(#76)
luchocamp's Avatar
Default 02-06-2018, 02:03 AM
100 octane fuel. Graph showing Meth ... working WGDC/WGP/DB
10.64 @129mph, MHD Custom + #LUCHOJB4, E40 + meth ~ Drag Track online set up on instagram @luchocampusano ➡
Frikiton's Avatar
Frikiton Frikiton is offline
Car: 2016 F25 X4 M40i (N55)
Default 02-09-2018, 10:45 AM
Originally Posted by luchocamp
protuningfreaks + jb4
try latest OTS they released for 2H (Upgrade Turbo Map)
15psi with better JB4 tune #luchojb4
Very good for 15psi, also try map0 or 4 (letting OTS map run boost) to compare
F90 M5 Comp - @BM3Tuning 100-200 5.29s / 60-130 6.5s | @HCP.US
F97 X3M Comp - Tuning Soon!
F80 ZCP DCT Tune Only | @BM3Tuning Stg1+ E85 60-130mph 6.7s "World Record Dragy Verified"
luchocamp's Avatar
Default 02-12-2018, 06:00 AM
I tried OTS 2H is good 11.75@118mph with dragy same boost...is a map for 93 oct.
Frikiton's Avatar
Default 02-12-2018, 01:20 PM
Add more boost on that OTS
terryd5150's Avatar
terryd5150 terryd5150 is offline
Car: BMW 335xi
Default 02-12-2018, 04:29 PM
So you're saying that BM3 map with a JB4 for PS2/Stage 3 turbo set-up?
luchocamp's Avatar
Default 02-13-2018, 06:17 PM
Yes you could use it as bef map and fine tune with JB4.
Bimmer_Boost's Avatar
Car: 2011 e92 335i
Default 02-13-2018, 06:24 PM
I would love to see some pump gas (91 - 94 octane) logs. It would be nice to know where timing is at a certain boost pressure and when the newer style HPFP gives up.
2011 E92 335i Auto
12.0 @ 125MPH JB4
Sold
VRSF Chargepipe | BMS Intake | JB4 ISO | N20 TMAP | VRSF 7" Intercooler | ER Turbo Outlet | XHP Stage 2 | BMS Methanol Injection |
terryd5150's Avatar
Car: BMW 335xi
Default 02-13-2018, 09:21 PM
Thanks.
There's amazingly little info as to how to tune a big turbo on an F3x N55 (other than the obvious custom tune).
I was looking for how to get by until I could arrange a custom tune.
luchocamp's Avatar
Default 02-14-2018, 05:04 AM
Originally Posted by Bimmer_Boost
I would love to see some pump gas (91 - 94 octane) logs, even if they are only screen shots. I would be nice to know where timing is at a certain boost pressure and when the newer style HPFP gives up.
I will do that later 93 octane fuel and E30 mix.
luchocamp's Avatar
Default 02-18-2018, 12:01 PM
Today some test STOCK TUNE ( oem ) just JB4 IS0 10 control everything.
Car: 2011 e92 335i
Default 02-18-2018, 12:05 PM
It's not that hard to post CSV files.
2011 E92 335i Auto
12.0 @ 125MPH JB4
Sold
luchocamp's Avatar
Default 02-18-2018, 12:07 PM
11.65 @ 121mph stock tune / 16.5psi prom
135idct 135idct is offline
Default 02-18-2018, 01:53 PM
why u convert to jb4 only & stock tune ? any problems with BM3?
luchocamp's Avatar
Default 02-18-2018, 04:31 PM
I had a voltage problem during a flash and had to go Stock Flash for last 7 days.
Problem with OB2 EN cable but I will be back with ACF Performance Tune soon and raise boost to 20psi and see how it goes.
Default 02-19-2018, 02:40 PM
it looks to me like your wgdc is not right. Boost not hitting target. I think we need to work on the tuning side to get wgdc tables right for upgraded turbo n55's. I have been looking around a bit and I dont think we are really there yet, but I think there are several people in the background working it. You are pulling good times, if you are good with the logs. I am having the same issues. Going to try to dial in pid or go to wgdc override, we will see.
luchocamp's Avatar
Default 02-19-2018, 02:44 PM
best e.t. to date .... ACF tune back on the car
WaqasRiyami's Avatar
WaqasRiyami WaqasRiyami is offline
Car: Bmw 535i - 2011
Default 02-19-2018, 02:57 PM
Do you have ps2 or ST3 ?? I see them both in your signiture
2011 F10 535i N55 PWG 8AT | "Pureboost.de Tune" + MHD Flasher | xHP Stage 3 transmission Tune | N20 3.5bar TMAP Sensor | Pure Stage 2 Turbo | GFB DV+ | Fuel-It Stage 2 LPFP | 93 Octane Fuel | BMS Intake | ER 4" CLess D/Pipe | ER 3" Charge-Pipe | Wagner-Tuning Competition Intercooler | Custom Turbo Inlet Pipe | https://i.imgur.com/iR4wm3I.jpg |
luchocamp's Avatar
Default 02-19-2018, 03:05 PM
now Speedtech Stg 3
luchocamp's Avatar
Default 02-20-2018, 03:10 AM
PWG is different than EWG.
I'm having fun dialing with JB4 ISO 10 ....
The car now at 17psi aprox is as fast as 2017 with oem manifold and PS2 max out 24psi.
luchocamp's Avatar
Default 02-20-2018, 07:53 AM
now 11.48@123.4mph with dragy
JETmn JETmn is offline
Car: 2011 335xi
Default 02-20-2018, 08:21 AM
Is that still at 17psi?? If so, holy crap! Following this intently, awesome job!
luchocamp's Avatar
Default 02-20-2018, 08:37 AM
Yes, working on boost control ... 17psi prom
luchocamp's Avatar
Default 02-20-2018, 08:55 AM
Car: 2011 e92 335i
Default 02-20-2018, 01:04 PM
Don't want to take away from your great results but I trapped 125 mph on 20 psi (10 degrees of timing) and 120 mph on 16 - 17 psi (average timing of 10 degrees) with the PS2. Your timing is higher than most people run so it isn't fair to compare power at the same boost level. I completely understand that the Speedtech kit is less restrictive and will make more power. I also understand that the xDrive system will add more drivetrain loss compared to my RWD.
2011 E92 335i Auto
12.0 @ 125MPH JB4
Sold
luchocamp's Avatar
Default 02-20-2018, 02:52 PM
Just keep watching .... I will upload dyno comparisson soon. Same car, same fuel, same dyno. Only manifold/turbo difference.
