(#1251)
Default 10-05-2015, 11:23 AM
Originally Posted by SOURCE1064
Hope this fixes my issue. I only noticed this after switching to the OBDII software.
Let me know. If it doesn't we'll keep hunting around for it!
jarrett jarrett is offline
Car: BMW
Default 10-05-2015, 11:07 PM
v1.53 received three reports of the CAN system randomly disabling itself until the vehicle is restarted. Made a minor code change which may correct that issue.
I've actually had this issue. I'll update and see if it goes away.
SOURCE1064 SOURCE1064 is offline
Car: Daily 08 335I Weekend 05 M3
Default 10-06-2015, 04:41 PM
That seemed to do the trick!
Charlie
2015 ///M3 Black Sapphire Metallic/ Black Extended Leather/ Carbon Fiber Trim
geared geared is offline
Default 10-07-2015, 03:42 PM
On a heart breaking Mustang Dyno. See below. Florida humidity/heat.
3.5 gallons of e85 mixed with a full tank of 93 octane
jb4 on map 2 (we think it maybe was still learning...see below)
ar *********
removed secondary filter pads
dinan exhaust
I switched it into Map 2 about 15 minutes before dyno. I did two spirited pulls, but I think it was still learning, as on the pulls you could see open/closed loop morphing and the a/f ratio leveling out.
I hit 527 torque on the last pull, but the power broke apart, and a got a hot engine warning so we instantly let out. Terry - what could be the reasoning here, as we only did 3 pulls? The fan we weere using wasnt huge, and the hood was closed, so potentially that is why. I have never seen this warning on the street.
Roger @ Pros Tuning, very smart guy btw, says his dyno reads 7-10% lower than the average dynojet. My buddies Supra which makes around 1,000 on the dot made 880 on this dyno on the same day.
475 / 502 on a mustang ; 508 / 537 on a dynojet (7% factor)
Im happy. Thanks Terry
Default 10-07-2015, 04:54 PM
Without JB4 logs of the runs who knows.
Pennzoil Pennzoil is offline
Car: BMW M4 RHD
Default 10-08-2015, 02:58 PM
Terry , i just ordered charge ***** and meth kit from BMS , and i want email you asking about the meth kit setting , may i ?
Default 10-08-2015, 04:58 PM
Use this thread for S55 water/meth discussion, questions, etc: http://www.n54tech.com/forums/showthread.php?t=31587
AM4ZING AM4ZING is offline
Car: F82 M4 6MT MW/SO | E46 M3 6MT AW/IR
Default LOG - 10-10-2015, 10:16 AM
Logging my car but something is off
I use the JB4 software on my tablet via USB and....
MAP1 on 91oct, my car hits 26psi
-Yesterday i added 4 gallons of E85 and put it on MAP7 as it also reached 26psi, cool...
BUT...
Then, i wanted to log and i check-marked the box that said "Ethanol Input" and after that, the car wouldnt make over 24psi
Any idea about that "Ethanol Input" selection?
Default 10-10-2015, 10:27 AM
On the JB4 mobile? You select that if running a flex fuel sensor. Doesn't effect anything on the tuning end. Yet.
Map 7 has a slightly variable target based on inlet temps. Logs attached look OK to me.
Default 10-10-2015, 10:35 AM
Considering my car was hitting max 26psi on MAP 1 and now only 24psi on MAP 7, could it be because i selected "ethanol input" on the mobile app? or did it not boost higher due to high IAT
Default 10-10-2015, 01:54 PM
Map 1 is additive. Map 7 is absolute. So the boost values don't mean much without the other variables.
Malte@CFD Malte@CFD is offline
Car: BMW M4 F82
Default 10-11-2015, 09:50 AM
Supports S55 JB4 cold/hot oil protection like the N55 ESeries JB4?
JB4 has cold/hot oil protection built in. So expect stock like boost until oil temps are > 160 degrees. Same goes for oil temps > 280 degrees.
Default 10-11-2015, 10:01 AM
Originally Posted by newm4
Steve ore Terry
Logs must be posted to the support area and you must post the CSV files, not links to a 3rd party site.
Default 10-11-2015, 10:02 AM
Yes, stays off below 160 degrees and tapers boost down starting at 270 degrees.
Car: BMW M4 F82
Default 10-11-2015, 12:20 PM
Ok thanks. Before 160 degrees car is running stock?
Other question:
Those numbers are at crank or whp?
Default 10-11-2015, 12:30 PM
Dynojets measure WHP. Stock boost until oil is up to temp.
Car: BMW M4 F82
Default 10-11-2015, 12:44 PM
Just wondering about 430 whp stock, stock car has 431 at crank. That means with Map2 it makes ±600 hp at crank?
335iFFM 335iFFM is offline
Default 10-12-2015, 07:26 PM
I've never seen a M3/M4 with 425HP/431PS. They are more like 460-490PS on german dynos.
335i N55 DCT
Default 10-12-2015, 07:40 PM
Crank HP is a useless measure. You can't sit on top of an engine and drive it around.
Car: BMW M4 F82
Default 10-12-2015, 10:56 PM
I know, just want to interpret your dynos correct for our customers. In germany its common to display only crank hp - maybe because it "looks" better
Wo hast du einen Serien M4 mit 490 PS gesehen? :D
Default 10-13-2015, 01:58 PM
Did you measure your 100-200km/h time? My car runs a 8.7s stock (Pbox corrected) and 8.5s uncorrected. That can't be 431PS. I'll hit the dyno soon. And - just to be correct - 490PS was the top of my range. It's more like 'up to' 490PS. Most of them have ~460PS.
Ich kenne zumindest keinen mit 431PS. Schau Dir Mal die ganzen Dynos an. War selber mit einem Kollegen drauf. 475PS :P. Habt ihr wieder die M4-Style Heckspoiler da? Meiner war leider von der Qualität nicht so gut ;-).
335i N55 DCT
Car: BMW M4 F82
Default 10-14-2015, 08:40 AM
Measured not yet, Vbox is ordered. Send you an PN
Ando @ BMS's Avatar
BMS Customer Service
Car: bmw 335i
Default 10-14-2015, 11:34 AM
taka taka is offline
Car: E90 335i N54
Default 10-15-2015, 08:28 AM
When I attach JB4 to a right-hand drive, I cannot put it on because EWG harness is short.
I want an extension line for right-hand drives.
Default 10-15-2015, 08:32 AM
You can extend the two EWG wires if needed. I've not looked at an RHD EWG model myself but I imagine you could also locate the box on your passenger side to make more room within the harness.
