Pure Turbos's Avatar
Default N55 PURE Inlet Pipe Tested - 09-22-2016, 06:15 PM
This week we had the opportunity to get some before and after PURE inlet pipe results. It seems the stock inlet pipe causes restriction above 400whp. This customer's PURE Stg2 car was capped around ~410whp. Only thing is it didn't have a PURE HiFlow inlet pipe. So we added one and were surprised to find it unleashed a lot of power! It made a ~40whp gain at the same boost pressures, and enabled us to later crank up the boost and hit 500whp.
We normally recommend the inlet for all PURE Stg2 customers. We will now consider them required. Available for E and F series N55.
Mike_L's Avatar
Mike_L Mike_L is offline
Anti-Social
Car: 2017 X3 xDrive35i
Default 09-22-2016, 06:18 PM
So what about right at 400whp? Should I buy one? Stock turbo.
Mike Levy
2017 X3 xDrive35i
2000 F150 Lightning
2018 Equinox LT 2.0T
Default 09-22-2016, 06:26 PM
We didn't test stock turbo. The PURE Stg2 car made more power with the inlet at even lower boost levels, 16-17psi. Yes, we suggest you buy one.
Bimmer_Boost's Avatar
Car: 2011 e92 335i
Default 09-22-2016, 07:07 PM
I did not see any change with the inlet in my logs with the stock turbo. I think since the stage 1 and 2 have bigger openings for the impeller you will see a result over the stock inlet fitting the stock turbo.
2011 E92 335i Auto
12.0 @ 125MPH JB4
Sold
VRSF Chargepipe | BMS Intake | JB4 ISO | N20 TMAP | VRSF 7" Intercooler | ER Turbo Outlet | XHP Stage 2 | BMS Methanol Injection |
911Y4's Avatar
911Y4 911Y4 is offline
Car: 435
Default 09-22-2016, 07:13 PM
Huge difference, very impressive!
Default 09-22-2016, 07:30 PM
We didn't see any change in the logs either. Just power to the ground!
Mike_L's Avatar
Anti-Social
Default 09-22-2016, 07:37 PM
We'll see. I just ordered it. I'll hit the dyno afterwards to find out.
Mike Levy
2017 X3 xDrive35i
2000 F150 Lightning
rwalker rwalker is offline
Default 09-22-2016, 07:52 PM
I can vouch for spooling gains with Pure's inlet and the stock turbo. I had to dial back Duty Bias from 1500-5000 RPM because I was overboosting once I installed the Pure Inlet.
I'm FBO, and I run 100oct on map7. I also have a map6 that follows map7 with less taper up top.
rwalker@rwalker.com (I really dislike private messaging)
nickshih nickshih is offline
Car: F10 535i 2011
Default 09-22-2016, 09:06 PM
hi Pure
will you have inlet pipe for F10 535i ?
the difference is huge on your dyno result .
Peter @ Pure's Avatar
Car: F20 M135i
Default 09-22-2016, 10:30 PM
When I first had my stage2 turbo in March 2015 there was no inlet pipe on F series. Nor was there a DV upgrade. I was able to run +- 20-21 psi on just 98 or E20 mix and meth. Doing 100-200 kph in 7.2-7.3. But going faster was not possible. Then I got the inlet pipe and at same settings could do 6.7-6.8 100-200. This shows how much of a restriction the stock inlet is.
The inlet upgrade is a must for stage2 turbo.
F21 M140i - 100-200: 6.95
Audi TTRS - 100-200: 4.47 60-130: 5.16
F80 M3 - 100-200: 4.45, 60-130: 5.1
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
neejay's Avatar
neejay neejay is offline
Car: 2011 535i M-Sport
Default 09-22-2016, 11:25 PM
"135/335 only, does not fit 535" Welp, I'm out. I hate that I prefer 4dr + space...seems like most of the N55 tuner items get made for the 3/4 series.
2011 535i M-Sport - MHD Stage 2+ BEF w/ JB4 (logging), xHP Stage 3, BMS Intake, FMIC, ER Chargepipe, RM Motors catted d/p, Megan Racing Supremo Exhaust
Car: F10 535i 2011
Default 09-23-2016, 12:08 AM
I already put pure stage2 turbo into my 2011 F10 535i.
It is amazing by this upgrade . i suggest that you can try it .
Mike_L's Avatar
Anti-Social
Default 09-23-2016, 05:08 AM
Not an excuse. My little 335GT has more interior space than your 5. It may look stupid, but it's got the biggest interior short of the LWB 7.
Mike Levy
2017 X3 xDrive35i
2000 F150 Lightning
Weehe Weehe is offline
Default 09-23-2016, 06:04 AM
I have an inlet waiting to go in on my stock turbo. I was thinking of making an insert to make the lip of the stock turbo a smoother transition. Just need to find plastic to make it out of. These results make me think it will help a stock turbo too.
Bee Pee Bee Pee is offline
Car: BMW F20 m135i
Default 09-23-2016, 07:45 AM
I will be dyno-ing my EWG car in late Oct to re-fettle map 6 on stock turbo once I install Wagner FMIC, ER charge ***** and Pure inlet pipe......
