mightbaal mightbaal is offline
Car: 2008 335xi
Default Going to the track today need a log review please new NGK 5992 plugs. - 10-05-2017, 02:44 AM
Just put in some NGK 5992 plugs E85 BEF E60 gas FBO+inlets 335xi N54
2008 335xi FBO JB4 BMS E85 Backend flash E60 Gas VRSF Chargepipe /w HKS BOV VRSF 7 inch FMIC DCI VRSF DOWNP xHP Stage 3 flashed
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 10-05-2017, 09:03 AM
Timing and I_Avg look excellent and consistent across all cylinders, so plugs must be working as intended.
Might be able to use some duty bias turning at the top end where you are a little under target, but I'm not sure your turbos have any more to give as PWM is nearly max.
Default 10-05-2017, 09:16 AM
How does it look post shift? No PI or WMI so fuel pressure will be the issue I think.
Car: 2008 335xi
Default 10-05-2017, 01:24 PM
Yea I sometimes under WOT get a injector fuel shutoff code? Possible hpfp not supplying enough pressure? It will happen at shifts I overboost alittle too. Do i just have a weak hpfp? It's 2 years old the lpfp is stock (well a Chinese knock off).
Default 10-05-2017, 06:20 PM
Take another log if you can 3rd gear, redline, shift into 4th, and stay in it as long as you are comfortable.
Curious to see post shift timing & fuel
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: 2008 335xi
Default 10-06-2017, 01:03 AM
Alright I am going to post 3 logs in separate replies the
1st log (this post is gears 3 to 4 and a little into 5 roads were damp so I didn't feel like dying at 140+ lol)
2nd reply will be the log gears 1-2-3-4 which I have problems with when I do this my avg_ign climbs like crazy
3rd reply will be an actual log I got the injection shut-off code that makes the car run like crap until cleared
Car: 2008 335xi
Default 10-06-2017, 01:06 AM
This is my problem section on a boost launch it runs like crap and AVG_IGN spikes like crazy IGN_1 looks odd to me Im no expert tho
File Type: csv 2017-10-06 02_43_57GEAR-1-2-3-4PROBLEM.csv (11.8 KB, 48 views)
Car: 2008 335xi
Default 10-06-2017, 01:07 AM
This log I took 3rd gear where my cylinder injection shut-off
File Type: csv 2017-10-06 02_45_00CYLINDERINJECTIONSHUTOFF.csv (10.7 KB, 48 views)
Car: 2008 335xi
Default 10-11-2017, 08:51 PM
Anyone?
Default 10-12-2017, 04:27 PM
I don't see the fuel system shutting down in that last log but it does appear that you are pushing the limits of your HPFP.
FYI...best to just post and discuss one log at a time...if you make it too involved, complicated, people will just pass it by.
Car: 2008 335xi
Default 10-12-2017, 05:01 PM
Do you Think my AVG_IGN is increasing on the post shift logs due to the HPFP lagging? Btw the HPFP is only 2 years old the LPFP is a stock chinese made one from 2 years ago.
Default 10-12-2017, 07:13 PM
No, I avg is not affected by the rail pressures.
Car: 2008 335xi
Default 10-12-2017, 07:21 PM
I just wonder why my AVG_IGN keeps raising on the shift logs but lowers when single gear pulls and what I can do...
Default 10-14-2017, 10:41 AM
Could be due to knock or false knock. If you believe it's false knock, see if the KR map improves it.
Car: 2008 335xi
Default 10-14-2017, 03:41 PM
Correct me if I'm wrong but I do think it's false knock but running those maps are riskier correct? I would rather be on the safe side tbh...
Default 10-15-2017, 03:39 PM
That is correct.
