(#51)
Default 02-22-2018, 09:44 AM
Originally Posted by themyst
Hi, anyone having issues with the 5A firmware popping an EPC when you try to connect to the unit while the car is running? Using iOS app with rev3 bluetooth module.
Will give this a try. Yours is the only report of this. Is it happening at idle or when you moving?
blackout1231 blackout1231 is offline
Car: 2014 Jetta GLI Edition 30
Default 03-09-2018, 07:12 PM
Anyone else's car going through gas like crazy with their new JB4 (latest firmware)?
Default 03-10-2018, 04:08 AM
If your driving style has stayed the same it shouldn't change by much if not drop a bit.
Make sure the AFR connection is on the primary O2 sensor and not the secondary which goes to after the ***. We have seen cars with the wrong connection run pig rich on part throttle driving due to this.
r_diaz13 r_diaz13 is offline
Car: Jetta GLI MK6
Default 03-12-2018, 08:00 AM
I would say slightly higher but it could be me having too much fun. I'm getting my Unitronic turbo back exhaust and expect some increased airflow but will be monitoring everything closely for a few days. I'm going to run a few days with Map2 and then Map4 and just log.
sextonracing@ymail.com sextonracing@ymail.com is offline
Car: 2014 vw gli
Default data logging issues - 03-23-2018, 06:55 PM
i have just installed my jb4 beta unit in my 2014 vw GLI and am using the data cable.. i have the firmware installed and have some communication back and forth i currtently have it on map 2... i am having issues trying to start a log
Default 03-24-2018, 04:12 AM
Do you see the data in the logging window moving? If not set the Future use D value to 1 and see if that works. Also the car will only log above a certain amount of load.
Car: Jetta GLI MK6
Default 03-30-2018, 10:51 AM
Just installed my unitronic full turbo back running map 2 and man what a difference. Feels borderline reckless at full boost and load. Very different car. I'm going to run it a bit like this and then get a log to work with BMS. Want to make sure it's running tip top in the Florida heat
BlkSTIG BlkSTIG is offline
I used to be cool.
Car: 2014 VW GLI
Default 04-12-2018, 06:45 PM
Yeah the same here. Installed JB4 a week ago. I used to easily clock over 310 mile per tank and since I installed JB4 clock 280 per tank.
My driving style hasn't changed and I'm certain it's connected to the primary O2.
14' VW GLI / Unitronic Stg 2+JB4 stacked / CTS turbo back exhaust / USP intake / Unitronic intercooler / Neuspeed Rse10's
themyst themyst is offline
Super Demigod
Default 04-12-2018, 07:19 PM
It was a one-off situation, but I haven't really connected to my JB4 recently. But from what I remember, I was accelerating (not WOT) and moving when the EPC popped.
E90 LCI N54 6AT
Super Demigod
Default 04-12-2018, 07:22 PM
George:
Has anyone ever reported undesirable DSG shifting behavior with the JB4? Occasionally, the DSG will shift extremely slowly and/or throw tach warning light with the JB4 installed. I recently took it off and trying to replicate it stock, but nothing so far.
E90 LCI N54 6AT
Default 04-19-2018, 08:54 AM
George:
The only thing that can affect the DSG shift speed to the point where its slow is a stored code. Usually the one we see most often is a misfire code.
The tach warning light could be related to the camshaft plug if the harness is a earlier Rev1.
Car: Jetta GLI MK6
Default 05-09-2018, 03:20 AM
It's been kind of quiet here. I'm enjoying my current setup just keeping it in map2. It's a completely different car when I need it to be.
tutuco's Avatar
tutuco tutuco is offline
Car: Audi A3
Default JB4 Features Roadmap - 05-14-2018, 07:34 AM
Hi all,
@George @Terry do you have any roadmap to share with us JB4 users?
New Features or New products?
Regards,
Tutuco
Default 05-15-2018, 08:12 AM
Originally Posted by tutuco
Hi all,
Regards,
Tutuco
We always working on something but nothing at the moment for immediate release JB4 wise.
We have been working on a intercooler and once we happy with fitment will go to production and it will be the next hardware item we release for MQB.
Penetrator7 Penetrator7 is offline
Car: M135i
Default 05-19-2018, 01:40 AM
Still no solid date for RS3 JB4 roll out then gents?
Nappy216 Nappy216 is offline
Car: 2017 VW Golf GTI
Default Latest FW - 05-19-2018, 02:45 PM
Have an interesting issue with the latest firmware. (VW_JB4_OBDII_6B.hex)
My map6 setting don't seem to stick.
I had the following.
1500 0
2000 1.0
2500 2.0
3000 2.5
3500 3.0
After the update
3000 = 2.6.
I can't set it back to 2.5.
2.4 or 2.6 works. 2.5 gets rounded up to 2.6. 5.2 goes to 5.3.
Not really a bid deal but wondering if anyone else has seen this?
Latest FW did fix the code reading. I had no codes before the update after I got the low fuel pressure code.
Default 05-19-2018, 06:04 PM
The values are bytes internally, but we squeeze in a 0-36psi boost value, so depending on the value it may round up or down 0.1psi to fit the storage space.
Car: Jetta GLI MK6
Default 07-05-2018, 06:23 PM
It's been kind of quiet here. No update on a new firmware? I remember seeing there's something in the works for"self-tunning" which sounds extremely promising.
Default 07-06-2018, 02:07 AM
Nothing major in the near horizon. We going to be putting up a small update with a minor revision that further improves part throttle smoothness in the next week.
mavalenca's Avatar
mavalenca mavalenca is offline
Car: Jetta MK6 2.0 TSI 211CV
Send a message via Skype™ to mavalenca
Default 07-26-2018, 09:51 AM
I also remember seeing something like that...
Default 07-27-2018, 04:35 AM
This is something we still evaluating. The ECU is very adaptive and it makes things harder when the ECU is going to adapt as well as the JB4.
CrAzY-HoRsE CrAzY-HoRsE is offline
Car: SEAT Leon Cupra 290 (2016)
Default 08-28-2018, 01:00 PM
Any news on the new FW release?
Default 08-28-2018, 03:26 PM
George has firmware with a new map4 valet map floating around, if that works well we'll be making some nice adjustments to boost by gear settings too.
Default 08-28-2018, 04:16 PM
So far so good. Should put it up here in page 1 by next week.
I can recall you had the 245hp PP GTI. We managed to get a Skoda vRS 245hp on the dyno in the UK recently. Car runs a Euro 6 ******** and some airbox mods. Graph looks excellent with good AFR. Map 6 was used with 6psi over stock.
Default 08-28-2018, 04:22 PM
That's awesome.
