Default 12-06-2018, 08:12 PM
Originally Posted by RLinePassat18
Hi George any luck getting your hands on different plugs yet? Thanks!
Still working on it.
RLinePassat18 RLinePassat18 is offline
Car: 2018 passat 2.0 TSI R line
Default 12-07-2018, 09:58 AM
Ok great
John MK7.5 John MK7.5 is offline
Car: 2018 GTI
Default 12-26-2018, 05:46 AM
I just installed my JB4 and on my first drive the EPC light came on. I did some research and found that plug C could be the issue. I plugged in OEM plug and it runs fine now. Anyone else have this issue and does the jb4 still unlock all the potential power if one plug isnt connected.
Codes from JB4 app
426A
5A38
MK7.5 GTI PP DSG
Default 12-26-2018, 10:23 AM
Codes from JB4 app
426A
5A38
MK7.5 GTI PP DSG
Drop me a email at george@burgertuning.com
Probably the wrong VW unit for your car.
latar latar is offline
Car: Polo GTI 2.0TSI
Default 01-04-2019, 04:38 AM
After some cooling car made decent power in map 3. The turbo is a IS20 so there is more range for power and much more torque using map 6 when coupled with cooling mods.
Hi George, what cooling mods do you mean in here? Cooling for a dyno or a bigger IC?
Are you aware of any IC upgrades ready for purchase for the new Polo GTI 2.0TSI to become map 6 compliant?
Cheers from Poland
Default 01-04-2019, 06:59 AM
Cheers from Poland
In general, the IAT can climb 30C in a single pull through the gears. There isn't a cooler available yet. I know Wagner is working on one so it should be the first to become available.
HitmanHearns HitmanHearns is offline
Car: 2016 340i
Default 01-08-2019, 05:15 PM
Would we run into cooling issues on the 2018 A4 190hp models ? Or the cooling functionality is different between the A4 and what you are testing?
2016 340i M-Sport |JB4|ER DNPIPE|BMS Intake|
Default 01-09-2019, 06:08 AM
Less so with the 190hp A4 as the intercooler has a slightly different lay out and seems to be larger. Most users are in winter now so the data is not enough to be conclusive.
In the next few weeks we are fitting on A4 that are in hot climates and will have a better idea.
creepingKrawler creepingKrawler is offline
Car: 2010 335xi
Default 01-10-2019, 08:11 PM
So this seems to be a little bit diff than the n54 jb4 (ran with BEF) I have & have a few questions.
Read the install pdf, what is the obd2 cable for? What about spark plugs from a gti or r? You think the turbo has around 60hp in it, is that on pump gas? Will I be able to take advantage of alcohol injection? Im guessing accessing command mode through the steering controls isnt possible? Does the app or laptop have access to all the same functions?
Default 01-11-2019, 07:19 AM
Only way to access is via the app or laptop. In terms of adjustment you can do boost and fuel.
OBD wire feeds engine data to the JB4 for mapping purposes.
The steering wheel module is not directly linked as the vehicle network is separated with various modules so we cannot do steering wheel controls unfortunately.
jnhalstead jnhalstead is offline
Car: 2017 Audi A3 FWD 2.0
Default 01-11-2019, 10:12 PM
George, any updates on the 3B? Any luck with the intake plug?
Default 01-12-2019, 09:43 AM
Do you mean for the MAF sensor in the intake?
Default 01-13-2019, 01:00 AM
indeed
17 A3|JB4|APR Turbo Inlet pipe|CTS Turbo Outlet Pipe, Throttle Pipe|aFe Dry Flow Drop in Filter
Default 01-13-2019, 06:52 AM
indeed
There was no benefit. At a certain load point the ECU starts ignoring it (we testing with it unplugged as well with no performance difference).
Lifesgood Lifesgood is offline
Car: 2018 Polo GTi
Default 01-14-2019, 01:54 PM
We got around 30 testers now and still evaluating . So far so good.
Any feedback from testers?
Litspeed Litspeed is offline
Car: Tiguan
Default 01-14-2019, 07:56 PM
I would like that as well......all feedback!
Tom
rsivan rsivan is offline
Car: VW
Default feedback - 01-15-2019, 05:56 AM
I have JB4 fitted on gen3b T-Roc 190cv TSI and work great!,zero problems.
Car: Tiguan
Default 01-16-2019, 06:00 AM
What about performance?
Car: VW
Default 01-16-2019, 10:53 AM
I did not test on dyno,however map2 and map3 are ok both no holes or error , we running here 95RON fuel as std,
I have now map6 at 4.5psi max ,comparing with my previuos gen3 tuned by flash I think is over 50ps+ the more gain is from 4000rpm to 6000rpm ,before was very weak in this range.
Car: 2018 Polo GTi
Default 01-20-2019, 01:30 AM
In our own stable we have both a US Tiguan as well as a Polo GTI 200hp
Had the Polo GTI on the dyno for some preliminary map testing. Gains seemed to be good on map 3 but the car has heat soak issues with the smaller front mount intercooler.
George, I have the JB4 now fitted to my Polo. Should map 3 be OK as it is - 1 outside
Default 01-20-2019, 06:33 AM
Yes, it should be good.
L32 L32 is offline
Car: Tiguan
Default 01-20-2019, 11:39 AM
which is the difference between the tiguan and polo gti?
there is some engine difference? or is just the ecu map?
i mean, you can get some decebt power on the gti but not on tiguan.
Default 01-21-2019, 05:49 AM
At this point it is unknown if there are any engine variances which I doubt. The variance is most likely mapping. On the Tiguan the base ECU tune does not allow for similar boost levels for consistent power at this level.
PaulyD88 PaulyD88 is offline
Car: 2018 vw passat
Default 01-27-2019, 06:19 AM
Hi everyone, just got my g8 jb4 installed on my 18 Passat. Anyone on here have the Passat also? Are you using the connect kit? Is it worth it at this stage of the jb4 just being released for our engines? If so what map is safe to use on us 93oct pump gas with no other mods. Thanks!
Default 01-27-2019, 11:19 AM
In cooler weather on the Passat which has a different turbo to the rest of the Gen3B cars user are using map 2 or 3 or a custom map we set up for them.
