Default ** AUTHENTIC ** Bosch 4bar sensors finally in stock! - 06-15-2018, 04:51 PM
As most know we released a 4bar adapter and sensor kit a couple years ago. And while it worked really well for some, others found the sensors went out on them after a few weeks or months.
It took a few months to get to the bottom of it but it turns out that the majority of Bosch 281002576 4bar sensors out there are counterfeit and not as reliable.
Fortunately we were able to track down known authentic sensors at a decent price (in volume) and are again able to offer 4bar sensor kits.
The fakes look really good, it's hard to tell the difference. But I put together a couple of photos to help you spot it. The best clue is that if you paid less than $100 for the sensor itself it's probably not authentic.
You can order the sensor kits from us here: http://www.burgertuning.com/JB4_upgrades.html
If you bought one of the kits from us and want to upgrade to one of these higher quality authentic sensors no problem, we can upgrade the 4bar sensor for $50 + shipping for you (half off). Just email us with your orignal BMS order number and we'll help get you sorted.
tofu tofu is offline
Car: 335i e92
Default 06-15-2018, 06:27 PM
Hey Terry,
I've been dealing with 2ABD codes on and off for a long time now. Changing values to account for elevation never did anything to help.
I purchased my 4 bar sensor on 5/22/16 for $99. Am I likely in the counterfeit sensor crowd?
Default 06-15-2018, 07:14 PM
Yes all the kits we sold were suspect as are any sensors bought on eBay, Amazon, etc, or anything that was less than $100 itself for the sensor. The suggested retail price on the sensor itself is in the $150 range.
Car: 335i e92
Default 06-15-2018, 07:35 PM
Were these advertised as "bosch sensors" on your website at the time of sale, or just generic 4bar tmaps?
Default 06-15-2018, 07:44 PM
4bar 281002576 sensors. Which is what the box and sensor says. I'm willing to bet 90% of the people running 4bar sensors are running fakes which is why we hear about so many problems with them across all platforms.
If you got one of the old 4 bar sensors from us and are unhappy with it you're welcome to return it. Just ship it back to the address on our site along with a copy of your receipt from us.
The purpose of this thread is to inform people that we've learned most sensors out there are fakes and we've found a good supplier for authentic sensors.
Car: 335i e92
Default 06-15-2018, 07:45 PM
got it. thanks
Car: 2008 E93
Default 06-16-2018, 01:15 PM
Terry, have you tryed the authentic sensor to see if 2ABD is resolved ? Thats my main issue with the sensor I picked up from you.
Car: 335i e92
Default 06-16-2018, 01:23 PM
That was my issue as well. I don't need the 4bar -- just bought it because it was cheaper than an oem sensor. I always chalked up the 2abd to user error, but ive tried everything over the years from voltage adjustments to changing boost solenoids. Turns out it was likely the sensor.
Default 06-16-2018, 01:39 PM
There are lots of different issues that can cause fault codes, most of them software related. 2ABD normally is a BEF scaling issue. We're running these sensors in our development cars but those cars never had an issue with previous 4bar sensors, so likely bad candidates for evaluation.
Default 06-18-2018, 07:26 AM
Dang, I think I lost my receipt.
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 06-18-2018, 02:13 PM
Good news Terry. Finally good to see the 4 bar option return.
Nice job providing the comparison between authentic and fake 4 bar sensor features - that's critical for anyone who currently has a 4 bar.
2017 AMG C63 -JB4
2009 535i - 548whp - sold
Default 06-18-2018, 04:13 PM
Then it's full price for you!
defineste90 defineste90 is offline
Default 06-25-2018, 05:44 AM
would the counterfeit one cause a code to be thrown for this sensor?
Default 06-25-2018, 08:12 AM
What code?
Default 06-26-2018, 05:11 AM
What code?
these are the codes i have coming up doing some research last night i have some things to check on also but here they are
2ABC - BOOST-PRESSURE SENSOR, ELECTRIC
2C9E - OXYGEN SENSOR HEATER AFTER *** : ACTIVATION
2C9F - OXYGEN SENSOR 2 HEATER AFTER *** : ACTIVATION
2D33 - ABSOLUTE-PRESSURE SENSOR, INTAKE MANIFOLD: SIGNAL
3DED POWER MANAGMENT, CLOASED-CIRCUIT CURRENT VIOLATION
3100 BOOST PRESSURE CONTROL
this is how i got it back from the shop that did the single turbo swap so now im left with just doind it myself. but im trying to take out one code at a time. but i know some are probably related to others just want this thing to run right!!!
Default 06-26-2018, 10:13 AM
2ABC could be a failed sensor code, or setting on the JB4 or BEF.
Default 06-26-2018, 11:07 AM
thanks terry! where would that setting be i switched from the 3.5 bar sensor to this 4 bar sensor. i got it back when u first released them(2yrs ago maybe) havent pulled it out yet to check if its a fake or not
Xshadows Xshadows is offline
Car: 2008 135i
Default 06-26-2018, 11:30 AM
Good to know, I had a 4 bar from you guys and swapped to a 3.5 after having a lot of issues with it.
DocRace Top Mount w/ Precision BB 6266 - JB4 G5 - BMS Pump flash - 650HP AD-E Intercooler - BERK Race Exhaust - Fuel-It Stage 2 Fuel pump - ER Chargepipe w/ TIAL BOV - 560whp @ 20psi on 93 octane only
Default 06-26-2018, 11:53 AM
For the 3.5bar TMAP = 1 is the setting and the default back end flash maps should work fine with it.
Default 06-26-2018, 06:19 PM
Would 2ABC cause 3100? Nvm everything came back
Default 06-27-2018, 09:06 AM
Yes, 3100 just means you have low boot mode from some code like 2ABC.
Default 06-27-2018, 09:12 AM
what should voltage be to the tmap sensor i was showing 1.97
Default 06-27-2018, 10:00 AM
That app value is rescaled to the stock sensor regardless of what actual sensor is installed. So if you want to do diagnostics you could measure the actual voltage on your sensor. In the DME box it's the yellow JB4 wire on the male side of the connector.
rsh_n54 rsh_n54 is offline
Car: Bmw N54 335
Default 06-28-2018, 03:34 AM
Hi Terry
I am not very "electrical" inclined, do you have any tests you can recommend to see if my 3.5bar sensor has failed?
Default 06-28-2018, 08:29 AM
Rare a 3.5bar fails unless you got it off Amazon or eBay (those are all fake sensors). But you could check it's voltage ign on, engine off. At sea level should be around 1.2v.
