mcjoe691 mcjoe691 is offline
Car: 2015 M3
Default 2019 M2 Competition - 02-25-2019, 08:26 PM
Terry anything for the M2C ?? I still have my JB4 from my m3 2016 ....thanks
Default 02-26-2019, 09:35 AM
Our S55 JB4 is fully compatible.
trebila's Avatar
trebila trebila is offline
Default 03-20-2019, 07:04 AM
I've tuned one last weak, uncatted, no particule filter, straight pump gas:
here is a log from the dyno:
and the dyno graph:
it built 540 whp / 830nm
fordnox fordnox is offline
Car: e92
Default 03-28-2019, 10:26 AM
Since the m2c is detuned, how does the jb4 add boost?
Absolute or refered to stock boost?(for instance 16 psi, or just +3psi)
Br
F87 M2C
Default 03-28-2019, 11:25 AM
Br
You can use both additive or absolute maps. I suggest starting with the additive maps like map1 or map2 so we can evaluate your fuel. While boost is lower than say an M3/M4 timing is set higher, so it's not as easy as just running the same boost targets as our M3/M4 tuning. That is, unless also adding our back end flash maps.
Car: e92
Default 03-28-2019, 02:07 PM
Thx so there is no way to use additive maps bases on stock m3 tune?
F87 M2C
Red Speed Red Speed is offline
Car: BMW M2 Competition
Default 07-30-2019, 02:02 AM
hi Guys
I have an M2 Competition with Map2, now I want to add 2.5 PSI from 5000 rpm. So it's like M3, M4.
Terry is the logg MAP2 ok?
Many thanks..
Default 07-30-2019, 09:19 AM
Post the CSV file, not a photo.
Default 07-30-2019, 09:48 AM
Ok hope that's good..
Default 07-31-2019, 07:47 AM
Could someone please check my logging
Many thanks
Default 07-31-2019, 11:02 AM
Looks very clean and strong to me! How does the car feel?
Default 07-31-2019, 12:40 PM
He runs good, but I want more
Default 07-31-2019, 12:41 PM
Can you help me with Map6?
I would like to make the difference to the M3 M4, which have about 2psi more...
M-terkait's Avatar
M-Terkait
Car: F30 335i
Default 08-01-2019, 02:56 PM
But why is the target very low? 10-5psi
N55 - Doc race 6266.
Default 08-02-2019, 10:03 AM
It's the additive map which means target boost plus the stock boost request.
Penetrator7 Penetrator7 is offline
Car: M135i
Default 08-12-2019, 08:35 AM
Just to,confirm, if I buy an S55 platform JB4 it will work correctly on my M2 Competition is this right??
Default 08-12-2019, 11:16 AM
Yes
Car: M135i
Default 08-12-2019, 11:41 PM
Yes
Thanks mate
