(#1151)
alfanatix alfanatix is offline
Car: f30
Default 03-19-2018, 08:37 PM
Hello Terry, Tested with FUA 10. Seems much more better. all the jerkiness and hesitation when going WOT is gone. more smoother at WOT and half throttle but why is it different?
attach is the log. throttle curve is much more better.
Thank You Terry
eksigned eksigned is offline
Car: Infiniti G37
Default 03-19-2018, 10:54 PM
Out of town for another week, so without being able to update to firmware 9 and check for myself, does this update by chance get rid of the...what feels like, a power cut between shifts in comfort and low-end sport shifts...aka improve driveability? Thanks Terry!
After reading through previous posts, and seeing that that there were no tuning changes...I’m assuming no to the above?
Default 03-22-2018, 12:31 PM
After reading through previous posts, and seeing that that there were no tuning changes...Iím assuming no to the above?
No general tuning changes but, as always, log your specific issue with the latest firmware and we can work with you find find ways to resolve it.
Default 03-22-2018, 12:32 PM
Thank You Terry
Good, log looks clean to me. Hope it stays this way.
Repo335i Repo335i is offline
Default 03-25-2018, 01:30 AM
Hi, have read in a German forum that it would be nonsense that the component protection in jb4 and other boxes would remain active ... what are you holding it?
Car: f30
Default 03-25-2018, 07:24 AM
Great! Thanks Terry. Hope to see more development on B48/B58 in near future.
Default 03-25-2018, 09:09 AM
Huh?
All factory safety systems remain in place with the JB4 active, and the JB4 adds to those safety systems using CANbus data to disable tuning based on over boost, run lean, and other situations more aggressively than the factory tuning itself would.
Default 03-25-2018, 12:35 PM
hi guys have finally managed to make a log .. and the new update I have on it. does the log look good?
Joee2204 Joee2204 is offline
Car: M140i lci2
Default 03-26-2018, 10:54 AM
Hello just a quick question, I don’t have the Bluetooth module and have the lci2 dash so the needles are bouncing all over, I’ve tried following the YouTube tutorials and can’t seem to get it to change to map selection, can anyone help or solved it them selves? Thanks
Default 03-26-2018, 11:07 AM
Nothing here... Maybe CANbus isn't working? Or recorded wrong.
Hoosier Daddy Hoosier Daddy is offline
Car: M140i
Default 03-26-2018, 11:28 AM
Originally Posted by Joee2204
Hello just a quick question, I donít have the Bluetooth module and have the lci2 dash so the needles are bouncing all over, Iíve tried following the YouTube tutorials and canít seem to get it to change to map selection, can anyone help or solved it them selves? Thanks
Hi bru. JB4 isn't compatible with LCI2 dash yet. I have the same issue. Got me a BT module and I'm more than happy.
Default 03-26-2018, 01:14 PM
hi, but I did everything right. Start logg then finish on logg finished .. you can not do much wrong ... But a question, can it be with a data display problems with jb4? because both are hanging on the can bus ..
Car: M140i
Default 03-26-2018, 01:42 PM
Default 03-26-2018, 02:36 PM
We'll be adding new dash support in a future software update. JB4 Mobile works great until then!
Default 03-28-2018, 09:34 AM
I wanted to say that I solved the problem ... It was on the data display, so I could not make logs ...
crp140 crp140 is offline
Car: m140i
Default 03-28-2018, 02:23 PM
Just updated my jb4 to version 9, the exhaust valve control has stopped working, this i use quite a lot due to the valve in my exhaust being used as a silencer bypass now, any chance this could be looked at?/added to the app instead?
Cheers! Keep up the good work
Default 03-28-2018, 02:49 PM
and what do you think looks good on the log or?
Default 03-28-2018, 03:03 PM
Not heard of any issues with it. Anyone else having one?
Logs go in the support area but at quick glance looks normal to me.
Default 03-28-2018, 11:11 PM
yes but in the support area I was told I should post it here ...
Bullitt1841's Avatar
Default 03-29-2018, 09:06 AM
Yes, CANflap is finicky on mine and always has been. Sometimes I have to try holding the BC button a few times before it opens or closes.
Also, closing the valves does not return to stock operation. It purely closes the valves until I restart the car.
2018 Audi RS3 | Stage 1 E85 and 91 Flashes | JB4 for Logging
Default 04-01-2018, 01:09 PM
hi is it possible with the jb4 app to read the exhaust temperature?
Default 04-01-2018, 01:39 PM
There is no factory EGT sensor, the value is modeled by the DME and barely accurate stock, not accurate tuned.
Default 04-01-2018, 02:57 PM
ok thanks ... do you test on a test vehicle how high the temperature rises? because the B58 series and running so jb4 with lean there are no problems with the exhaust gas temperature?
Default 04-01-2018, 04:11 PM
Yes half mile full throttle testing was part of the orignal testing phase.
