-2019, 09:34 AM
Thats weird, cause they have had an intake for the Gen3B out for a while, although it dropped off their site when they launched their new website layout....
Default 02-12-2019, 11:55 AM
Only for Jetta and Bettle, not A3
https://www.bmptuning.com/products/c...ke-2-0t-gen-3b
Car: 2018 Passat
Default 02-12-2019, 12:02 PM
It was previously listed for Passat's
Default 02-12-2019, 12:51 PM
same intake, it has the opening for the MAF sensor, though it wont fit the Audi, totally different turbo locations.
Car: 2018 Passat
Default 02-12-2019, 01:02 PM
Sorry I thought you were asking about Passat's not Audi
HoTnFunkYGTI HoTnFunkYGTI is offline
Car: Polo GTI 2.0 2018
Default 02-13-2019, 05:55 AM
Leyo make an intake for the EA888 Gen3B
Leyo Motorsport Cold Air Intake Kit - Polo (AW) GTI 2.0T - Awesome GTI - Volkswagen Audi Group Specialists
If you live in the US its a bit cheaper, would say the EU price is a bit over the top.
Default 02-14-2019, 06:32 PM
Personally I’m look at getting a *** back exhaust. Like the standard sound for day to day driving, but wouldn’t mind a bit more of a growl. Like what milltek sounds like on the golf r but no valves on the other versions. Armytrix and IPE sound pretty good with very good valve systems but also very expensive...
So found this YouTube clip of Dutch manufactured custom exchaust, not big brand, but it sounds dam good. Imagine a few raspy high pitched crackles in there...
JMTuning - VW Polo GTI 2018 - Valve Exhaust loud. - YouTube
Also mounting my JB4 tomorrow, Done my running in of the engine 600/700 miles. How long does it take for the JB4 to get to know the engine, will you feel a difference straight away and what temps does it activate at?
Default 02-15-2019, 05:54 AM
It takes one or to full throttle runs to adapt. JB4 is active above 169F water temperature.
Car: 2018 vw passat
Default 03-01-2019, 11:14 AM
Anybody install a dv+ or a diverter valve plate on the 3b yet?
RLinePassat18 RLinePassat18 is offline
Car: 2018 passat 2.0 TSI R line
Default 03-01-2019, 11:57 AM
Was also wondering to, if its worth the money. I was thinking about buying it. But seeing how its not that easy to remove if you need warranty work done. I may wait
threefirs threefirs is offline
Car: MB C43
Default 03-01-2019, 08:49 PM
Iíve got a GoFastBits DVX on my MK75R.
