(#251)
m6beast's Avatar
m6beast m6beast is offline
Car: 335i/m6
Default 06-27-2014, 08:27 PM
I'd guess in the 480-490whp range on a conservative tune for 93.
Great job T can't wait to see how well this beast performs. You think turbo upgrades are worth the investment on that beast?
I'm pretty sure that's a little too early for where you're going with it but would like to know for I plan to pick one up maybe by the end of the year that is if they don't come up with a M2 next year. That's where I'd really like to have with some BMS touching up. Power to weight would be the **** and hopefully wider fenders to go with it.
Thanks again for all you do lovin the meth setup on my car runs strong!
G
2Times's Avatar
2Times 2Times is offline
Car: 08 E92 335xi
Default 06-28-2014, 04:38 AM
Your development work is amazing. Good call on making it all one package, good business sense too.
I'm debating between the F80 and (don't laugh) Porsche Macan Turbo. If there were a JB4 for the Macan, I would probably just get that but this M3 stuff is so exciting!
T - no plans on doing porsche stuff huh? There aren't any tunes available for the Macan yet
Default 06-28-2014, 07:11 PM
Sorry BMW keeps me busy enough as is.
Caruso0644's Avatar
Caruso0644 Caruso0644 is offline
Default 06-30-2014, 02:17 PM
Terry how long should we wait to throw the tune in? Meaning do you suggest putting 1k miles on the stock platform?
15' M4 : JB4 : BMS intake : Meisterhaft full exhaust : AR **'s : MSR Charge ***** : H&R Sport Springs / 08' E92 335i : Montego Blue : JB4-G5 : DCI : BMSMeth : BMSoilCC : VRSF **'s : VRSF Front Mount : 19" Vertini Magic : Bridgestone RE-11 : Carbon CSL Trunk Lip : MtechRearBumper : Mtech FrontBumper
EdHunter69 EdHunter69 is offline
Car: e92 335i
Default 07-01-2014, 02:52 AM
Next try:P:
The SparkPlugs used in M3/4 looking very promising. Will they fit into an n54 (fbo), and if are they better than ngk?
BavarianBullet's Avatar
BavarianBullet BavarianBullet is offline
Assistant pedal masher
Default 07-01-2014, 06:18 AM
Clone yourself!
Modern Audi is suffering in the dark ages of $1300-$2000 flash tunes that you have to drive to a shop to install and de-install to go to dealer visits. Ugh!
Great cars with good engines, DSG, LSD just crap for tunes.
Rescue us Terry!
2011 335xi Sedan 6AT, Premium, CW, Nav, Space Gray, Oyster and black. N55 JB4.
Glowin's Avatar
Glowin Glowin is offline
Car: 335
Default 07-02-2014, 09:36 AM
Originally Posted by BavarianBullet
Clone yourself!
Rescue us Terry!
I thought that APR and Revo had flash at home solutions thru OBDII port?
Default 07-02-2014, 09:56 AM
No, you have to bring your car to one of their dealers and they perform some sort of unlock on the bootloader or whatever. Once the ECU is "unlocked" they or you can OBD to it, depending on the tuner. You then have to reverse the process if you want to go to the Audi dealership for service. Not exactly fun if the tune installer is nowhere near your house (esp if you break down and need to be towed).
The tune choices are also significantly more limited for the 2013-2015 3.0T cars (B8.5). No map selection by cruise stalk etc.
It's the dark ages and no one is going to spill the beans on what is likely a simple trick to unlock the bootloader so anyone can flash it. We need bimmerbost help on that.
The majority of the power unlocked on these engines is just keeping the boost bypass valve closed after 5000rpm and swapping the SC pulley. It's prime meat for a JB4!
Default 07-02-2014, 10:48 AM
Getting closer. This is on E30. Time to step up to E40.
Forgotpassword's Avatar
Forgotpassword Forgotpassword is offline
Car: 2009 BMW 135i
Default 07-02-2014, 11:14 AM
^AFR looks steady but I can't read those trims. Does this ECU also measure -34 to +34?