F20 M135i EB AT with options - what a hoot !
DB90 DB90 is offline
Car: M135i
Default 09-23-2016, 02:40 PM
If you are running high boost on the oem EWG turbo I'd definitely recommend the Pure hi flow inlet. I seen a nice reduction in PWN at the same boost levels pre and post inlet.
Now that I'm running 20/21 psi peak and holding on to much more boost up the Rev range, the inlet has definitely helped me achieve that.
Get it done people!
M135i 8AT / JB4 + EWG Harness / N20 TMAP / VRSF 5" HD FMIC / Fuel-It TBI / Fuel-It STG2 LPFP / Pure High Flow Inlet / FTP Charge & Boost ***** / Richter ***** / Backbox delete / E50 Fuel / ngk 5992s / BBS CH-R's / KW V3 Coilovers / M4 LCA's / GP Front Splitter & Side Blades.
100-200kph: 7.8s
1/4 mile: 11.9s @ 120mph
Default 09-23-2016, 02:43 PM
DB90, can you share your map6 targets and Duty Bias?
Car: 2011 e92 335i
Default 09-23-2016, 04:07 PM
Get it done people!
I was targeting 20 psi before and after the inlet on the stock turbo and saw no change in quarter miles times or my logs. I think it is great if some people are seeing results on the stock turbo and I agree this should be required for the stage 2 turbo. I am just trying to set realistic expectations for future buyers of just the inlet. You may or may not see a difference.
As Pure has shown and Darkiedm4 has said, you will see the difference with the stage 2.
I looked around for almost a month trying to find any documented results on the stock turbo with the inlet before picking mine up. I knew I would be buying the stage 2 so if it did not show any gains the investment would not be a waste. In my research I saw that Pure said they purchased a dyno and would dyno the results at some point. If any gains were shown with the stock turbo I am sure sales would go up.
Keep in mind this is for the E series PWG turbo.
2011 E92 335i Auto
12.0 @ 125MPH JB4
Sold
Car: M135i
Default 09-23-2016, 10:37 PM
I can't find my log/support thread on my phone but I know you've commented and seen the DB settings etc.
Yup for sure, I have no experience with the E series PWG but the f series EWG turbo flows much better from what I have seen I've basically got a pure stage 1 boost curve now with the stock EWG turbo. My vbox times also match very closely to Peters (darkiedm4) car when he was on pure stage 1 to add even more evidence.
Unfortunately I won't be removing the inlet just to see what difference going back to the stock inlet will do.
100-200kph: 7.8s
keyap keyap is offline
Car: N55 135i
Default 09-24-2016, 10:13 AM
@ Pure - don't suppose you fancy taking a look at the E N55 hotside charge pipe to see if there's any magic you can work there too?
JB4 | BMS OCC | N20 TMap | Fuel-It! PI | AIC6 PI Controller | Fuel-It! Fuel Lines | Fuel-It! Stage 2 LPFP | Continental In-line E Sensor | ER Charge Pipe | Pure Stage 2 Turbo | Pure High Flow Inlet | GFB DV+ | Richter C'less D/Pipe | Berk Race Full Exhaust | MFactory Pro Helical LSD (75% Bias Ratio) | eDiff Disabled Via Coding | MFactory Solid Diff Bushes | Diff Lockdown Bracket | Custom 98G0B BEF | NGK 5992s (0.020")
Mike_L's Avatar
Anti-Social
Default 09-24-2016, 02:58 PM
Can I ask a stupid question? How's the install of this on an xDrive car? I was just looking at Dinans turbo instructions and they drop the steering rack before they remove the inlet. Is that necessary? If I gotta do all that I may have consider a Stage 2 since I gotta tear everything apart anyway.
Mike Levy
2017 X3 xDrive35i
2000 F150 Lightning
Lowon's Avatar
Lowon Lowon is offline
Car: Bmw M2
Default 09-24-2016, 08:26 PM
Some people drop a motor mount or pull the engine. My shop just pulled my engine out to install the stage 2 turbo.
Mods: Stock for now
Car: F20 M135i
Default 09-25-2016, 03:19 AM
I installed the inlet pipe from top of engine. This is doable on X-Drive too.
peter@pureturbos.eu
pureturbos.eu
Default 09-26-2016, 01:25 PM
It's not doable from the top on an M235i because of this:
http://www.realoem.com/bmw/enUS/show...diagId=17_0907
The M135i looks like this:
http://www.realoem.com/bmw/enUS/show...diagId=17_0654
There's an extra oil-water heat exchanger (number 26 in first pic) that blocks access to the inlet, so you can only see the retaining nut from below. This is the same bugger that makes installation of the EWG wires a bloody knuckles affair.
The 335iGT looks like it has the same setup as the M135i...
Lowon's Avatar
Car: Bmw M2
Default 09-26-2016, 01:46 PM
Is it possible to swap radiator cores to a larger aftermarket one? I noticed oil temps getting a bit too high with pure stage 2 on the track, and on my m2 temps look ok with the stock turbo and stock boost, but I don't know if it can take more boost or a larger turbo.
Mods: Stock for now