2009 BMW 135i 6AT
AR **'s, BMS DCI, ETS 5" FMIC, Tune: Super Secret
Default 07-02-2014, 11:16 AM
Wow, boost stays at 25 all the way to redline with no timing drops! How is the LPFP and HPFP doing so far? Add more ethanol and crank her up!
Glowin's Avatar
Car: 335
Default 07-02-2014, 03:06 PM
Your local dealer must love reading your posts! LOL! :D
A418t81's Avatar
A418t81 A418t81 is offline
One tire fire
Car: E92 335, 6MT
Default 07-02-2014, 04:18 PM
Freakin' awesome Can't wait to get my car back!
18 Magnetic Gray Raptor S-crew
'17 991.2 Guards red Turbo S. 10.54 @ 131 stock
'07 997.1 6MT: FBO, stock turbos, E85: 5.9 60-130
'18 Nardo Gray RS3
Tony007 Tony007 is offline
Car: F80 M3
Default 07-02-2014, 04:47 PM
Hey T, can you also post up the graph for 93 pump gas?
Default 07-02-2014, 04:56 PM
Not going crazy yet with sharing data I know want-to-be competitors are following this thread. But upon release we'll post the tuning specifics for each map.
mad chemist's Avatar
mad chemist mad chemist is offline
Default Jbm - 07-03-2014, 06:35 AM
First off - excellent work Terry, as always.
Quick question - coming from a JB3-tuned 135i (which I was very happy with) and moving into an M4 DCT in 4 weeks, can you advise on an estimated release date for the new tune.
Cheers,
Mad.
Default 07-03-2014, 07:48 AM
There is no set ETA for release. But we'll probably have a few alpha units ready to go in a couple weeks.
chuckd05 chuckd05 is offline
Car: 08 135i , 06 325xi e90
Default 07-03-2014, 09:17 AM
the shifts must be so fn fast.... amazing to see those logs like that
e92
Jc15f82m4 Jc15f82m4 is offline
Car: 2015 M4
Default 07-03-2014, 10:00 AM
Terry,
This is super exciting. Keep up the great work! I know the community appreciates it more than you know.
A couple q's:
1. What were the power levels with the E30 in comparison with the ~93?
2. How is the JB4 with the EWG control working out? Seems like the boost is staying right on target.
3. Were you ever able to figure out if the charcoal filters had a significan impact on the flow?
4. Do you have any comments on your thoughts on the factory fuel system?
5. (Last for now, promise) Any major issues with traction ATT?
Default 07-03-2014, 10:23 AM
On the dyno now. I smell a new s55 dyno record
Car: 2015 M4
Default 07-03-2014, 10:24 AM
Ready to see results
A418t81's Avatar
One tire fire
Car: E92 335, 6MT
Default 07-03-2014, 11:16 AM
Can't wait for the results
'18 Nardo Gray RS3
Default 2015 M3 JB4 Ethanol Testing & Dyno - 07-03-2014, 11:36 AM
Got back from a couple hours of dyno tuning and came back with some interesting results. This car definitely likes E85...
The JB4 now has full electronic wastegate control in addition to the fuel mass control & CANbus, pathing the way for E85 testing. The test car is our 2015 DCT M3, 100% stock with a JB4, with ethanol mixed with 91 octane at 30-50%.
I've been running E30 for the last week on a tune that ramps up to around 25psi and I've been very impressed with it. On the dyno today running that same trim resulted in a very consistent ~510whp / ~510wtq results. Although the turbo holds boost to redline it looks like shifting around 6000rpm will result in the best acceleration results as power noses off above that.
While I had it strapped down I decided to explore more aggressive power levels. Added a little more E85 and went on an hour long adventure through many different curves and tweaks. Finally arrived at a 28psi peak tune which yielded ~540whp / ~575wtq. I've not tested this much on the street so we'll have to see how viable it is. But this just goes to show you how much room was left on the table for tuning with this platform.
This car is an animal.
c0zgrove c0zgrove is offline
Default 07-03-2014, 11:43 AM
Thanks for the update Terry. This is good stuff!
2014 F56 MINI Cooper S
Default 07-03-2014, 11:44 AM
Here you go:
http://www.n54tech.com/forums/showthread.php?t=25698
